Old Jan 03, 2007, 10:56 AM
Dragon 2 is offline
Find More Posts by Dragon 2
Fly Fly Fly Crash
Dragon 2's Avatar
United States, CO, Montrose
Joined Aug 2005
Here is the pac 15c 2100 Mah 31 amp 42 burst. I will try the 11x 5.5 prop. , but the watt meter says only 300 watts with the 12x 6 prop and 30 amps. It used like 400mah on the 30 second test.Seemed like alot. Must be a 15c , not a 10c My bad.
Dragon 2 is offline Find More Posts by Dragon 2
Old Jan 03, 2007, 11:13 AM
mjws is offline
Find More Posts by mjws
Airdrie, AB Canada
Joined Sep 2004
400mah in 30 seconds requires 48A of current. Doubful that your motor is pulling that. If the pack is 31A-42A it is a 15C 20C pack.
But it sounds like the pack is more hype then capable. It may get a little stronger after a few charges if you had treated it gently (break-in). The himax on 2100mah packs and a large prop is going to push them. Much less than the EVO's or Extreme's and you will need pretty solid throttle management. Overrated packs just won't cut it.
300w is still decent power on the plane hopefully ~150w/lb. But if you're tagging lvc you are stressing your batts and they won't last long. 30 seconds is a very long burst for 3D type flight. For pattern/sport if you are going to stay at WOT long you need to prop down or use larger or stronger packs.
mjws is offline Find More Posts by mjws
Old Jan 03, 2007, 11:19 AM
Dragon 2 is offline
Fly Fly Fly Crash
Dragon 2's Avatar
Joined Aug 2005
I'm going to try a 11x 5.5 prop now and see if that helps.I hate to think these packs are over rated as I have been using them on other planes with no problems!! Thanks for the info.
Old Jan 03, 2007, 11:25 AM
mjws is offline
Airdrie, AB Canada
Joined Sep 2004
Just saw your pack. My understanding of commonsense packs is that they try and be reasonably conservative in their ratings. Unfortunately just because it will run at 30A and not blow up doesn't mean it will hold high voltage there.
Pretty obvious if you're only getting 300w exactly what the pack is capable of as it is the primary limit in that system.
Is your lvc a little high by any chance? Alternatively you can choose to just lower it and take the reduced pack life as it comes at you. Not the end of the world if things don't overheat no biggee. But it will definately reduce pack life. Or be a little easier on the throttle.
Always a trade off. But the choices are simple.
Good luck,
Old Jan 03, 2007, 11:45 AM
Dragon 2 is offline
Fly Fly Fly Crash
Dragon 2's Avatar
Joined Aug 2005
Well I went out to try the 11 x5.5 and thats what was on there. I then put on the 12 X6 and the watts went to around 400 and the amps to over 32 I watched the volts and they dropped quickly to like 9.7 . I didnt keep the throttle up very long . I didnt want to ruin the battery. Should I fly with the bigger prop and just manage the throttel or go even smaller than the 11X 5.5. remember I'm at 6000 ft above sea level.Please be paitent as I'm still on the learning curve.
Old Jan 03, 2007, 12:02 PM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
Dragon,
your 400w figure didn't seem correct to me:
400W/32A=12.5V under charge
The pack must be VERY good to sustain 12,5V. My charger only charge a 3s pack till 12,6V, then the voltage sag a bit after disconnecting the pack.
more data please.
jalves is offline Find More Posts by jalves
Old Jan 03, 2007, 12:05 PM
Dragon 2 is offline
Fly Fly Fly Crash
Dragon 2's Avatar
Joined Aug 2005
My LVC is what came on it. Its a castle Creations 45 amp.
Old Jan 03, 2007, 12:23 PM
Dragon 2 is offline
Fly Fly Fly Crash
Dragon 2's Avatar
Joined Aug 2005
This is all new to me , but my MPI watt meter says 12.42 after full charge.I just did a test with the 12x6 prop. It went to 385 watts 32 amps for about 25 seconds at full throttle and cut off. The volts went down to 9.38 when it shut off. It said I used 270 mah. I have been told my meter is not correct as it should read 12.6 at full charge. I have 7 lipos that all read 12.42 at full charge.I'm letting the battery fully cool then will recharge it and try again with a 11 x 5.5 prop.
Old Jan 03, 2007, 12:31 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Try to reduce the LVC of the phoenix to 9V (3V per cell)
It seems your lipos can't withstand the current pulled by the himax with a 12x6.
If your Himax is the 1130rpm/V, everybody is using the APCe11x5.5 with good results
Old Jan 03, 2007, 12:34 PM
Dragon 2 is offline
Fly Fly Fly Crash
Dragon 2's Avatar
Joined Aug 2005
Thats the prop (11 x5.5 ) that it shut down with in flight yesterday. Does the altitude effect it? I will try lowering the LVC , but would hate to reduce the life of the pac. New test with the 11x 5.5 to follow.
Old Jan 03, 2007, 02:22 PM
Dragon 2 is offline
Fly Fly Fly Crash
Dragon 2's Avatar
Joined Aug 2005
Last test. I think the battery is getiing stronger with a few charges under its belt.This test was with the 11 x 5.5 prop and it ran 315 watts at 29.5 amps and dropped to 9.7 vollts and didnt shut off after at least 30 seconds. It used 301 Mah. The problem may have been the new battery hadnt got to full strength. I guess I should use this prop. thanks for all the input. RB
Old Jan 03, 2007, 02:50 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
EDIT: Problem solved...
Old Jan 03, 2007, 04:44 PM
Dragon 2 is offline
Fly Fly Fly Crash
Dragon 2's Avatar
Joined Aug 2005
I'm sorry it 9.7 volts not 7.9 Its been a long couple of days.Does that sound better. It didnt kick off and seems to pull like a horse.
Old Jan 03, 2007, 05:27 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Glad all is solved
Enjoy the plane, it is very good.
I am recovering mine, should be flying again next weekend.
Old Jan 03, 2007, 05:33 PM
Arbo is offline
Find More Posts by Arbo
Joined May 2000
Originally Posted by Dragon 2
Sorry to hear about your loss.The other guy ran away because he thought it was his fault and didnt want to have to pay. On a brighter note I got to maiden my AM today at our clubs chilli fly. It flew perfect with no trimming needed at all. I was totally impressed. It was 28 degrees, but sunny. Happy New year to all
Yeah, that thing flies like a champ. Here's some pic's.
Arbo is offline Find More Posts by Arbo
Reply With Quote  (Disabled)
Discussion Extremeflight Extra vs Multiplex Acro Master Magna 3D Flying 17 Dec 10, 2008 01:11 AM
For Sale Multiplex Acro Master RTF slopenutz Aircraft - Electric - Airplanes (FS/W) 6 Jul 13, 2007 04:12 PM
Sold Multiplex Acro Master termite Aircraft - Electric - Airplanes (FS/W) 8 Mar 20, 2007 05:04 PM
Link Multiplex Acro Master $99.99 Doubletap Hot Online Deals 6 Dec 18, 2006 03:37 PM
New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 Joe Pierson Aircraft - Electric - Airplanes (FS/W) 0 Sep 06, 2001 01:48 AM
