Old Jan 01, 2007, 03:01 AM
SD_Raptor is offline
Find More Posts by SD_Raptor
SD_Raptor
San Deigo, CA
Joined Mar 2006
Originally Posted by Wilron
Randy,
how many amps are you drawing with the 11inch prop?
I want to keep my power draw to around 30amp max and was originally thinking of using the recommended Himax with a smaller [around 9x5] prop,
but this Hyperion looks to be an alternative. My reading of the tables suggest that the Z3013-14 with an 11x5.5prop has a max amp draw 27.5 on 3s.
Is this what you are getting?
Ron
I'll try to grab some data tomorrow with my Eagle Tree logger and post the results for you.
Randy
SD_Raptor is offline Find More Posts by SD_Raptor
Old Jan 01, 2007, 11:57 AM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
Folks,
Look the condition of my AcroMaster after a brief meeting in air with a glow trainer.
The glow trainer owner just land his plane with dead motor, clean it and run away before I came back with the wreckage, that's odd don't you think??
Happy 2007
jalves is offline Find More Posts by jalves
Old Jan 01, 2007, 12:26 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Nah, you should of waited until he landed then run over and stepped on his plane real quick before picking up your pieces.
As for the contest between a heavier, more reinforced (to deal with the IC engine vibrations) glow plane and a foam electric, I'd think the built-up would win the majority of times. Sorry to hear of your loss though. Mid-airs suck, but they're also usually no ones fault, just part of the hobby.
Vantasstic is offline Find More Posts by Vantasstic
Old Jan 01, 2007, 12:27 PM
punkindrublik is online now
Find More Posts by punkindrublik
multirotormania.com
punkindrublik's Avatar
United States, CA, North Highlands
Joined Sep 2004
The carnage, THE CARNAGE!!
Aw man, I'm sorry. Thats a horrible way to kick off the new year
Brian
punkindrublik is online now Find More Posts by punkindrublik
Site Sponsor
Latest blog entry: TBS/VAS Triumphs IN STOCK!
Old Jan 01, 2007, 12:48 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Yea, positive thoughts, positive thoughts...
But the other flier make some bad comments about my AM Yesterday, when I was launching it.
Thus, I don't understand his behave after the clash, no excuses, no help to collect the pieces, just run off as soon as he could,
What worries me most is the time needed to replace the AM
Old Jan 01, 2007, 02:29 PM
Dragon 2 is offline
Find More Posts by Dragon 2
Fly Fly Fly Crash
Dragon 2's Avatar
United States, CO, Montrose
Joined Aug 2005
Crash/ maiden
Sorry to hear about your loss.The other guy ran away because he thought it was his fault and didnt want to have to pay. On a brighter note I got to maiden my AM today at our clubs chilli fly. It flew perfect with no trimming needed at all. I was totally impressed. It was 28 degrees, but sunny. Happy New year to all
Dragon 2 is offline Find More Posts by Dragon 2
Old Jan 01, 2007, 03:54 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Tnx and Congrats,
You'll love the AM flight envelope.
Old Jan 01, 2007, 04:08 PM
multirotormania.com
Joined Sep 2004
Hey! Mine didn't come with any "envelope"
Site Sponsor
Old Jan 01, 2007, 04:48 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
You understand what I mean with "envelope", very good flier
Old Jan 01, 2007, 05:00 PM
multirotormania.com
Joined Sep 2004
I was just tryin to be funny...
Site Sponsor
Old Jan 02, 2007, 06:51 PM
Dragon 2 is offline
Fly Fly Fly Crash
Dragon 2's Avatar
Joined Aug 2005
Lost tail wheel
The tail wheel fell of my AM today. Can someone tell me the diameter of the wheel so I can try and find a new one.Where can I order AM parts? This little wheel has me shut down.
Old Jan 02, 2007, 07:26 PM
multirotormania.com
Joined Sep 2004
27mm or 1.050"
A 1' foam wheel should work fine although the stock ones are very light.
Good luck,
Brian
Site Sponsor
Old Jan 03, 2007, 09:04 AM
Dragon 2 is offline
Fly Fly Fly Crash
Dragon 2's Avatar
Joined Aug 2005
Thanks. I'll check my LHS
Old Jan 03, 2007, 10:07 AM
Dragon 2 is offline
Fly Fly Fly Crash
Dragon 2's Avatar
Joined Aug 2005
LVC cutting out
I'm running the himax 3516/1130 motor with 12 x6 prop at 6000 ft above sea level. I'm useing a 2100MAh 10c lipo rated for 31 amps 42 burst. CC 45 amp ESC. On my MPI watt meter it says I'm pushing near 300 watts and 30 amps , but if I run full power for like 20 second the motor kicks off. I can throttel down and go again. Its fine if I keep it half throttel and only kick it for a few seconds.Is this normal or is my battery really not putting out what it says it should?. The battery is new, with only 2 flights on it. When I just checked it for like only 30 seconds I could feel the battery and ESC were starting to get warm already. The battery was charged on a Triton and balanced on a thunder power balancer!
Old Jan 03, 2007, 10:33 AM
mjws is offline
Find More Posts by mjws
Airdrie, AB Canada
Joined Sep 2004
The voltage on your 10C (21A) pack is sagging when you draw 30 amps. Watch it when you plug in your wattmeter. It is probably fine with the burst current for a while and then decays till it hits your LVC. Classic pack killer.
You need a stronger pack, smaller prop, or shorter burst. Even an 11x5.5 on that motor typically draws upwards of 340w if the packs can put out.
Edit: You've changed the math on your pack. What is it exactly? 10C is 21A not 31A. The problem is still the same. Watch your meter when you pin it.
mjws is offline Find More Posts by mjws
Discussion Extremeflight Extra vs Multiplex Acro Master Magna 3D Flying 17 Dec 10, 2008 01:11 AM
For Sale Multiplex Acro Master RTF slopenutz Aircraft - Electric - Airplanes (FS/W) 6 Jul 13, 2007 04:12 PM
Sold Multiplex Acro Master termite Aircraft - Electric - Airplanes (FS/W) 8 Mar 20, 2007 05:04 PM
Link Multiplex Acro Master $99.99 Doubletap Hot Online Deals 6 Dec 18, 2006 03:37 PM
New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 Joe Pierson Aircraft - Electric - Airplanes (FS/W) 0 Sep 06, 2001 01:48 AM
