Old Dec 12, 2006, 03:51 PM
Lightnin is offline
Find More Posts by Lightnin
Non-Discriminatory User
Lightnin's Avatar
Joined Mar 2003
What do you think of this setup?
Motor: Mega ACn 16-25-3; 1700rpm/V; 1.9A no-load; 0.017 Ohms.
Battery: Sanyo CP-1700SCR; 12 cells; 1700mAh @ 1.2V; 0.0055 Ohms/cell.
Speed Control: Generic Brushless ESC; 0.006 Ohms; High rate.
Drive System: SKYCAT; 12x8 (Pconst=1.08; Tconst=1) geared 2.3:1 (Eff=95%).
Airframe: SKYCAT; 558sq.in; 53.3oz; 13.7oz/sq.ft; Cd=0.043; Cl=0.06; Clopt=0.39; Clmax=0.89.
Filter: 80% min efficiency.
Stats: 121 W/lb in; 102 W/lb out; 22mph stall; 33mph opt @ 60% (16:31, 109F); 88mph level; 1989ft/min @ 42.9; -510ft/min @ -10.
Now as you can see this was for my skycat....it was a pig...and this setup made it fly very nice...just almost hover.
This time I will use lipos..any thoughts?
Lightnin is offline Find More Posts by Lightnin
Old Dec 12, 2006, 05:55 PM
mjws is offline
Find More Posts by mjws
Airdrie, AB Canada
Joined Sep 2004
Motor is about the right weight. (110g) You still have to add a gearbox on that, but should be in the ball park.
According to motocalc that rig is pulling 400w or so (121w/lb*3.3). That is also right in the ball park. But you have 14v using 12 cells. Closer to 4s than 3s.
Effective KV geared 2.3:1 is 739. The 800KV motors do very nicely in this plane on 3s and a 12x6 or 13x6.5 ... The slightly lower kv and a 12x8 should be fine and put you squarely in the 350-400w range.
Passes the quick and dirty sanity check for me. Don't know how much of a pain it will be to mount. But it should balance and work fine. Wouldn't be my choice but if it's there... why not? Should be much nicer on a 33oz plane than 50oz.
mjws is offline Find More Posts by mjws
Old Dec 12, 2006, 06:25 PM
Trexflyr is offline
Find More Posts by Trexflyr
Joined Sep 2006
Would the E-flite 480 work for this plane?
Trexflyr is offline Find More Posts by Trexflyr
Old Dec 12, 2006, 08:21 PM
Dragon 2 is offline
Find More Posts by Dragon 2
Fly Fly Fly Crash
Dragon 2's Avatar
United States, CO, Montrose
Joined Aug 2005
trexflyr
If your talking about the 480 bl outrunner, I think it will be to small. that motor is for 3D planes from 550 to 850 grams and the acro master comes in around 1100 grams. The Himax 3516/1130 is what is recommended
Dragon 2 is offline Find More Posts by Dragon 2
Old Dec 12, 2006, 09:51 PM
mjws is offline
Airdrie, AB Canada
Joined Sep 2004
The Power 10 is almost identical to the recommended system. The 480 is a little small, but it will certainly get it up in the air. Lots of 30oz planes i.e Brio flying on it.
Old Dec 13, 2006, 09:12 AM
LRHann is offline
Find More Posts by LRHann
Wheaton, IL
Joined Nov 2004
How well will a Mega RC600/20/8 work on the AM? It's an 885 rpm/v outrunner that weighs 4.7oz 136g. It runs about 350 watts.
http://www.megamotorusa.com/Brushles...Cn600-20-8.htm
How would this compare to the best motors out there, the Torque and maybe Hyperion and HiMaxx?
LRHann is offline Find More Posts by LRHann
Old Dec 13, 2006, 03:57 PM
Lightnin is offline
Lightnin's Avatar
Joined Mar 2003
*I ran the motocalc number last night when I got home..if I did it right this setup (which is already sitting waiting for a plane) with an 11x5.5 prop on 3s or 4s will out perform the recommended Himax motor (higher output watts/lb).
The only problem I have is (as you mentioned) I dont know how easy it will be to mount up the superbox (http://www.modelelectronicscorp.com/.../superbox.html) to the motor mount.
Old Dec 13, 2006, 04:06 PM
simon 3D is offline
Find More Posts by simon 3D
How low can you Go??
simon 3D's Avatar
England
Joined May 2004
Hi guys, just finished painting my acromaster, hopefully get her in the air in the next week or so.
a few pics.
Cheers
Simon
simon 3D is offline Find More Posts by simon 3D
Old Dec 13, 2006, 04:15 PM
mjws is offline
Airdrie, AB Canada
Joined Sep 2004
Nice Paint Job.
Old Dec 13, 2006, 04:36 PM
punkindrublik is offline
Find More Posts by punkindrublik
multirotormania.com
punkindrublik's Avatar
United States, CA, North Highlands
Joined Sep 2004
Very nice! Me likie
punkindrublik is offline Find More Posts by punkindrublik
Site Sponsor
Latest blog entry: FEAR The REAPER!
Old Dec 13, 2006, 06:35 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Love the 'star bursts' on the canopy. What kind of paint did you use and how well does/is it sticking?
Vantasstic is offline Find More Posts by Vantasstic
Old Dec 13, 2006, 07:25 PM
simon 3D is offline
simon 3D's Avatar
England
Joined May 2004
The paint i am using is AutoAir colours from createx, they are superb!, i gave the model a rub down with fine wet and dry, to get a good key, and the paint went on well, must be carefull when masking over painted surface as anything other than ultra lowtac tape will fetch off the colour.
Cheers
Simon
Old Dec 14, 2006, 12:45 AM
MICKEL is offline
Find More Posts by MICKEL
C.H.E.A.P.
MICKEL's Avatar
Chino Hills, CA
Joined Jan 2005
simon 3D,
That work is superb. Only You and Blucor seem to know what's up with this foam. Mine is all white with black canopy. Easy to see, but not a justified look for our birds of paradise. Maybe I can get my neighbor to spray her up....
MICKEL is offline Find More Posts by MICKEL
Old Dec 14, 2006, 01:09 AM
SD_Raptor is offline
Find More Posts by SD_Raptor
SD_Raptor
San Deigo, CA
Joined Mar 2006
Originally Posted by punkindrublik
Yeah, stay away from epoxy...
Brian
I have used epoxy for repairs and mods on my Magister with no problems. The trick is to properly prepare the surfaces - sand them with 300 grit to get a nice 'suede' finish and the epoxy adheres perfectly well. If something breaks there again, the epoxy will bring only a layer of elepor beads with it.
I have now decided to do more than reinforce, I am going to glass the nose with two plies of very lightweight fiberglass and use finishing resin. A test on an old piece of a 'boneyard' Magister gives excellent results. The finishing resin is a polyimide that will remain slightly flexible but with very high shear strength, complimenting the glass which adds high tensile strength. Very thin CF cloth would also work but I do not have any and it is a bit more tricky to work. The glass is nearly transparent and hides mistake much more easily - if you goof with CF, everyone can see your incomptence.
Once I have the nose glassed, I will begin applying the metallic iron-on covering. I have red, green, blue, purple and white to play with. Since I have zero artistic abilities, I probably won't post any pics (unless by some miracle it looks really nice).
Randy
SD_Raptor is offline Find More Posts by SD_Raptor
Old Dec 14, 2006, 12:12 PM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
jalves is offline Find More Posts by jalves
Discussion Extremeflight Extra vs Multiplex Acro Master Magna 3D Flying 17 Dec 10, 2008 01:11 AM
For Sale Multiplex Acro Master RTF slopenutz Aircraft - Electric - Airplanes (FS/W) 6 Jul 13, 2007 04:12 PM
Sold Multiplex Acro Master termite Aircraft - Electric - Airplanes (FS/W) 8 Mar 20, 2007 05:04 PM
Link Multiplex Acro Master $99.99 Doubletap Hot Online Deals 6 Dec 18, 2006 03:37 PM
New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 Joe Pierson Aircraft - Electric - Airplanes (FS/W) 0 Sep 06, 2001 01:48 AM
