Apr 07, 2006, 03:38 AM
San Jose, California
I added a little TIX low temp solder on top of what was left of Plantraco's original solder. For sure, you should "tin" the new battery tabs before soldering them to the old battery magnet PCB. You can google "TIX solder" and find some sources that describe it. I use TIX flux also, since some regular fluxes may not be very active at low temps. I think Plantraco has used TIX on some of their Bahoma cells, but I am not sure if they still use it or have selected another low temp solder these days. TIX works fine, although it does get into a "plastic" state before it fully melts and it ends up not so shiny as regular electronics solder. After playing with it, I found a soldering temperature of 200C worked well with a very small chisel tip. A tip with more surface area might allow you to use 190C.
For charging, I used the Didel BAPI thingies for the magnetic interface and a single cell charger I got a while back from smarttoolsinc.com. I just set it to 130mA for charging my 140, 160, and 170mAh cells. If I'm not in a hurry, I charge using my Plantraco TX (which is fixed at something like 70mA).
Mark
