I'd love to hear the following, as I'm very close to the first flight.
CG: How far back? Throws Spoilerons and elevator compensation Differential, if any Also: What thread is the little nylon bolt thats begging to break, and what SAE thread are you guys replacing it with? 4-40? What thread are the v-tail bolts? That should cover it I guess. Any news on the carbon version? |
Latest blog entry: F-20 update
Slope-
I think the thread is 3mm or 4mm. But I think I remember Bill L saying he tapped his out with either 6-32, or 8-32; I cant remember. Do a search on Mach Dart. T |
Latest blog entry: Stork 4 Pro X-tail from...
BillL's thread is here: http://www.rcgroups.com/forums/showthread.php?t=408301
I have a cg of 86 mm. Flaperon mix with down elevator worked a little bit prior to flap mod. I set the aileron throws to max deflection (~2 cm) and 50% differential. Roll rate okay but not axial yet. Still working this out. -Chad |
Is that 50% diff the actual measurement at the surface, Chad?
T |
I'd prefer to change over to SAE bolts whenever possible. Kinda hard to find a 3mm nylon bolt at 4pm in Bandon Oregon...
Also it doesnt hurt to have some commonality between planes. Most of my sheeted crunchies are either 1/4-20 or 10-32, to minimze what I have to carry in my backpack. |
-Chad Ed: that is measured at max stick movement. |
Most of these newbies don't DS. They will want the nylon in there until they master the smooth landing...In my opinion.
Chad- if your rols aren't axial, leave in the diff, and set it up on one of the "Digi Adjusters" on the EVO, that way you can adjust it easily while you are flying. T |
Your camber and reflex look good to start--- I MAXED my aileron throws and put enough elevator in to keep from snapping it-- through trial and error on the slope, as when you move your CG--the throws will change. I tapped the rear hold-down hole to 440- then used a steel bolt. I also could bolt right into the fuse-- 1/2" lead rope that I got from Tom Copp-- sections that weighed 4oz each-- I could easily ballast up to 12 oz's that way with one long bolt. Once you find your sweet spot for CG--drill a hole at the fuse bottom there, add a few fiberglass circles about 1" in size around that area for strength-- and you're good to go! F3F Mach Dart!!! They fly very nice and with ballast-- very fast!
FWIW Timmig BTW-- snap flaps should only deflect DOWN-- you don't want them mixed with your down elevator-- only UP for pull through the turns. And you shouldn't need more than 1/8" |
My approach for ballast was different. I made a ply plate with a bolt coming up from the back side that was epoxied into the fuse under the wing. I didn't want to drill a hole in the fuse. I casted a couple of 8 oz lead plates with a hole in the middle. These are held in place with a 1/4-20 wing nut and washer. Other folks and I have posted on our various methods. Can't wait till the winds kick up. -Chad |
| Thread Tools | |
| Nose lead in Mach Dart? | 80SGliderDude | Slope | 61 | Sep 23, 2005 12:02 AM |
| flaps on a Mach Dart? | rimshot | Slope | 1 | Jan 11, 2004 12:24 PM |
| Prodij or Mach Dart? | rimshot | Slope | 18 | Oct 16, 2003 09:19 AM |
| Mach Dart- Any good? | PDX Slope Pilot | Slope | 32 | Sep 22, 2003 07:10 PM |
