Old Feb 03, 2006, 12:04 PM
chileno is offline
Find More Posts by chileno
Santiago, Chile
Joined Mar 2003
How to use microballons on foam?
hi, I want to paint my formosa so I will be applying some microballoons topflite filler on to it, then sand it and finally paint with acrylic paint. But according to towerhobbies¨s description it has to be mixed with epoxy, but I dont want it to be heavier so can I put it on just like it comes from the bottle?
has anyone done this to his GWS airplane?
chileno is offline Find More Posts by chileno
Old Feb 03, 2006, 12:33 PM
podavis is offline
Find More Posts by podavis
podavis's Avatar
Louisville KY
Joined Nov 2004
I don't think it's necessary. I sanded my Pico TM with 180 grit garnet sandpaper and it cut the foam very nicely. Garnet has sharper and more brittle edges then aluminum oxide or other papers. It doesn't last any way near as long as other papers so a lot of people don't use it but on foam it's a big advantage. People use it for exceptional finishes on wood too.
podavis is offline Find More Posts by podavis
Old Feb 03, 2006, 05:08 PM
2112 is offline
Find More Posts by 2112
Yes, I am a RUSH fan!
Out Flying
Joined May 2002
You can't put microballoons on by itself because it's just a powder-like substance and won't stick to the foam. It's used with epoxy to make a lighter-weight glue than just straight epoxy - it also sands more easily than plain epoxy.
As for sanding, I've had great luck using drywall sanding screens on foam - the kind that looks like screen door material, but with abrasive on it. It doesn't seem to chunk-out the foam as much as regular sandpaper. Never tried the garnet variety on foam, though - maybe it's even better? BTW drywall screens also work great for sanding plastic without making it fuzzy.
2112 is offline Find More Posts by 2112
Old Feb 03, 2006, 06:43 PM
SEC is offline
SEC
Find More Posts by SEC
SEC
Damn you gravity!
Gladstone, Oregon
Joined Jan 2005
I'm planning on using acrylic paint on the e-starter I've just started. Sanding first with a drywall screen, then a coat of drywall spackling paist, sanding lightly again after its dry, has given a nice finish to a few test pieces, and doesn't add much weight. I found a water based clear coat at Home Depot, that's been safe with the test pieces as well, that gives a nice finish.
SEC is offline Find More Posts by SEC
Old Feb 03, 2006, 06:53 PM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I think that you could mix micro-balloons with water based latex like Min-Wax Polycrylic clear. It would be lots lighter than resin and would sand away much easier. I used Polycrylic to glass the ailerons on my GWS Zero. You should be able to glass the whole model with Polycrylic and 1/2 ounce fibreglass cloth or even silkspan. I painted my Zero with a Badger siphon type air brush using water thinned craft store acrylic. Just go easy on paint especially toward the rear. If you mount lipos and other as far forward as possible, you may not have to add as much or any nose weight.
Others have used low temp iron on coverings, probably lighter and much easier if done right.
E-Challenged is online now Find More Posts by E-Challenged
Old Feb 04, 2006, 04:43 PM
ncb is offline
ncb
Find More Posts by ncb
ncb
A&P
Parker, Colorado
Joined Jan 2004
If you do try using micro balloons make sure you wear a good respirator. The balloons are so small they blow every where and they are not good for your lungs.
ncb is offline Find More Posts by ncb
Old Feb 04, 2006, 08:45 PM
Catkicker is offline
Find More Posts by Catkicker
Nevada City, California, United States
Joined May 2004
one other thing to know about using balloons in epoxy. when you add them the epoxy cooks off much faster. i use 30 minute epoxy when i use balloons and it cooks off in just 5-7 minutes. i never tried 5 minute epoxy, i'd expect it would cook off so fast as to be unusable.
Catkicker is offline Find More Posts by Catkicker
Old Feb 04, 2006, 10:06 PM
vax6335 is offline
Find More Posts by vax6335
Crazy 'bout Bees
vax6335's Avatar
Fort Wayne, IN
Joined Oct 2005
Drywall putty works good too, and it's lightweight.
vax6335 is offline Find More Posts by vax6335
Old Feb 05, 2006, 01:22 AM
Steve H. is offline
Find More Posts by Steve H.
Zebulon, NC
Joined Aug 2000
Hmm thats odd as all I use micro balloons in is 5 minute epoxy and it doesn't effect the time it takes to cure at all, I don't know how it could even since it is cured by a chemical reaction and micro ballons are nothing but small glass balls. Maybe a different brand has something else mixed in with it? I use the white ones.
Steve H. is offline Find More Posts by Steve H.
Old Feb 05, 2006, 03:50 AM
crashawk is offline
Find More Posts by crashawk
Duh
crashawk's Avatar
grain valley mo, or about 25 minutes east of kansas city
Joined Jan 2004
it has to do with how much you mix at one time. the more you mix the quicker the epoxy cooks no matter what minute epoxy you use, when you mix in the micro balloons it keeps the heat from escapeing as fast and so the epoxy sets up faster in you cup. works better to mix it on a flat surface if you don't want it to cook quicker.
btw, microballoons are interesting to use with some ca glues. one in particular allowed me to mix the ca with the balloons and then spread it out on the surface and then it kicked like accelerater had been sprayed on it. it was a strange delayed reaction. sanded great, works well on fiberglass.
Jason
crashawk is offline Find More Posts by crashawk
Old May 10, 2009, 07:51 PM
antstoes is offline
Find More Posts by antstoes
antstoes's Avatar
Shelbyville, KY
Joined Apr 2009
Microballoons and 30 minute epoxy
Guys,
I've been trying to use Microballoons and 30 minute epoxy to do a fillet. I'm new to it and I don't understand why mine won't sand easily like I've read on the forums.
I've tried using more Microballons but the finished product is still to hard to sand. What am I doing wrong. I am going to try CA.
Ken Antos
antstoes is offline Find More Posts by antstoes
Old May 10, 2009, 08:48 PM
pdansalvish is offline
Find More Posts by pdansalvish
Lusby, MD 20657
Joined Mar 2001
I mix my Micro-ballons with a white glue, makes sanding them easier. Also, the white glue is lighter then epoxy.
pdansalvish is offline Find More Posts by pdansalvish
Old May 11, 2009, 04:48 AM
antstoes is offline
antstoes's Avatar
Shelbyville, KY
Joined Apr 2009
Microballoons and white glue
Thank you very much! Very logical and simple
Old Oct 03, 2009, 04:42 PM
RonR214 is online now
Find More Posts by RonR214
Memb DEAF R/C
RonR214's Avatar
Dallas, TX
Joined Nov 2005
Just ran across this thread so it is probably way too late, but thought I would offer my 2 cents.
Suggest you try finishing resin. Dose not have the hardener (can't remember the name of it) that normal fiberglass resin has in it. When first got my hands on micro balloons back in the late 70s, that is what was recommended. Have not used them since early 80s as I got out for quite a few years.
Ron
RonR214 is online now Find More Posts by RonR214
Old Oct 03, 2009, 06:14 PM
antstoes is offline
antstoes's Avatar
Shelbyville, KY
Joined Apr 2009
Finishing resin
Ron,
Thanks, I tried regular 30 min epoxie, then I found out about Finishing Resin. I needed some anyway to use with fiberglass cloth.
I use quite about of microballons in it and that worked pretty well. Then what I did was used balsa filler to make sure everything was smooth and looked the way I wanted it to. Then I took just the resin and hardner and painted a thin coat on top of the balsa filler. Then covered it with monokote. Came out very well, but of course we always want the monokote to come out looking perfect with NO wrinkles, but it never does.
Thanks a bunch for your reply.
Ken
Question How to use a switch on Futaba tx to set up-trim for takeoff? Danny Troy Radios 8 Jun 16, 2007 11:35 PM
Discussion How to keep plans on foam? Basic questions. xray328 Foamies (Kits) 6 Jun 19, 2006 11:25 AM
How to use spoilers on a GL? big3dan Thermal 11 Apr 10, 2005 08:08 AM
Question How to fix a dent on foam? temp_oct Parkflyers 10 Nov 12, 2003 01:24 AM
What do you use for an end insulator on a foam cutter? AW Power Systems 8 Jun 20, 2001 11:49 PM
