In the case of your electric setup, you *also* need to remove the positive (+) wire from the ESC servo plug connection. You can snip this, or, if you are careful you could pop the little plastic holder and pull out the little connector and then wrap it in electrical tape to isolate it so that you could switch back at a later time. Quote:
In a plane with a seperate battery for the servos the battery powers them and then the ESC has no power effect to the servos or receiver. Why don't you give us a bit more details on your Crys. What is motor, ESC, battery, type and number of servos? Ryan |
Latest blog entry: May 2013 US F3B Team Practice contest
I use the BEC from the ESC to operate the rx and servos on 3 channel gliders or less. Anything more and I use a seperate battery. OR, if for whatever reason I feel the setup pulls enough current that it would heat up the ESC. I don't think you have to worry about the lipo pack running down. Really, in my experience you have a pretty good idea anyway the battery is getting low when the last climb is pretty weak. That, and with lipos you don't want to run them low anyways to risk damaging them, so you tend to be even more careful. The worry is that somehow the circuit that drops the voltage down from 10 volts to 5 volts will get overheated and crap out on you. I think you should be OK on the 2 servos (or possibly even 3) and using the BEC. Especially if you have experience running those servos in a "power plane" with this same ESC/battery/motor (probably not same prop). I have 3 servos in my Allegro Lite and run it off the Jeti brushed ESC's BEC. Of course, I have never ran a 3S setup, so that makes it a bit worse (a bigger voltage to have to drop). Ryan |
| Thread Tools | |
| Discussion BEC vs separate battery for receiver | BoneDoc | Giant Electric Planes | 133 | Nov 24, 2008 09:40 AM |
| Discussion Help with ESC, Servo & Battery for Balsa 3D | Porcupine | 3D Flying | 3 | Aug 22, 2007 11:21 AM |
| separate BEC for retract servo? | hul | DIY Electronics | 2 | Apr 09, 2005 02:29 AM |
| ESC & Battery for SS | PCola-Flyer | Beginner Training Area (Aircraft-Electric) | 5 | May 22, 2003 07:01 PM |
| Separate battery for a retract servo? How? | tim hooper | Electric Plane Talk | 17 | May 05, 2003 06:15 PM |
