Old Feb 02, 2006, 02:24 AM
Koen Van Goethem is offline
Find More Posts by Koen Van Goethem
Brussels,Belgium
Joined Feb 2000
Question
AXI 2808/20 rewind
Hi ,
since months , i'm busy in repairing an AXI 2808/20
I've forgotten to shoot some pictures before removing the wiring.
has someone some pictures from the stator with windings .
I've allready tried some winding , eg: 8x 0.2mm but with 20 windings , the tooth is not completely filled .
anyone some idees on what is original used ?
regards,
Koen
Koen Van Goethem is offline Find More Posts by Koen Van Goethem
Old Feb 02, 2006, 09:09 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Goedendag Koen. We need to know the number of statorpoles (teeth) and the number of magnetpoles to figure out what winding diagram to use. I don't know the original number of winds
Rewinding AXI's
http://www.rcgroups.com/forums/showthread.php?t=404857
http://www.rcgroups.com/forums/showthread.php?t=397069
http://www.rcgroups.com/forums/showthread.php?t=387166
http://www.rcgroups.com/forums/showthread.php?t=259994
Do-it-yourself motor homepages, manuals/tutorials, checks and tests in the first message of this motor builders tips and tricks thread. The checks and tests may save you from frying your controller or motor. Thread is active, bookmark it for future refence and subscribe to it:
http://www.rcgroups.com/forums/showthread.php?t=240993
Vriendelijke groeten Ron
int. E fly-in & diy outrunner meet, June 25 2006, Nijmegen, the Netherlands
diy outrunner discussion group
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Feb 02, 2006, 11:19 AM
latrans is offline
Find More Posts by latrans
Joined Aug 2004
Koen,
You're in luck, I have been working on a building a similar motor out random computer junk (almost done and build thread to come if anyone is interested). That motor is wound with 20t in the distributed LRK scheme connected delta. This means that each arm with 10t of whatever the largest wire will fit, I'd try 22g.
Hope that helps.
Latrans
latrans is offline Find More Posts by latrans
Old Feb 02, 2006, 01:20 PM
Joined Feb 2001
LRK or distributed lrk only for 12teeth and 10 or 14magnetpoles. I think al AXI's have this but I'm not sure.
Old Feb 02, 2006, 01:31 PM
latrans is offline
Joined Aug 2004
Ron,
The 2808 is 12N14P D-LRK.
Old Feb 03, 2006, 08:38 AM
Brussels,Belgium
Joined Feb 2000
thanks guys , thanks Ron
it has indeed an 12 tooth stator and 14 magnets , and as i remember , there are only 6 tooths used .
to be shure , i wanted to see some photo's .(i've really be stupid in not shooting some pictures with 2 digital cams in house , shame on me )
before I started on removing the existing wire , I had desoldered the original connecting wires , in order to have access to the multiple strains in the winding .
On my notes , I have 8 time 0.2mm diam wire , but when I try this , I have only filled halve the space around the tooth and the teeth aside . in the 6 tooth winding scheme
regards
Koen
Old Feb 03, 2006, 09:58 AM
Joined Feb 2001
So 8 winds, not 2 winds & 4 parallel or 4winds & 2 wires in parallel?
Or 8 parallel strands, number of winds unknown?
Prettig weekend Ron
Old Feb 05, 2006, 03:55 AM
Brussels,Belgium
Joined Feb 2000
Ron , I mean 8 parallel wires with 0.2mm diam
for the moment , i've tried these 8 // with 12 Turns/tooth in distributed LRK .
question , has anyone a splendid idea how to temporarely fix the stator to the motormount , and to keep it easy to remove ?
I want this in order to make a testrun , and if i want, to go for another rewind.
I'll send a picture of the wound stator tomorrow.
regards and a good Weekend to you all .
Koen
Old Feb 06, 2006, 01:50 AM
Brussels,Belgium
Joined Feb 2000
Do i need to use more copper ?
I've made a testrun yesterday .
The stator was held by the wires .
It runs smoothly !
this week I'll try to make a testbench.
question : how to determine Ri ?
what I've done:
I 've put a known DC voltage on 2 wires and measured the drawn current .
U/I= R and voila : around 250mOhm .
compared with the specs from axi :
2808/16 : 90mOhm
2808/20 : 125mOhm
regards
Koen
Old Feb 06, 2006, 12:49 PM
Joined Feb 2001
With hindsight, you could have used thicker wire, there's room for it.
Keep in mind, there are twho kinds of resistance, the actual resistance per phase and the resistance/parameter Rm that is used to model electric motors: rpm = Kv * (V-(I-Io)*Rm), Pout = (I-Io)(V-IRm)
Old Feb 08, 2006, 01:48 PM
George Shering is online now
Find More Posts by George Shering
Scotland
Joined May 2005
My 2808s have all teeth wound
George Shering is online now Find More Posts by George Shering
Old Feb 14, 2006, 11:08 AM
Brussels,Belgium
Joined Feb 2000
did some testing with the stator kept in place to the motormount with some copper wire .
The original propeller from the easyglider is easily turned around .
now i'm going to try an 12 x 7 with some extra windings added to the stator
keep you posted
regards
Koen VG
Axi 2808-20 on 10 cells? byoung Power Systems 6 Jul 22, 2003 09:07 PM
AXI 2808/20 dimensions rclark Power Systems 2 Jul 07, 2003 11:50 AM
Mega 16/15/8 or AXI 2808/20 ? Carl K Power Systems 8 Jun 08, 2003 12:32 PM
AXI 2808-20 in Switchback or Dandy Sport steveo64 Power Systems 8 May 20, 2003 12:33 PM
Which prop for Axi 2808/20 on 8 cells? Bigfoot Sport Planes 1 Jan 13, 2003 11:10 AM
