Old Feb 01, 2006, 01:44 PM
JayJay76 is offline
Find More Posts by JayJay76
JayJay76's Avatar
United States, IL, Chgo
Build Log
Sperry Messenger build from free MAN plans
Hey I just got my April issue of Model Airplane News yesterday, and it has a write up on a micro (13" span) Sperry Messenger with free online plans.
I am just finishing up another project and I have been hankering for a ~35" span biplane with simple lines and lots of character, it looks like MAN was reading my mind! The April issue is not yet up on the MAN site, but when is is available I plan to blow them up and start building a foam model based on this simple, all sheet balsa design. And I *plan* to document the build right here. Attached are a few photos and line drawings I found on the web, and the link is to a thread on John Blankenship's 30" span all balsa messenger.
http://www.rcgroups.com/forums/showthread.php?t=274972
JayJay76 is offline Find More Posts by JayJay76
Old Feb 02, 2006, 01:56 PM
JayJay76 is offline
JayJay76's Avatar
Okay the April issue is finally up on Modelairplanenews.com but the 'click trip' or whatever that has the free plan is still not up. I'm very eager to get my hands on that plan so I can begin a redesign for 6mm "C" foam. The wide, rectangular undercambered wings should make this a real floaty bipe. I'm planning on using streamlined aluminum tube over a CF rod stiffener for the struts because in this particular model they have to handle both tension and compression loads.
Old Feb 03, 2006, 09:22 AM
JayJay76 is offline
JayJay76's Avatar
With a little advice I am almost done with the first draft of the adapted plan. Here is a screenshot of the plan so far. Relative to the horizontal stab, the motor has 2 drg down thrust, the lower wing has 2 degrees positive incidence, and the upper wing has 3 degrees positive incidence.
Old Feb 04, 2006, 02:04 PM
JayJay76 is offline
JayJay76's Avatar
Cool Anyone build a CNC Router from Hobby CNC plans? corey The Builders Workshop 0 Jan 23, 2005 02:52 PM
Free 3D Plans...Build One, Try It!!! Boss248 3D Flying 10 Nov 11, 2004 08:25 PM
Kits from free plans ? steve lewin Electric Plane Talk 18 Nov 25, 2003 07:37 PM
NEWBIES...Easy Build and Fly...Free Plans... gpw Foamies (Kits) 93 Apr 30, 2003 06:36 PM
RCM&E TUCANO, build from kit or plans? kartman24 Electric Plane Talk 1 Nov 19, 2002 06:10 PM
