Old Jan 31, 2006, 08:57 PM
funkyflyer is offline
Find More Posts by funkyflyer
ProBro #388
funkyflyer's Avatar
United States, IN, Griffith
Joined Apr 2003
Trex 450xl w/hs-56 problem
I just got a Trex 450xl, and am using Hitec HS-56HB servos. The problem I am having is the servo arm is big time interfering with the canopy. Even if I use the first hole, It will rub. Am I doing something wrong?
funkyflyer is offline Find More Posts by funkyflyer
Old Jan 31, 2006, 09:16 PM
Greybird is offline
Find More Posts by Greybird
Greybird's Avatar
Florida
Joined Nov 2004
Use the smaller arm that comes with the 56. Keep the ball on the inside like you have it. Mount the servo from the inside with a spacer to position the servo where it would be if the 56 had normal mounting tabs. Mine does not rub at all.
Greybird is offline Find More Posts by Greybird
Old Jan 31, 2006, 09:33 PM
Greybird is offline
Greybird's Avatar
Florida
Joined Nov 2004
Look at the spacer on the servo. Also a picture of the servo arm. The canopy is before and after mounting servo inside with spacer. Hope this helps.
Old Jan 31, 2006, 09:56 PM
skip63 is online now
Find More Posts by skip63
Phoenix, Arizona
Joined Jan 2005
I didnt want to make my servo arms smaller so I just did this. I think if you reduce your servo length you loose alot of performance. I wish the folks who make the canopys would let us decide on where the mounting holes should go. Anyway my servo arms are not rubbing anymore. I have seen pics of those who mount the servo upside down with a larger arm.
skip63 is online now Find More Posts by skip63
For Sale trex parting out hs 56 servos align motor cc speed control and kit kogibankole Aircraft - Electric - Helis (FS/W) 5 Dec 04, 2006 09:39 PM
For Sale Trex 450XL W/servos deeejay Aircraft - Electric - Helis (FS/W) 3 Aug 31, 2006 09:22 PM
For Sale ALL SOLD. Trex carbon frame, HS-56, HS-55, HS-50 servos thematrixz Aircraft - Electric - Helis (FS/W) 0 Jul 20, 2006 05:30 AM
For Sale trex with aon and hs 56 servos kogibankole Aircraft - Electric - Helis (FS/W) 3 Jul 09, 2006 05:51 PM
Sold F/S Brand New Trex XL CCPM /Astro 803T/CC35/ SAB 320/HS-56. epc2 Aircraft - Electric - Helis (FS/W) 3 Sep 29, 2005 07:32 AM
