Old Jun 15, 2002, 03:09 PM
Al P is offline
Find More Posts by Al P
small electrics r BIG FUN
Iowa
Joined Aug 2000
APC 5.5x4.5 or Master Airscrew 5.5x4.5 ?
Wondering if there is a better prop for my 6v Simple 400 and 9x1000 Nimh. The MA seems to be better in the air than a Graupner 5x5 . I've heard good things about APC props.
I do more more cruising around and low fast passes than aerobatics. Anyone flown both ?
Which is faster ?
Al
Al P is offline Find More Posts by Al P
Old Jun 15, 2002, 09:08 PM
Mitch G is offline
Find More Posts by Mitch G
Mitch G's Avatar
Naperville, IL USA
Joined Nov 2000
The APC prop is a bit faster. But, it's also twice as expensive as the MAS. So, with belly landers which inevitably break the occasional prop, I don't think they are worth the extra money.
Mitch
Mitch G is offline Find More Posts by Mitch G
Old Jun 16, 2002, 11:00 AM
Greg Covey is offline
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
I have all 3 of the 5.5x4.5 props:[list=1][*]Master Air Screw[*]APC[*]Graupner CAM Speed[/list=1]
They are list in ascending order of hardness, price, and performance.
Greg Covey is offline Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old Jun 16, 2002, 11:09 AM
downeym is offline
Find More Posts by downeym
Electric Addict
downeym's Avatar
United States, GA, Atlanta
Joined Apr 2002
does that mean all things being equal you like the Graupner CAM Speed prop? can you explain why? More speed? More thrust? More duration? Stiffer? please expound on this.
I have only tried teh APC and It seems to be a better than the stock spoons or the carbon 5x5 props I have tried. I would like to know if you have found something better
downeym is offline Find More Posts by downeym
Old Jun 22, 2002, 06:15 PM
Flying Cat is offline
Find More Posts by Flying Cat
Flying Cat's Avatar
Cary, NC
Joined Jan 2002
This morning I tested two APC propellers and the Graupner 4.75 x 4.75 in my Python. The APC propellers were the 4.75 x 4.75, and the 5.5 x 4.5.
I was disapointed with the APC 5.25 x 4.5, the plane was slugish and quite slower than with either of the 4.75 x 4.75 props.
When I tested the Graupner 4.75 x 4.75, the plane was not as fast as with the APC 4.75 x 4.75.
Conclusion: If you want speed and performance, the APC 4.75 x 4.75 is the best of the three I tested.
Enjoy!
Flying Cat is offline Find More Posts by Flying Cat
Question APC or Master Airscrew - who has the better 3-blade prop? gromitvt10 Electric Plane Talk 5 Aug 30, 2006 11:33 AM
FS:Graupner Precision spinner 30mm/Cam speed prop 5,5X4,3 DesertRC Aircraft - Electric - Airplanes (FS/W) 2 Jul 05, 2002 09:22 PM
Twinjet + 2xB40 S12 + CAM 5.5x4.3 RPL Foamies (Kits) 16 Jan 05, 2002 04:07 PM
MAS 5.5x4.5 for Twinjet RPL Foamies (Kits) 4 Nov 19, 2001 09:42 AM
Master Airscrew 5.5x4.5 prop upgrade for Zagi 400X 177ichael Foamies (Kits) 9 Jun 19, 2001 09:16 AM
