Old Jan 30, 2006, 05:25 PM
INVERTED39 is offline
Find More Posts by INVERTED39
INVERTED39's Avatar
Joined Nov 2005
moutain models dl50 trim problem
just maidened my dl50 today. trimmed it out so that my launches and
normal flying were nice and straight. probally getting 80-90 ft launches. problem... there is about 1/2 inch of right rudder to get it to fly this way. is there something i need to do so that my rudder is straight for flying? any help would be appreciated. thanks
INVERTED39 is offline Find More Posts by INVERTED39
Old Jan 31, 2006, 12:49 AM
noishi is offline
Find More Posts by noishi
noishi's Avatar
United States, CA, Long Beach
Joined Oct 2003
hey first post? let me be the first to say welcome to to the forums! try measuring the distance from the TE wingtip to the tip of the elevator and make sure its the same on both sides. is the vert stab aligned with the wing? how does it fly when you just hand launch it verses a discus? im sure you can figure out your problem here, the guys here are a great help.
noishi is offline Find More Posts by noishi
Old Jan 31, 2006, 08:45 AM
CoClimber is offline
Find More Posts by CoClimber
Mountain Models Wannabe
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
You may also have a warped wing. See if you can sight the wings from about 3-5' in front of the plane. You can fix a warp by GENTLY heating the wing and holding a twist. Go very slowly, only doing a little at a time.
Doug
CoClimber is offline Find More Posts by CoClimber
Old Jan 31, 2006, 08:49 AM
INVERTED39's Avatar
Joined Nov 2005
trim problem
i did measure the distance from the TE to the elevator corners, almost dead on maybe a 1/16 inch difference. i'll check for wing warp next.thanks for your input
FS: Molt Models Hellcat + trim Trikster Aircraft - Electric - Airplanes (FS/W) 6 Oct 07, 2003 12:51 PM
COG problem or Trim problem? Newberry Beginner Training Area (Aircraft-Electric) 31 Aug 19, 2003 11:47 AM
Moutain Models question DIAMONDBACK Parkflyers 26 Aug 17, 2003 08:03 AM
Alfa Models P-51 problem Mcalliater Electric Plane Talk 21 May 30, 2003 06:30 AM
SB Trim Problem Tim K Parkflyers 20 Jun 07, 2002 10:58 AM
