Espritmodel.com Heli Air
Old Jan 30, 2006, 08:58 AM
Estonia
Joined Sep 2005
Trainer one with X-twin electronics
Made the fuselage out of 6mm epp.
Used the trainer one plans for fuselage and stabs, got the wing off from some cheap rubber powered glider.
AUW with electronics is 22g, cant tell the other dimensions , except that the plan was on 1 A4 sheet.
Trimmed down the horizontal stabilizer a bit to make sharper turns. The thing doesn't handle wind very well, but indoors flys like a bird
only problem is that when turning, the plane tends to lose altitude a bit
The window tape is for rx covering and used for repairs :P
It's because of a hangar rash called "my sisters cat" And the plane has had some bumps to walls and concrete still flies
tann200 is offline Find More Posts by tann200
Old Jan 30, 2006, 11:57 AM
Estonia
Joined Sep 2005
perhaps this post could be moved to x-twin mods section?
Old Aug 29, 2007, 08:48 AM
gpw
“There’s no place like Foam”
gpw's Avatar
Joined Jul 2002
Tann, that looks GREAT !!!! Maybe a bit noseheavy why it's losing altitude in the turns ...or making the turns too steep ...??? what's X twin electronics ???
gpw is offline Find More Posts by gpw
Old Aug 29, 2007, 09:47 AM
WHERE'S THAT STUPID PART!
dill's Avatar
United States, MA
Joined Dec 2006
Xtwin=Aeroace
dill is offline Find More Posts by dill
Question two act setup with x-twin guts? Cuddles Indoor and Micro Models 3 Feb 23, 2007 04:52 AM
Idea why is nobody building x-twin electronics in existing/kit planes !@#$%^&*(!) Micro RTF 0 Dec 23, 2006 11:41 AM
Yippee! 4x4m flight with x-twin bubbe Micro RTF 1 Oct 19, 2006 07:28 AM
Discussion problems with one motor on x-twin bubbe Micro RTF 8 Oct 03, 2006 03:23 PM
Discussion Building new planes with X-Twin rcstunt101 Indoor and Micro Models 0 May 08, 2006 01:09 AM
