Old Jun 14, 2002, 07:25 PM
mike93 is offline
Find More Posts by mike93
Santa Barbara/Roseville, California
Joined Dec 2001
Please help me with my zero throttle respone from my Futba Skysport Radio
O.K., I have a conversion American Airlines plane that I am builing. 2x EDF-50 in parallel, worked before, now zero throttle respones.
Setup:
Bench Testing with ICS-50(Checked to see if it was toasted because of amp draw, not the problem, works on mini max with different radio)
Futaba 4channel Skysport Radio T, E,R A:everything works except the throttle. I have zero response with the above radio, even after checking other crystals. I then tried Futaba radio in the mini max with the same ESC as above and again same response NO THROTTLE. Tried out my
Hi-tec Focus III radio with same ESC in the mini max and it worked!! Then I tried one EDF-50 with Hitec 3 channel radio with same (ICS-50) ESC, and that worked perfect.
I then tested the Futaba Radio with the same ESC, in the same setup as the Focus III: No throttle response, but servo control is good. I had both motors working fine earlier, and then ran out of battery power, thought that I burned up the ESC, but it still works.
Is it possible to damage the radio in any way?? I tried another servo on the rudder/Throttle stick on the Futaba radio, and again no throttle, but rudder control worked.
I am running out of possibilities, please help me because I don't have to tools or the experience neccessary to figure this out on my own.
Thank you for your help,
Michael Arnoult
mike93 is offline Find More Posts by mike93
Old Jun 14, 2002, 07:27 PM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Does the Futaba have servo reversing? If so, try reversing the throttle channel.
BC
Basketcase is offline Find More Posts by Basketcase
Old Jun 14, 2002, 07:40 PM
mike93 is offline
Joined Dec 2001
Tried it?
I have tried it, but I will try it again. I just tried out the Futab Radio on my GWS 2 amp ESC, and Direct Drive Motor, and it would not respond. I am really conserned that it may be the radio, BUT HOW?!?!?!?
any more advice, please help!!
Old Jun 14, 2002, 08:27 PM
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Re: Please help me with my zero throttle respone from my Futba Skysport Radio
Hi Mike, are you using the same receiver in both examples above? Are you also saying that when a servo is plugged into the receiver channel that you still get no movement? Or does the servo work?
I think you've proven it's not the speed control, if all the other channels work and just the throttle is out I'm lost.
BC
Old Jun 14, 2002, 09:43 PM
mike93 is offline
Joined Dec 2001
Problem solved. I am not sure how I did it, but after re thinking everything and trying it all again (close to 2 hours of rethinking) I fixed the problem. Everything works now.
Thanks for your advice,
Old Jun 14, 2002, 09:45 PM
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Glad to hear you got it going, that's all that counts.
Have fun,
BC
Please help me with my gobrushless DIY kit EddieNewYork Power Systems 14 Jun 18, 2004 08:00 AM
please help me with my little HB!! birdie_in_texas Micro Helis 19 Jun 03, 2004 12:47 PM
Question Please help me with my kyosho megaforce MEGAFORCE Off-road Cars 0 Sep 06, 2003 08:51 AM
PLEASE Help me with my zero throttle response on my radio!!! (Please read) mike93 Electric Ducted Fan Jet Talk 2 Jun 14, 2002 07:52 PM
