Old Jun 14, 2002, 09:37 AM
GKurt is offline
Find More Posts by GKurt
Chicago
Joined May 2002
Building sub-c battery packs
What's the concensus on building sub-c battery packs, sticks or side-by-side? Any faq's out there?
It seems building sticks would be easier with the right tools (correct soldering iron tip, and a groved chunk of wood to line them up). Since sticks have less parts, there should be (theoretically) less resistance. Cheaper to build with less bars to buy.
OTOH, side-by-side has the advantage of being able to easily identify and replace a bad cell.
I have a couple DeWalt 12 cell packs purchased from Nicdlady.com and plan to use the cells to build a couple 10 or 12 cell packs as an experiment. I was thinking of getting a new tip for my Weller soldering gun and filing the sides of the tip flat so it'll heat two batteries at once (if I build them as sticks). Is there a preferred, lower resistance/stronger solder (silver perhaps)?
I have shrink wrap but it seems as if clear package tape, carefully applied would work. Or the new Saran Wrap style of stretchy plastic wrap would work fine too.
GKurt is offline Find More Posts by GKurt
Old Jun 14, 2002, 01:47 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Don't know if you tried the search yet, but there is lots of info on building packs out there. Try the Open and Science forums too.
Shrinkwrap is the best. It helps to hold the cells together better.
You can get a special tip for the weller 40 watt iron to make cells from Hobby Lobby. Just use regular solder.
Building packs does take a knack, so try with older cells a few times beefoore you hit the biig ones!
Fred Bronk is offline Find More Posts by Fred Bronk
Old Jun 14, 2002, 02:24 PM
Ben74 is offline
Find More Posts by Ben74
Ben74's Avatar
San Francisco, CA, USA
Joined Jun 2001
side by side is way easier, IMO. i glue the cells together with Goop, then solder strips of copper braid (aka solder wick) across the terminals. the copper braid is a great conductor, and is very easy to work with.
Ben74 is offline Find More Posts by Ben74
Old Jun 14, 2002, 04:48 PM
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Side by side has good and bad tradeoffs, just like end to end.
Old Jun 15, 2002, 12:15 AM
pwkpete is offline
Find More Posts by pwkpete
ElektroRC.com - MSH,LAHeli,YGE
Pewaukee, WI, USA
Joined Mar 2002
I used to build my RC car packs. Now I build both my 8 cell flat packs for the Piccolos and the standard pack for the Hornet. But for my "big" (12 cell Logo) packs, I use the MEC solderless tubes. They cost 20 / pack (sub-c) but work awesome and thats a 1 time cost. For that price, I could never see messing with soldering these types of inline packs... (Thats just IMHO though )
If they were side-by-side though, I'd build them myself, those are easy...
Does your application (heli) take side-by-side or inline packs?
pwkpete is offline Find More Posts by pwkpete
Old Jun 15, 2002, 09:35 PM
ebrown is offline
Find More Posts by ebrown
DLG Addict
Peachtree City, GA
Joined Nov 2001
Where can you find the MEC tubes?
Eric
ebrown is offline Find More Posts by ebrown
Old Jun 15, 2002, 11:33 PM
pwkpete is offline
Pewaukee, WI, USA
Joined Mar 2002
http://www.modelelectronicscorp.com/spt.html
I saw their advertisement on this board. I posted a question about them, got lots of positive comments. I can see why...
Old Jun 17, 2002, 10:25 AM
GKurt is offline
Chicago
Joined May 2002
I saw the Power Tubes before, but it seemed I should just buy completed packs if it's going to cost $20 to put the individual cells together. IMHO
Last night I soldered tubes together with my Weller gun. It was very easy, once I got the hang of it. All I did was file the sides of the gun's tip to put some flat spots on it for better heat transfer. I prepared each cell, sand/flux/solder puddle, then lined them up on a grooved piece of wood clamped to the workbench. I put clear package tape on each completed stick (to insulate them from the other stick), wrapped rubber electrical tape on the ends after connecting the two sticks and wires, and covered the whole thing with clear heatshrink. I'll bet it took a lot less time than side-by-side would have taken.
Now what remains to be seen is what the DeWalt battery packs actually have in them. The cells are unmarked, except for small letters "Japan FB", and they weigh 52g. The first cycle they took just over 1800 mah, which should improve with further cycling.
In the DeWalt packs they were assembled with cardboard sleeves covering them, which I discarded in favor of clear package tape. The finished pack, with clear heatshrink over clear package tape over shiny, unmarked cells looks very cool. And the individual cells only cost $2.08/each.
Where Can Newbie Girl Buy 12-Cell 2/3 Sub-C Battery Packs? AP WannaBe Power Systems 5 Jun 17, 2004 08:26 AM
FS: Used 7 and 8 cell Sub-C battery packs Art Horne Aircraft - Electric - Airplanes (FS/W) 1 Nov 29, 2003 08:38 AM
Building my first battery packs... Gospadin Sport Planes 4 Nov 15, 2001 09:17 AM
Building In-line Battery Packs John E Power Systems 4 Oct 11, 2001 03:27 AM
Sub-C battery end caps... Where can I find them? Jonas Leander Power Systems 3 Jun 13, 2001 12:30 AM
