Old Jan 27, 2006, 11:46 AM
preston_brown is offline
Find More Posts by preston_brown
Intermediate Pilot
preston_brown's Avatar
Chapel Hill, NC
Joined Dec 2005
Question
2nd outdoor flight, helicopter caught in wind/thermal?
Hi all,
Today has been the 2nd time I've flown a helicopter outdoors. Been flying since Christmas day, I got a Lama 2, and last week I finished building up a X400. I've test flown it inside a garage about 6-7 times, and I have hover and hover movement worked out.
Everything has gone well outside, although the rate of climb on the helicopter isn't that great right now (400DH motor is probably to blame). I get about 11 minutes of flight time on a 2100mAh battery pack.
Here's the question part: As I am a beginner, I have set up a fairly conservative pitch curve, and I'm flying with a CC35 in governor mode at about 2200 RPM. My pitch curve only has a very small bit of negative pitch at the bottom, and at mid stick, already has several degrees of positive dialed in. Still, hovering doesn't occur till I'm in the top portion of the stick.
I was flying around the big back yard, doing fine, and then I decided, hey, no ceiling! Let's fly a bit higher! I ascended to approximately 30 or 40 feet. Winds are calm to very low, and today is around 45-50 degrees and sunny.
All of a sudden, there was a LOT of additional lift on the helicopter. Even pulling the throttle WAY back (but I don't think I pulled it completely) the model was still climbing. Then, after a couple of seconds all of a sudden it started dropping of course, and I had to put in lots of throttle to keep it coming down at an alarming rate. I went through this for what seemed like eternity, attempting to bring the heli down at a controlled rate, cause it was really high now, almost higher than the tallest trees in my yard, and that's pretty high. I was getting really nervous and actually thought I was going to get disoriented and stuff it.
Eventually I had it under control and got it down, at lower altitudes (like 10-15 feet) the throttle behaved as I was used to.
Did I get caught in a thermal and thus the helicopter got extra lift? Did something else happen? Clearly I think the main remedy is to dial in extra negative pitch on the bottom, I guess it is time to set up an idle-up 1 curve?
preston_brown is offline Find More Posts by preston_brown
Old Jan 27, 2006, 11:53 AM
Butuz is offline
Find More Posts by Butuz
DRAGONUS
Cardiff, Wales, UK
Joined Jan 2006
Sounds more like radio interference to me
Butuz
Butuz is offline Find More Posts by Butuz
Old Jan 27, 2006, 12:01 PM
Intermediate Pilot
Chapel Hill, NC
Joined Dec 2005
I doubt it was radio interference. I've got a Futaba 7CHP in PCM mode, talking to a R146iP receiver, and I have a noise filter between my ESC and receiver.
Motions is offline
Find More Posts by Motions
Motions's Avatar
Tallahassee, FL
Joined Nov 2005
It sounds very much like wind. Even small winds can cause a small heli to jump in altitude. You should definately be flying in idle-up and have at LEAST -5 degrees pitch. You don't want to fly at altitude you need to use idle-up because in normal you will loose head speed when you bring the throttle down.
Motions is offline Find More Posts by Motions
Old Jan 27, 2006, 12:04 PM
Intermediate Pilot
Chapel Hill, NC
Joined Dec 2005
Thanks for the confirmation of the wind theory. I guess you are right about losing head speed at the very low end in normal mode (my gov. throttle curve for normal/hover is 0 80 80 80 80).
I'll set up an idle-up with more negative pitch and constant throttle across all 5 points.
Old Jan 27, 2006, 06:29 PM
clodman13697 is offline
Find More Posts by clodman13697
Joined Jul 2005
At least you had negative pitch, my GWS Minidragonfly FP chopper goes for one heckuva rollercoaster ride when I get it up above our 2 story house. The only way to bring it down is to reduce the throttle at which point it becomes a heavy kite, soon as the wind dies or the rotor slows too much down she comes..........................and quick! Haven't stuffed it yet but I picked up an X400 for breezy days and I'll keep the lil guy for calmer stuff.
clodman13697 is offline Find More Posts by clodman13697
Old Jan 27, 2006, 07:16 PM
ukgroucho is offline
Find More Posts by ukgroucho
ukgroucho's Avatar
Stratford upon Avon
Joined Jul 2004
That should work... you also want more headspeed. 2200 is a little 'light' for dealing with windy conditions on a small rotor disk... 2400 would be better as it reduces the impact of gusts and gives you more control generally. Better to fly for 1 minute less than to heap it 'cos you don't have control.... and it may not actually reduce flight time - depends on where the BL motor is in it's efficiency curve. If 2200 is 'inefficient' then 2400 might be in the sweet spot so battery life might actually improve.
Sounds like you're doing really well! Congratulations on getting it back in one piece!
Oh, one more thought... sounds like you have tall trees around. These can cause some funky wind effects. In general the wind will be a little more as you climb from 0 to 50 or even 100 feet but big trees can add to this by causing sheltered spots - and exagerated 'high wind' areas.
My flying field (an old airfield) has a set of trees about 100 - 150 yards from the RC fly zone and if the wind is in the right direction they cause some really odd effects where we fly..
ukgroucho is offline Find More Posts by ukgroucho
Old Jan 27, 2006, 08:00 PM
Gary Hoorn is online now
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
Yes and Yes when flying outside and doing anything other than just low level hovering on calm days. If your Tx has more than 1 Idle Up postion set that up as well in case you push the switch too far in a panic! There have been Helis crashed by inadvertently switching to an Idle Up that was not configured.
Gary
Gary Hoorn is online now Find More Posts by Gary Hoorn
Old Jan 27, 2006, 08:48 PM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
That's called "rotor".
They're air eddies (not to be confused with EddieMoth or EddieNewYork) caused by wind blowing past obstacles.
We're very careful of them when paragliding.
Toshi
TMorita is offline Find More Posts by TMorita
Old Jan 27, 2006, 08:54 PM
ukgroucho's Avatar
Stratford upon Avon
Joined Jul 2004
OK Toshi.. I'm intrigued... eddies I understand but
EddieMoth?
EddieNewYork?
Old Jan 27, 2006, 08:58 PM
hueyman is offline
Find More Posts by hueyman
Joined Dec 2004
climb out rate not good? have you tried the 400dh without gov mode on your esc? I have read quite a few posts about gov. mode really decreasing the performance of the 400dh.
hueyman is offline Find More Posts by hueyman
Old Jan 27, 2006, 09:20 PM
TMorita is offline
Joined May 2002
EddieMoth?
EddieNewYork?
Yes, those are Eddies, not eddies.
Toshi
Article FMA FS8 CoPilot 2nd Generation Flight Stabilization and FailSafe Unit Helicopter Inst y_g Electric Heli Talk 16 Nov 12, 2007 10:59 AM
Discussion 2nd and 3rd flight in first aleron plane 1st and 2nd crash resullivan Beginner Training Area (Aircraft-Electric) 13 Dec 30, 2006 09:06 AM
Discussion Dragonfly caught in the wind jefkawst Micro Helis 5 Nov 30, 2006 08:42 PM
Discussion Finally! Caught in Flight LuftAdler Aerial Photography 10 May 13, 2006 07:10 AM
Second outdoor flight starts well ends in disaster HuskyD Micro Helis 3 Jun 12, 2005 05:44 PM
