Old Jun 14, 2002, 02:21 AM
Captain Carlton is offline
Find More Posts by Captain Carlton
Captain Carlton's Avatar
Fairfield, CA
Joined Apr 2002
3M Super 77
I was digging though matt's web site and saw the info on the formula change on the super 77. Bad news.
I need to snatch up a couple big cans of the old stuff. That should last me while.
Any suggestions where to look????
- Rick
Captain Carlton is offline Find More Posts by Captain Carlton
Old Jun 14, 2002, 05:48 AM
Flying Low is offline
Find More Posts by Flying Low
I ain't got it!!!
USA, SC, Spartanburg
Joined Apr 2001
Not sure where to find the old formula, but I think I remember reading something at the LHS that said there's something like the old 3-77 called 3-78. I'm going by there this afternoon and if I see it again, I'll repost later tonight. Then again, I'm sure SOMEONE here will no something about it.
Adam
Flying Low is offline Find More Posts by Flying Low
Old Jun 14, 2002, 08:08 AM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
The old 77 is getting harder and harder to find. Finding it is based on dumb luck; you might find some old cans hidden on the shelves behind the new cans. 77 is sold pretty much everywhere, but your best bet is large home improvement superstores.
mkirsch1 is offline Find More Posts by mkirsch1
Old Jun 14, 2002, 10:05 AM
Dan H. is offline
Find More Posts by Dan H.
Crashez-vous sans stress!
Dan H.'s Avatar
Chicago
Joined Nov 2001
Remember that in a pinch, you can still use the new acetone-based formula on foam if you don't spray it on the foam, but into a cup and then stir it to evaporate the acetone. Test on scrap first. (Doesn't work too well for tape prep though)
Dan H. is offline Find More Posts by Dan H.
Old Jun 14, 2002, 03:59 PM
KevinM is offline
Find More Posts by KevinM
Pro Bro # 179
KevinM's Avatar
United States, TX, Little Elm
Joined Jan 2002
Here is the reason for the change:
----Thank you for inquiring about 3M tapes, adhesives and
packaging products.
3M has made a formula change in the Super 77 to meet the new California Air Quality Management District Rule 1168.
Unfortunately, we were required to replace one of the solvents with acetone. This solvent will cavitate EPS and beadboard. The only other aerosol we have that will not cavitate the beadboard in 3M Insualtion 78 Spray Adhesive.-------
This is an email that I got from 3M today.
KevinM
KevinM is offline Find More Posts by KevinM
Old Jun 14, 2002, 04:10 PM
Dan H. is offline
Dan H.'s Avatar
Chicago
Joined Nov 2001
You can tell if you have the old formula by the first ingredient listed in the fine print. The foam-friendly version reads "cyclohexane". The new formula, "acetone".
Old Jun 14, 2002, 06:21 PM
Fairfield, CA
Joined Apr 2002
Found some Old Super 77
FYI: Home Depot in Fairfield, CA has probably 10 large spray cans of the stuff left. (After I bought 6).
I can build 3 to 4 wings with a single can, so I am in business for a while.
Hopefully, by the time I run out, someone will have figured out something else to use.
- Rick
Old Jun 14, 2002, 10:17 PM
SiRacer is offline
Find More Posts by SiRacer
So. Cali
Joined Mar 2002
I also found some at the local Tall Mouse Craft store. It is the small cans but it will do.
SiRacer is offline Find More Posts by SiRacer
Old Jun 14, 2002, 10:26 PM
Sal C is offline
Find More Posts by Sal C
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
I found some at Home Depot too. They had a bunch of it.
Sal C is offline Find More Posts by Sal C
Old Jun 15, 2002, 11:05 AM
sbledl is offline
Find More Posts by sbledl
Anaheim, Ca.
Joined Apr 2002
I have used the new formula to build some balsa sheeted foam (regular white foam) wings recently. Did some tests on pieces of scrap first. If it drips or puddles the stuff will eat right through the foam. When sprayed at the recommended distance and done carefully, there were no problems. The sprayed surface looked good and had no etching (I sprayed several light, quick coats). I made sure to let it dry long enough before assembly and my wings came out great. I definitely believe if it needs to be put on thick, put it in a container first.
sbledl is offline Find More Posts by sbledl
Old Jun 20, 2002, 09:41 PM
ramair is offline
Find More Posts by ramair
allergic to castrol oil
ontario canada
Joined Jan 2002
old //new????
hey guy how do i know if its old or new,,i just built a wing and never knew any better,,first i heard of this!!
is it only a problem in the usa???i know where there is a ton of that stuff,,,worked fine on my wing,,,may be the old stuff though???? please advise ramair
ramair is offline Find More Posts by ramair
Old Jun 20, 2002, 09:48 PM
Dan H. is offline
Dan H.'s Avatar
Chicago
Joined Nov 2001
Read the "ingredients" (contents); if the first one is "cyclohexane", you have the foam-safe formula, and if "acetone", that's the foam-nasty. But if you'd cavitated (melted) your foam you probably would have realized it already. Notice any strange flat spots or dents in the wing while you were taping? It's not a strength/adhesion issue, so I wouldn't worry about it.
I believe the formula was changed for all US markets just to meet the requirements of a California clean-air law, so I doubt 3M would keep the old formula just for N. American exports, though they probably could have.
Old Jun 21, 2002, 05:30 AM
ramair is offline
ontario canada
Joined Jan 2002
old stock
hello dan,i am wondering if they are getting rid of there old stock in canada??i walk into 3 differant stores and found the old stuff without the acetone,,,real pricey stuff though!! thanks again ramair
3M Super 77 Spray Adhesive culiv Foamies (Kits) 9 Mar 21, 2009 01:20 PM
Alert 3M Super 77 Spray Adhesive jimboyzguy The Builders Workshop 27 Apr 10, 2008 02:22 PM
New spray glue better than 3m super 77 kbstingwing Slope 10 Dec 22, 2002 12:06 AM
New 3m Super 77 SmoothSL Foamies (Kits) 32 Oct 17, 2002 06:29 PM
