Old Jan 25, 2006, 08:14 PM
yodie001 is offline
Find More Posts by yodie001
Joined Jan 2006
foam safe ca not working...need moisture???
i am building a depron model. i tried putting the first pieces together using great planes medium foam safe ca tonight and they didnt stick...not at all. i hear ca uses moisture to cure...is this correct? its very dry here now being january...do i need to moisten the joints before applying the ca?
also...what is kicker...will water so the same thing?
yodie001 is offline Find More Posts by yodie001
Old Jan 25, 2006, 08:40 PM
brodjack is offline
Find More Posts by brodjack
usual old know-it-all
Blackpool,U.K.
Joined May 2005
Get some kicker,it will dry almost instantly.Be careful though the quick drying effect can produce heat and melt foam,use sparingly.
I tried water didnt seem to work,kicker aint dear.I use the hand pressure spray one.can dip a cotton bud in for delicate work.......
brodjack is offline Find More Posts by brodjack
Old Jan 26, 2006, 09:32 PM
the-plumber is offline
Find More Posts by the-plumber
the-plumber
Joined Feb 2003
Didn't stick . . . .
Does that mean the CA did not cure, or that the CA cured but did not bond to the depron ?
If the latter, odds are good that there were fingerprints or some other oily substance on the depron.
CA doesn't like oil, so the last step before applying CA is to wipe the parts of the joint with denatured alcohol (not drug store isopropyl or 'rubbing' alcohol.
the-plumber is offline Find More Posts by the-plumber
Old Jan 27, 2006, 03:13 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Yes CA does need moisture to cure. Yes depron is often too dry to kick it off (there's always enough residual moisture in balsa but not in foams). I've had considerable success just very lightly damping the joints before gluing.
Spraying lightly with water after you've assembled it can work too. Kicker also works but be careful not all kickers are foam-safe. It would be a shame to buy that expensive foam-safe CA and then have the kicker melt your work into a puddle .
Steve
slipstick is offline Find More Posts by slipstick
Does Foam-Safe CA require kicker? MX Foamies (Kits) 12 Mar 28, 2011 05:47 AM
Careful! FOAM SAFE CA GLUE ....not so safe ! inventing_man Foamies (Kits) 15 Jul 26, 2006 10:01 PM
Question Foam Safe CA... NOT!! craab Foamies (Kits) 12 May 15, 2004 10:28 PM
Foam safe CA? Xoltri Foamies (Kits) 7 Jul 21, 2002 07:05 AM
Odourless/Foam safe CA in the UK?? j8m8l Foamies (Kits) 3 May 23, 2002 02:23 PM
