Old Feb 07, 2006, 12:02 AM
robert harik is offline
Find More Posts by robert harik
Joined Dec 2003
Most of the people converting them are using the 12 volt output( unregulated),so any load you put on it, causes the voltage to drop below a usable level. So you must put a dummy load on the 5 volt output( regulated)to keep the 12 volt output up . A couple of amps is fine( 10 -15% of the 5 volt rated output works). I use two large power resistors, but many use light bulbs.
robert harik is offline Find More Posts by robert harik
Mini-HowTo Convert a computer ATX power supply for bench work old man emu Australia 44 May 26, 2007 02:56 AM
Discussion Power Supply For Bench Testing The L Batteries and Chargers 11 Apr 04, 2007 05:43 AM
PC Power Supply For Motor Testing Tom Frank Power Systems 1 Dec 08, 2004 06:00 PM
Universal power supply for motor testing? Radiofly Power Systems 42 Mar 23, 2004 11:15 AM
Power supply for bench testing Phoenix controllers rakm Castle Creations 5 Mar 10, 2004 10:33 PM
