Old Jan 24, 2006, 12:40 PM
himszy is offline
Find More Posts by himszy
Scratch Builder
himszy's Avatar
Birmingham, England
Joined Sep 2004
Power Supply For Bench Testing
Hi,
As I will need to carry out extensive bench testing of my kilo, I found that I couldn't be doing with recharging my batteries all the time, so bought a ATX Computer PSU and converted it
http://wiki.ehow.com/Convert-a-Compu...b-Power-Supply
12V for TX and 5V for the RX, servos etc
Michael
himszy is offline Find More Posts by himszy
Old Jan 24, 2006, 01:19 PM
TheMetriX is offline
Find More Posts by TheMetriX
Joined Jul 2005
Nice, these power supplies are cheap and plentiful too
TheMetriX is offline Find More Posts by TheMetriX
Old Jan 24, 2006, 01:21 PM
EngineerW is offline
Find More Posts by EngineerW
Yorba Linda Ca
Joined Apr 2004
Busy Guy
Himzy,
Were'nt you building an Akula??
EngineerW is offline Find More Posts by EngineerW
Old Jan 24, 2006, 01:37 PM
himszy is offline
Scratch Builder
himszy's Avatar
Birmingham, England
Joined Sep 2004
I've got a couple of conversions to do first then I start on the Akula
Old Jan 24, 2006, 01:38 PM
himszy is offline
Scratch Builder
himszy's Avatar
Birmingham, England
Joined Sep 2004
Yup, and they have temperature, overload and short circuit protection built in.
Old Jan 24, 2006, 02:04 PM
Joined Jul 2005
Just don't zap yourself, electricity can hurt... LOL
Old Jan 24, 2006, 02:34 PM
himszy is offline
Scratch Builder
himszy's Avatar
Birmingham, England
Joined Sep 2004
lol,
Unless it's AC .................
Michael
Old Jan 24, 2006, 03:19 PM
Akula971 is offline
Find More Posts by Akula971
Is it me?
Akula971's Avatar
Perfidious Albion
Joined Jan 2005
Don't touch these power suppplies. They are switch mode supplies, and need a rated load on each output for the regulation to work. If you don't then the regulation can not often be relied upon. I design multi-output switch mode power supplies for many applications, and believe me with the high frequency ripple and poor regulation, you would be better off using a car battery. If you are not qualified, then stear clear of this type of supply!
Akula971 is offline Find More Posts by Akula971
Old Jan 24, 2006, 04:04 PM
himszy is offline
Scratch Builder
himszy's Avatar
Birmingham, England
Joined Sep 2004
Well when I run mine I stick drives on the end of them, so far so good.
Michael
Old Jan 24, 2006, 04:13 PM
Sub culture is offline
Find More Posts by Sub culture
Man from Atlantis
Sub culture's Avatar
London
Joined Nov 2003
Michael,
Man, I'm going to pull you up there. NEVER EVER joke about electricity.
It can and will kill, even small voltages can be fatal.
I'd go looking for a good linear regulated supply at a HAM radio show. You can pick them up very cheaply if you know what you're looking for, and they're a lot more dependable than switch-mode supplies IMHO.
Andy
Sub culture is offline Find More Posts by Sub culture
Old Jan 24, 2006, 04:49 PM
Akula971 is offline
Is it me?
Akula971's Avatar
Perfidious Albion
Joined Jan 2005
The other thing you have to consider about switch mode supplies is that they are designed to feed into external regulators, IC's and local smoothing caps. At power on the surge taken by these components is minimal compared to that taken by motors, which are at start up essentially inductors. When a switch mode power supply is designed, it is designed to feed a particular load, if one is designed to feed a motor then it's design is entirely different, it would have larger output caps, a different feedback loop and current sensing. If these computer supplies where the bees knees for all applications then they would be used in all applications, but they are not! they are used for PC's and PC peripherals.
Be warned, mains Kills, they also have 400vDC primaries, this can also kill! You don't get a second chance. Feel lucky punk?
Old Jan 25, 2006, 04:15 PM
himszy is offline
Scratch Builder
himszy's Avatar
Birmingham, England
Joined Sep 2004
Thanks Andy and Akula, I'll bear it in mind.
Michael
Old Feb 01, 2006, 06:01 PM
robert harik is offline
Find More Posts by robert harik
Joined Dec 2003
Do a search in the battery and charger section, alot of these have been converted to run chargers and they work well for that. I use them run my Lipoly chargers. Having said that, they dont seem to take sudden heavy loads very well(shut down), so I use a linear supply for motor testing.
There have been people describing working on them hot, without the cover!
Use common sense.
robert harik is offline Find More Posts by robert harik
Old Feb 01, 2006, 06:46 PM
Joined Jul 2005
Yes, like I said, electricity hurts. The visible damage is nothing compared to the internal damage it can cause. Be safe...
Old Feb 05, 2006, 06:42 AM
Nixie is offline
Find More Posts by Nixie
Nixie's Avatar
Joined Jan 2006
Akula971 is quite correct. Switch-mode power supplies need loads, otherwise the regulation isn't reliable. It's better to get a linear type power supply. The internals of switch-modes run at 250 volts or more too.
Nixie is offline Find More Posts by Nixie
Mini-HowTo Convert a computer ATX power supply for bench work old man emu Australia 44 May 26, 2007 02:56 AM
Discussion Power Supply For Bench Testing The L Batteries and Chargers 11 Apr 04, 2007 05:43 AM
PC Power Supply For Motor Testing Tom Frank Power Systems 1 Dec 08, 2004 06:00 PM
Universal power supply for motor testing? Radiofly Power Systems 42 Mar 23, 2004 11:15 AM
Power supply for bench testing Phoenix controllers rakm Castle Creations 5 Mar 10, 2004 10:33 PM
