Old Feb 26, 2013, 11:51 AM
Fab3105 is offline
Find More Posts by Fab3105
Joined Jun 2009
Ok Got everything balanced more or less...had to had weight in the tail as well as the rx battery..still in the max TOW!!!! Anyway.. got decals from Callie Graphics and I have been really unhappy with the purchase!! Got them in the mail box and they were soaked!! She never bothered to put them in a plastic sheet! Some of them were ruined but she completely wrong the writing and the colours for the "air Intake" "rescue" and all the transparent writing...at least the roundels and the squadron insignia were ok!
Send her an e-mail but she never even bother to answer...anyway now I need to be brave and throw this 2000$ bird up in the air....
Fab3105 is offline Find More Posts by Fab3105
Old Feb 26, 2013, 12:06 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
man, that looks awesome!!!
corsair nut is offline Find More Posts by corsair nut
Old Feb 26, 2013, 12:48 PM
Fab3105 is offline
Joined Jun 2009
Thank you! There are still a couple of details that I want to add...I will post some more pics soon with a better camera. It took me 2 years and I had to finish it after I moved back to Europe from Canada! I hope it will fly ok...I haven' t flown much since I got back!
Thanks to everyone for the help in this forum
Old Feb 26, 2013, 02:05 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
better get some stick time ,before you fly it .the best tip i can give is let it roll as long as you can ,hope you have a paved or real short grass to fly from. just dont yank it off the ground before its ready to fly .there very smooth flyers .good luck.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Feb 26, 2013, 06:22 PM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Nice job man! Looks awesome! So how much does it weigh ready to go?
bri6672 is offline Find More Posts by bri6672
Old Feb 26, 2013, 08:37 PM
jefffassbinder is online now
Find More Posts by jefffassbinder
jefffassbinder's Avatar
United States, CA, Chino Hills
Joined Jan 2011
Great job
Looks awesome. Your stabs look like there in the trim position for flight. What Rodger said let SLUF get up to speed and ROG. Should look awesome in flight.
Good luck with your maiden.
jefffassbinder is online now Find More Posts by jefffassbinder
Old Feb 27, 2013, 12:12 AM
Fab3105 is offline
Joined Jun 2009
It weights 14lbs!
Old Feb 27, 2013, 08:39 AM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Be sure to take the pylons off for the first couple flights, that will reduce weight and drag.
Keep the rudder travel really small for the first couple flights and don't commit till the wind is perfect. You'll do great! I flew mine last weekend and am loving it!
Old Feb 27, 2013, 10:26 AM
Fab3105 is offline
Joined Jun 2009
are you sure that those pylons are really so bad?
Does any one flies with the tanks underneath?
Old Feb 27, 2013, 10:41 AM
JetMang is offline
Find More Posts by JetMang
The RC Geek
JetMang's Avatar
San Diego, California, United States
Joined Feb 2002
Fab,
Nice work on the SLUF, it looks great! The pylons are fairly neutral to the airplane, but not a bad idea to work up to flying with them. They do increase the side area of the airplane which really comes into play with cross-winds, etc. Also, as Brian mentioned flying without them initially will reduce the drag, so if there are any issues that arrise on the first flight (I'm sure there won't be), you're in a cleaner aircraft configuration. My dad flew the Desert Storm A-7 with the tanks a number of times. Interestingly, on this airplane they don't change the appearance in flight hugely compared to other airplanes I've seen fly with tanks.
Good luck on the maiden! Be sure when to CG the aircraft simply by picking up the airplane by the leading edge sawtooth with your figertips. Ignore the dimension that is given in the instructions (it's not the correct dimension). Also, the starting position for neutral elevator should carry about 1-2 degrees up elevator.
Chris
JetMang is offline Find More Posts by JetMang
Old Feb 28, 2013, 12:53 PM
Lear45 is offline
Find More Posts by Lear45
Omaha, NE
Joined Jun 2004
Check out this new video of an A-7 from Florida - trim flights.
JHH A-7 Test Flights (4 min 19 sec)
Jim
Lear45 is offline Find More Posts by Lear45
Old May 13, 2013, 01:13 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Found a video of mine flying from a couple months ago.
Ran out of room on the video so I didnt get the landing. (sorry about the gas plane running in the back ground.....)
Jet Hangar Hobbies A-7 With TJ-100 (2 min 24 sec)
Old May 13, 2013, 02:22 PM
Joined Jan 2011
Bri
What size packs are you running with the TJ-100? Also did you make full ducting for the 100 or is it open. Just a thought. I have mine and would like to fly it more than I do now. I have a 100 ready to put into action so just wondering how you mounted things. Looks good and the performance seemed great. Those gasser man, I'm trying to hear my fan. LOL.
Old May 13, 2013, 02:38 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Jeff,
I am using tams ducting and 4000mah packs, The flights are not that long 3:30-4min but it flys good at this weight and I normally accomplish want I want with this model in that time frame, I can post some pics for you when I get home. I would like to experiment with a gyro on it, I know that Neil put a gyro on his a few years ago and he said it helped it track better in the wind.
Old May 13, 2013, 04:55 PM
Rangerfan is offline
Find More Posts by Rangerfan
Rangerfan's Avatar
United States, TX, Grapevine
Joined Jul 2012
Does anyone know where to get an ARF? I had emailed JHH and they said it would be unlikely they would be able to get any more from China.
Rangerfan is offline Find More Posts by Rangerfan
Site Sponsor
Video Jet Hangar Hobbies A-7 ARF E-Turbax Las Vegas Ed Waldrep Electric Plane Talk 0 Jul 03, 2007 12:00 PM
For Sale NIB F-14 EDF KIT Jet Hanger Hobbies FAA Aircraft - Electric - Airplanes (FS/W) 3 Jan 06, 2006 03:53 PM
For Sale Twin EDF F-14 Jet Hanger Hobbies FAA Aircraft - Electric - Airplanes (FS/W) 1 Oct 28, 2005 11:50 AM
Jet hanger hobbies smooth6x6 Aircraft - Fuel - Airplanes (FS/W) 6 Jan 30, 2005 11:55 AM
Jet Hanger Hobbies F-14 build thread? speleopower Electric Ducted Fan Jet Talk 14 Jul 23, 2004 03:48 AM
