Old Nov 26, 2012, 01:13 PM
A10pilot is offline
Find More Posts by A10pilot
A10pilot's Avatar
United States, TX, Seguin
Joined Mar 2006
Brian:
Really nice looking plane. Nice runway also.
Ed
A10pilot is offline Find More Posts by A10pilot
Old Nov 26, 2012, 03:34 PM
Sluf7 is offline
Find More Posts by Sluf7
Sluf7's Avatar
New Zealand, Taranaki, Midhirst
Joined Feb 1999
Outstanding !!!!!!!!!!!
Nothing like a SLUF in the Groove. :d
Great job on her mate. :d
Sluf7 is offline Find More Posts by Sluf7
Old Nov 26, 2012, 06:29 PM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Thanks Guys, its been a fun project! I am on to the scale details now but I should have her all done up in a couple weeks and I will post the finished product! I will try to get some video soon as well.
bri6672 is offline Find More Posts by bri6672
Old Feb 05, 2013, 09:15 AM
Fab3105 is offline
Find More Posts by Fab3105
Joined Jun 2009
Nearly 2 years since i bought this kit and after a move back to europe i am nearly ready...
Need to buy some decals and adjust the landing gears door
I a couple of weeks i should be airborne I will post some pics later
Fab3105 is offline Find More Posts by Fab3105
Old Feb 05, 2013, 09:19 AM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Nice!! I have some video of mine just need to get around to posting it.
I would set the rudder up with little to no throw for the first couple flights, be sure the nose gear is on a seperate channel than the rudder.
Old Feb 06, 2013, 02:24 PM
Fab3105 is offline
Joined Jun 2009
uhh i followed the instructions and i put them on the same channel!
still having some troubles with the doors...
thanks for the tip
Old Feb 06, 2013, 03:23 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Well change it. It is always a good idea to have the nose gear on a separate channel for trimming and travel adjustments.
The reason this is so important on this model is the rudder does not respond the way it does on other models. It will create roll in addition to yaw. I can bet that some of the guys that crashed theirs on take off a few years ago were adding a good amount or nose gear steering on takeoff roll to keep it straight, this is adding a good amount of rudder as well, once they would lift off the rudder would then roll the plane over and result in a crash. I am only using less than a of an inch travel on the rudder. Keep in mind you don’t need rudder to fly the jet! For the first few flights keep it out of the equation and focus on flying, once you get used to it start adding in some rudder travel and experiment with it up high. The model fly’s great and looks amazing in the air!
The gear doors just take time to get setup and they are frustrating but once setup your good!
My best advice on this model is no crosswinds for the first few flights, and before you pull it off the ground make sure she is really moving out to be safe!
Old Feb 06, 2013, 03:32 PM
Mike Warren is offline
Find More Posts by Mike Warren
BOHICA!
Mike Warren's Avatar
Joined Dec 2010
+1 to the above, treat the rudder with great care......best to have nose gear steering on a separate channel for easier trimming out.
Another hint: if you see wing rocking it means you are TOO SLOW
Mike Warren is offline Find More Posts by Mike Warren
Old Feb 06, 2013, 03:49 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
One more thing, do the first few flights with out the wing pylons. I have them on mine now and they do add a good amount of drag. It dosent bother me and I love the looks of them but it requires a bit more throttle to fly. Once you feel comfortable with the jet then add them.
Old Feb 07, 2013, 09:54 AM
JetMang is offline
Find More Posts by JetMang
The RC Geek
JetMang's Avatar
San Diego, California, United States
Joined Feb 2002
Brian's recommendations are good ones. Setup the steering as you need it, but minimize the rudder surface deflection. The rudder makes the airplane do weird things if the throws are too large. Cross-winds can be tough based on the configuration of the airplane, so on the test flight, avoid a cross-wind if you can. Once the airplane is trimmed out and flying well, you can start exploring cross-wind approaches.
I've gotten to see Brian fly his SLUF a number of times and he's got his flying really well.
Chris
JetMang is offline Find More Posts by JetMang
Old Feb 14, 2013, 02:10 PM
Fab3105 is offline
Joined Jun 2009
thanks a lot guys everything is working...waiting to get the decals from callie.
However I am having some problems with the cg... lipos 2 turngy 5000mA 5s do not fit in the bulkhead and with a ICE 160 esc it is too nose heavy...
Old Feb 14, 2013, 02:57 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Can you post some pics of your layout so we can see where you put everything?
Old Feb 14, 2013, 05:28 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
brian, you bringing that puppy on sat?
corsair nut is online now Find More Posts by corsair nut
Old Feb 14, 2013, 05:44 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Yep I was planning on it, probably bring the A-7, Falcon and the Eflite F-4 with the jetfan in it.
Was wanting to have my F-15 ready but looks like its going to take another week or so before maiden.
Old Feb 15, 2013, 01:07 AM
Fab3105 is offline
Joined Jun 2009
Thanks for your help!
Here are some pictures...as you can see only one battery goes in the bulkhead and my 160A esc doesn't fit in the fusolage on top the fan. In front of the landing gear compartment i have the bottles for the brakes and the retracts. Everything is so cram!! The only space that i have left is the canopy!
Video Jet Hangar Hobbies A-7 ARF E-Turbax Las Vegas Ed Waldrep Electric Plane Talk 0 Jul 03, 2007 12:00 PM
For Sale NIB F-14 EDF KIT Jet Hanger Hobbies FAA Aircraft - Electric - Airplanes (FS/W) 3 Jan 06, 2006 03:53 PM
For Sale Twin EDF F-14 Jet Hanger Hobbies FAA Aircraft - Electric - Airplanes (FS/W) 1 Oct 28, 2005 11:50 AM
Jet hanger hobbies smooth6x6 Aircraft - Fuel - Airplanes (FS/W) 6 Jan 30, 2005 11:55 AM
Jet Hanger Hobbies F-14 build thread? speleopower Electric Ducted Fan Jet Talk 14 Jul 23, 2004 03:48 AM
