Old Apr 15, 2011, 06:04 PM
Mike Warren is offline
Find More Posts by Mike Warren
BOHICA!
Mike Warren's Avatar
Joined Dec 2010
Originally Posted by JetMang View Post
"..........(snip).........Tailormade only.has a couple and are the earlier gull grey over white schemes. Bare in mind I have not used either so cannot say regarding quality or customer service. Maybe some other could chime in about that.
Chris
I have had only one experience with AeroLoft and won't go there again. The lady can be kind of cranky to deal with if things are not exactly as she planned. Her scale was way off of being right for my JHI A-7D......
Ralf at "Tailormade Decals" is an absolute delight and does excellent and fast work. He will also quote on custom work from any color scheme and/or plastic model decal sheet.
Mike Warren is offline Find More Posts by Mike Warren
Old Apr 15, 2011, 07:48 PM
Fab3105 is offline
Find More Posts by Fab3105
Joined Jun 2009
at this stage we will see when ( if ) i get the bird! I am getting edgy
Fab3105 is offline Find More Posts by Fab3105
Old Apr 16, 2011, 08:25 AM
JLLayton is offline
Find More Posts by JLLayton
Lansing, MI
Joined May 2002
Youmight want to try Callie graphics. I have ordered twice from her and the results have been very good.
JLLayton is offline Find More Posts by JLLayton
Old Apr 16, 2011, 01:09 PM
Fab3105 is offline
Joined Jun 2009
thanks JL! i will have look
Old Apr 17, 2011, 11:32 AM
JetMang is offline
Find More Posts by JetMang
The RC Geek
JetMang's Avatar
San Diego, California, United States
Joined Feb 2002
Fab,
sent you a pm.
JetMang is offline Find More Posts by JetMang
Old Apr 17, 2011, 10:40 PM
Fab3105 is offline
Joined Jun 2009
chris i cancelled my order with mike.
sent you a private message let me know
Cheers
Old Apr 18, 2011, 08:10 AM
Fab3105 is offline
Joined Jun 2009
xxxxxxxx
Old Apr 18, 2011, 11:18 AM
JetMang is offline
The RC Geek
JetMang's Avatar
Joined Feb 2002
Did you get it worked out? If there's anything I can do to help, let me know.
Chris
Old Apr 18, 2011, 01:04 PM
Fab3105 is offline
Joined Jun 2009
may be i found a couple second hand! But USAF version. How difficult and how long does it take to convert to the navy? sent you a pm
Old Apr 20, 2011, 08:51 AM
Fab3105 is offline
Joined Jun 2009
Ok got the bird! should be shipped soon!
I was reading that the eturbax requires a lot of work to fit into it. Is that true?
I thought that this plane was designed for the eturbax. I wanted to use the 12s Any comments? Ideas?
Old Apr 20, 2011, 11:00 AM
JetMang is offline
The RC Geek
JetMang's Avatar
Joined Feb 2002
Fabio,
If you are getting the df version, then the eturbax will drop right in as is with no mods. Smaller fans will work also, but require inlet modifications (i just recently finished converting my turbine a7 over to 90mm edf). As far as battery installation, we have that shown on our website. Having convertible style batteries definitely makes it a bit easier with a 120mm in there.
I have flown this airplane with the mw44 turbine, 120mm eturbax, and most recently with our 12s90 90mm wemotec setup. They all fly well with excellent performance. The benefit of the 90 is that it is lighter and offers a little longer flight time. However, it requires a fair amount of modification including swapping out the ducting (we have a mold) if you want the most performance from it. For all out speed and performance, the 12s eturbax is hard to beat and will drop right in with no mods.
Chris
Old Apr 20, 2011, 12:18 PM
Fab3105 is offline
Joined Jun 2009
thanks chris,
I have abunch of 5s and 6s batteries , can I run the etubax 12s with a 10s i have seen on your web that everything is the same apart the motor that has a higher max rpm
Old Apr 20, 2011, 12:33 PM
BOHICA!
Joined Dec 2010
Originally Posted by Fab3105 View Post
thanks chris,
You HAVE to have a differet and higher kV motor for 10s. Can't just use the 12s and drop 2 cells and expect any usable power.
I seem to remember that JHI used a Neu1521/1.5Y for 10s
Old Apr 20, 2011, 12:41 PM
Fab3105 is offline
Joined Jun 2009
ok That's great! thanks. one guy at my club told me that i could have used both 6s or 5s with the eturbax 12s. Sounded very strange...and this is my first real edf! i am used to props...and you can't swap cell and props like that...
thanks again...
Old Apr 20, 2011, 01:16 PM
JetMang is offline
The RC Geek
JetMang's Avatar
Joined Feb 2002
Fab,
You can conceivably do that, but you won't get the rpm and performance of the 12s system (hence changing to the 1524 motor for 10s). A good compromise between the two is to only drop to 11s instead. That's a less drastic change. Keep in mind that 6s brick packs may be tough to fit. 5s bricks are a little easier to get in there. I've put them in the turtledeck area behind the canopy on the 10s a7s I've flown. These were also thinner 20c cells though. The 30c and up cells are a little fatter. Tough to determine that without having the airplane yet though.
Chris
Video Jet Hangar Hobbies A-7 ARF E-Turbax Las Vegas Ed Waldrep Electric Plane Talk 0 Jul 03, 2007 12:00 PM
For Sale NIB F-14 EDF KIT Jet Hanger Hobbies FAA Aircraft - Electric - Airplanes (FS/W) 3 Jan 06, 2006 03:53 PM
For Sale Twin EDF F-14 Jet Hanger Hobbies FAA Aircraft - Electric - Airplanes (FS/W) 1 Oct 28, 2005 11:50 AM
Jet hanger hobbies smooth6x6 Aircraft - Fuel - Airplanes (FS/W) 6 Jan 30, 2005 11:55 AM
Jet Hanger Hobbies F-14 build thread? speleopower Electric Ducted Fan Jet Talk 14 Jul 23, 2004 03:48 AM
