Old Jan 24, 2006, 11:33 AM
Speed is Life is offline
Find More Posts by Speed is Life
Speed is Life's Avatar
FREE Gene!!! Get Banned!!!
Joined Jun 2005
Jet Hanger Hobbies A-7 D/E ARF
Check this one out from the turbine guys section.
http://www.rcgroups.com/forums/showthread.php?t=469417
New use for 120mm Fan maybe.
-Mike
Speed is Life is offline Find More Posts by Speed is Life
Old Jan 24, 2006, 11:55 AM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
Depends on what it weighs, the Hawk was horribly heavy for an EDF. The fuse wasn't half bad but the wing weighed a ton. This is intended for turbine so I have to assume it'll be sturdy
Chris True is offline Find More Posts by Chris True
Old Jan 24, 2006, 01:14 PM
JetMang is online now
Find More Posts by JetMang
The RC Geek
JetMang's Avatar
San Diego, California, United States
Joined Feb 2002
Chris,
The bare airframe shown in the pictures weighs 4.4 lbs. That is with all construction completed (except paint), awaiting hardware and electronics installation.
Already it's considerably lighter than the Hawk was at this point. I think it would do well for EDF.
Chris
JetMang is online now Find More Posts by JetMang
Last edited by JetMang; Jan 26, 2006 at 03:02 PM. Reason: Added pictures...wrong weight posted
Old Jan 24, 2006, 01:53 PM
Joined Dec 1996
That's great news Chris. Give us the inlet area and exit measurement if it isn't too much trouble. For EDF just an inlet duct would be needed, maybe even just the section at the front transitioning to round - we can make up the rest easily!
Old Jan 24, 2006, 02:43 PM
Ken Lapointe is offline
Find More Posts by Ken Lapointe
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
Dam that thing looks great.
Oh if only I had more room in the cellar
- Ken
Ken Lapointe is offline Find More Posts by Ken Lapointe
Old Jan 24, 2006, 03:29 PM
The RC Geek
JetMang's Avatar
Joined Feb 2002
Same post as in the "jets" forum.
Chris,
This design was originally built and flown for our Turbax 5" fan many years ago...and did not require an auxillary inlet. The FSA for the turbax is about 15 sq inches. I believe the inlet area is slightly less than that. The ducted fan version of the kit will have the full inlet duct to mate up to the 5" fan as well as the two piece ducted fan exhaust liner. The turbine version has the same inlet only cut back to open up for large sized fuel tanks and will not have the fibreglass exhaust liners as they are not required.
The aircraft in the pictures is essentially the first production prototype. Just requires paint and artwork which are being worked on. The models are being built using traditional build methods (ie. balsa sheeted foam cores which are then fibreglassed) which is helping to keep them light and affordable.
Chris
Old Jan 24, 2006, 04:07 PM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Chris ,
Have you started a waiting list yet?
Bob
bruff is online now Find More Posts by bruff
Old Jan 24, 2006, 05:18 PM
Joined Dec 1996
Send em an e-mail Bob, there is a contact link on www.jethangar.com on the A-7 page. Sounds like it'd make a great conversion if the weight stays under control with the production models! The inlet area is perfect.
Old Jan 24, 2006, 05:38 PM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Chris,
Thanks!
Bob
Old Jan 24, 2006, 05:49 PM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
I just put my order in for one.
Bob
Old Jan 24, 2006, 06:13 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Man that really looks good. I hope you guys have something to protect yourself against the Copy Drones.
Good luck!
Oh yeah, does it come with the main gear like the kit version did?
Kevin Cox is offline Find More Posts by Kevin Cox
Old Jan 24, 2006, 06:37 PM
Sluf7 is offline
Find More Posts by Sluf7
Sluf7's Avatar
New Zealand, Taranaki, Midhirst
Joined Feb 1999
Nothing quite like a SLUF to get ya going :0)
I'll wait for the write up's I'd have one in the Future always looked the lil Suckers.
Sluf7 is offline Find More Posts by Sluf7
Old Jan 24, 2006, 10:06 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Hi Guys, I put my name on the list at ama.I have the A7 kit but I build too slow so an arf it is.
Scott
Old Jan 24, 2006, 10:09 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
O Yea, I also picked up a set of larry and chris's mini retracts! they have out done themselfs..better than any others.
Scott
Old Jan 25, 2006, 09:58 AM
The RC Geek
JetMang's Avatar
Joined Feb 2002
Thanks guys! I am hopeful someone will do an EDF conversion of the airplane. It really should be a great performer with an EDF.
@Kevin, we are protecting ourselves as best as possible. This aircraft is being built in our own factory overseas...no more middle man. The main gear design is the same as the kit. All of the hardware will be supplied. However, we're offering the initial offering with the scale oleo struts (see picture)...the use the same hardware for retraction as the wire struts.
I've attached a couple other pictures highlighting additional detail.
Chris
Video Jet Hangar Hobbies A-7 ARF E-Turbax Las Vegas Ed Waldrep Electric Plane Talk 0 Jul 03, 2007 12:00 PM
For Sale NIB F-14 EDF KIT Jet Hanger Hobbies FAA Aircraft - Electric - Airplanes (FS/W) 3 Jan 06, 2006 03:53 PM
For Sale Twin EDF F-14 Jet Hanger Hobbies FAA Aircraft - Electric - Airplanes (FS/W) 1 Oct 28, 2005 11:50 AM
Jet hanger hobbies smooth6x6 Aircraft - Fuel - Airplanes (FS/W) 6 Jan 30, 2005 11:55 AM
Jet Hanger Hobbies F-14 build thread? speleopower Electric Ducted Fan Jet Talk 14 Jul 23, 2004 03:48 AM
