Espritmodel.com Heli Air
This thread is privately moderated by mnowell129, who may elect to delete unwanted replies.
Old Jan 27, 2010, 09:57 AM
shahrin's Avatar
Kedah, Malaysia.
Joined Feb 2007
Kaysee,
Good luck on your research and for incoming Wetland competition..
Gambar Slumberger upload tu gyro I ler tu.. Sorry..the blade was fabricated with balsa and basswood..not a heli one..
shahrin is offline Find More Posts by shahrin
Old Jan 27, 2010, 11:58 AM
kaysee's Avatar
Kuala Lumpur, Malaysia
Joined Aug 2008
thanks, so it is you with that corogyro. care to stop by the discussion to share some useful info? actually it is more because of interest in trying something new.
maybe we should take the chat via pm or pls do joint us there. so far there's only two that showing interest.
btw about my questions in my last post regarding the dual coaxial rotor on a gyro. is it gonna help in lowering the disc loading on my gyro n is there any effect that i should be aware of in using coaxial (two actually).
kaysee is offline Find More Posts by kaysee
Old Jan 27, 2010, 08:57 PM
shahrin's Avatar
Kedah, Malaysia.
Joined Feb 2007
Designing a real flying autogyro is far more difficult than what we think of. It's always better to build and fly a proven models first and be familiar with the flight characteristic before attempting to design on your own.
Depron blades has lots of drag to counter on, unless you have really light AUW aircraft. I've tried it before and failed. I'm no good in aerodynamics part but do have strong believe in following those senior's advices in this forum..
Old Apr 21, 2010, 07:54 PM
winds light to variable
Kookaburra's Avatar
Joined Apr 2009
Thanks for the introduction to the black arts of autogyros, Mickey. Very helpful.
I'll see what plans or kits are available here in Australia so I can join in.
Kookaburra is offline Find More Posts by Kookaburra
Old Apr 30, 2010, 11:01 PM
Mike Sharpe
Joined Apr 2010
I have flown helicopters when they first came out in 1969. Can I use some of my older fixed pitch rotor heads on a autogyro
divitdiger is offline Find More Posts by divitdiger
Old May 01, 2010, 01:21 PM
Joined Nov 2004
Yes. You will want to go to much bigger blades than the helicopter it came off of.
mnowell129 is offline Find More Posts by mnowell129
Old May 02, 2010, 03:12 PM
Mike Sharpe
Joined Apr 2010
Thanks Mnowell129 With a heli we set up with about 2.5 to 4 negative pitch for a autorotation .Do i need to set the rake of the main shaft back about the same as the pitch on a autogyro?
Old May 03, 2010, 07:29 AM
Joined Nov 2004
I used 18°.
Old Jun 27, 2010, 12:57 PM
Joined Jun 2010
Hello everyone! :-)
I'm new here, Bartek is my name and i'm from Poland :-)
Could You tell me what are main diffrences in calculations of "Pusher" and "puller" autogyro design???
Best regards
Bartek74
bartek74 is offline Find More Posts by bartek74
Old Sep 01, 2010, 03:34 PM
Joined Aug 2010
Sparky or Simple G plan
Hello everybody,
would somebody be so kind and send me a scan of Sparky or Simple G autogyro plan? I would buy it directly from website listed above, but shipping to my country makes the price 4 times more expensive
Thank you.
jacr is offline Find More Posts by jacr
Old Aug 23, 2011, 02:25 PM
Be here now!
ask21!'s Avatar
Rome,Ciampino
Hi!
Today, while driving my car, I was thinking a lot and now I have got a question:
Which are the differences between a nose/tail heavy aircraft and gyro?Do they have the same tendency?
Instead, speaking about the rotor, what does it change if I change its incidence?I can imagine I will have a faster or slower autogyro, but are there other things that will change?
Waiting for your answer guys!
Thanks a lot!
ask21! is offline Find More Posts by ask21!
Old Sep 18, 2011, 07:30 PM
Rumbling, bumbling, stumbling
Cincinnati, Ohio
Joined Dec 2010
mnowell129,
I'm working on a gyro head and my blades weigh about 48 pounds at 600 rrpm. How do I calculate the grip strength needed?
joe nelson is offline Find More Posts by joe nelson
Old Dec 08, 2011, 03:24 PM
United States, NY, New York
Joined Dec 2009
thanks for information. great thread
bigtruck169 is offline Find More Posts by bigtruck169
Old Jan 09, 2012, 04:49 AM
QLD Australia
Joined Oct 2009
Originally Posted by ask21! View Post
Hi!
Thanks a lot!
The main thing you will notice if a gyro is 'tail heavy' is that you will run out of foreward stick to keep it flying level[if you are lucky enough to get it level]
And vice/versa for nose heavy[you will not be able to get the nose up enough to do a good landing--it is worse at low speed]
This is assuming you fly with the moveable part of the rotor head apx square to the fixed part at the bottom[which is apx the correct position to fly at--sometimes you trim it a bit one way or the other]
M
minirotor is offline Find More Posts by minirotor
Old Mar 12, 2012, 03:38 PM
Joined Mar 2012
Book
Thanks for the post. It's a lot of information. Could you tell me if there is a book on autogiros-electric in particular.? I'm a newbie so I'm enjoying all the information I'm finding here. Thanks a lot.
Ken
planewright is offline Find More Posts by planewright
zagi advice, questions, answers easy2fly Foamies (Kits) 61 Dec 11, 2009 04:38 AM
T-rex fuselage questions and answers. darthdrk Mini Helis 9 Jul 11, 2005 04:41 PM
Tiny-X Building - Tips, Questions, Answers, and Pictures Manchild Parkflyers 264 Dec 09, 2002 08:25 PM
Tiny-X Building - Tips, Questions, Answers, and Pictures Manchild Batteries and Chargers 2 Oct 31, 2002 11:28 AM
Didel Questions and Answers Gordon Johnson Indoor and Micro Models 2 Sep 03, 2002 01:31 PM
