Go Back   RC Groups > Aircraft - Exotic and Special Interest > Auto Gyros
This thread is privately moderated by mnowell129, who may elect to delete unwanted replies.
Old Sep 06, 2008, 12:54 PM   #46
my Savage' only enemy is trees
jettrooper02's Avatar
are there any rtf gyrocopters out there other than the gyrohavoc?
jettrooper02 is offline Find More Posts by jettrooper02   Reply With Quote
Old Sep 07, 2008, 09:05 PM   #47
Not that I know of.
I have a gyro-havoc and it doesn't fly that well. I feel like it needs an elevator with some down trim. Someone in one of the forums reported that this seems to make it fly much better. That would by my suggestion. It seems to have enough power to fly well, just way out of trim.
mnowell129 is offline Find More Posts by mnowell129   Reply With Quote
Old Sep 28, 2008, 12:17 AM   #48
spitfire_Doug's Avatar
Hi Mickey
More Gyro problems. As my rotors are spinning they are very prone to flexing down and wacking the tail boom. Closer observations have shown me that it is the plastic mast inside the Heli head flexing and allowing the rotor to flex 3 inchs and hit the boom. Is this normal or is there a fault in my construction? It is a normal 4Ch fixed pitch heli head off of a Night ranger 2.
Doug
spitfire_Doug is offline Find More Posts by spitfire_Doug   Reply With Quote
Old Sep 28, 2008, 01:37 PM   #49
You need the head stiffener. Send me a private message and we'll discuss it.
Old Nov 22, 2008, 07:33 PM   #50
Time for another motto!
What would be an acceptable disk loading for a small autogyro? I did the unadvisable thing and made up my own design as I went along. The first try did not fly apart from a small hop with the rotor fully back. Now I've made some bigger and stiffer blades (I did not like the way the old ones flexed up). I've incresed the size from 70cm diameter to 84cm (33"). I suspect that this may be too much for a 4 blade weighing 300gram?
What will go wrong if my blades are too long? Will it spin up faster or slower and how will that affect flying?
JelleB is offline Find More Posts by JelleB   Reply With Quote
Old Nov 25, 2008, 10:42 AM   #51
Disk loading sounds ok for 4 blades at 33". 3.75 to 5 ounces /sq foot is a good range. Too long a blade may be to flexible and fly erratically. Spin up depends on how heavy the blades are and how efficient the blade is, etc. Too many unknowns here.
Open a new thread with some pictures of your model to get some suggestions from others.
Old Dec 05, 2008, 06:48 PM   #52
http://www.rcgroups.com/forums/showthread.php?t=963609
Hi guys check this post of mine and i wold really apreciate if somebody tell me can it work when i finaly design it. Also i want to know what you think about that way of controling heli.
Tnx
8urk3 is offline Find More Posts by 8urk3   Reply With Quote
Old Dec 09, 2008, 06:02 PM   #53
me gyro me fly plane
wildcatfan42 is offline Find More Posts by wildcatfan42   Reply With Quote
Old Dec 11, 2008, 02:29 PM   #54
Ozzie GyroNut
Hi There,
What you're asking, is the same as asking, "when I've cooked this food, will it taste good?" One will not know, till the job is done. All ideas have a chance at succeeding, all depends how well you can convert a theoretical idea into the exact practical example, without having to compromise. You are the one that will have to experiment with the mathematics, and determine if it will work. You will then have to turn it into a working example. Deciding if it will work, from just a rough drawing, that's not possible to do. Airplane flyers might say no, heli flyers might say maybe, UFO pilots might say yes.....??
HobbyCAD is offline Find More Posts by HobbyCAD   Reply With Quote
Old May 19, 2009, 11:27 AM   #55
Beginners question
Hi there.
I read this very interesting forum about auto gyros but I still have some (stupid ?) questions :
- Are there any advantages using a 2 / 3 / 4 blade rotor ?
- Did nobody try a 6 blade rotor / why ?
- there are description of selfmade blades using 3mm depron with 2mm CF support - do this blades have any profile (I could not figure out in text or pictures).
Sven
svenhb is offline Find More Posts by svenhb   Reply With Quote
Old May 31, 2009, 07:14 PM   #56
Gracias don Juan De La Cierva!
joseico90 is offline Find More Posts by joseico90   Reply With Quote
Old Jun 17, 2009, 02:49 AM   #57
Woodsy
hello gents.
can some one point me at the plans/thread for the G3PO.
or is there an easier/better gyro for a rotor wing virgin
woodsy is offline Find More Posts by woodsy   Reply With Quote
T-rex fuselage questions and answers. darthdrk Mini Helis 9 Jul 11, 2005 05:41 PM
Tiny-X Building - Tips, Questions, Answers, and Pictures Manchild Parkflyers 264 Dec 09, 2002 09:25 PM
Tiny-X Building - Tips, Questions, Answers, and Pictures Manchild Batteries and Chargers 2 Oct 31, 2002 12:28 PM
Didel Questions and Answers Gordon Johnson Indoor and Micro Models 2 Sep 03, 2002 02:31 PM
zagi advice, questions, answers easy2fly Foamies (Kits) 60 May 22, 2002 07:24 PM
Bored? Want to fight?
Join the RCGroups clan!
