Old Jan 23, 2006, 12:15 PM
fly4fun is offline
Find More Posts by fly4fun
Joined Jun 2001
Help!
Spektrum Radio Throttle Problem.
I have a new Spektrum Radio and I cannot seem to get the throttle to work correctly. The BL motor will not turn on until 1/4 way up on the stick. It makes things difficult when trying to hover without smooth throttle range on the stick. Any Ideas. Thanks.
David
fly4fun is offline Find More Posts by fly4fun
Reply With Quote  (Disabled)
Old Jan 23, 2006, 12:35 PM
martinic is offline
Find More Posts by martinic
FPV Enthusiast
martinic's Avatar
New Brunswick, Canada
Joined Nov 2004
It sounds like you may not have your throttle ATVs set up correctly for your ESC. If the ESC isn't arming until 1/4 throttle, then set your throttle stick to 0% (bottom), go to the TRV ADJ screen, scroll down to THR and adjust the - value upwards until the throttle arms (motor not spinning, but throttle armed - most will indicate arming with a light or sound). You should also set the upper limit based on your setup/preferences.
martinic is offline Find More Posts by martinic
Old Jan 23, 2006, 03:01 PM
fly4fun is offline
Joined Jun 2001
I think that is the problem. I will give it a try. Thanks Martinic.
Old Jan 25, 2006, 02:48 PM
jlachow is offline
Find More Posts by jlachow
Bridgewater, NJ
Joined Nov 2004
ATV's should be set at 100%
jlachow is offline Find More Posts by jlachow
Old Jan 29, 2006, 03:42 PM
fly4fun is offline
Joined Jun 2001
Just to follow up in my Situation is the ATV's are set to 100% as instructed. No matter what I do I cannot get a throttle response unless I have the stick 1/4 way up. My Castles BL controllers responge good at all throttle positions but this Great Planes BL ESC just isn't playing. It serves me right to go cheap.
Old Jan 29, 2006, 04:05 PM
fritzthecat is offline
Find More Posts by fritzthecat
Send Money, Women & Guns!
fritzthecat's Avatar
Virginia Beach
Joined Sep 2002
Remove main blades or setup a pitch curve with 0deg all accross. Throttle curve must be 0% on bottom, 100% on top.
Set both up and down throttle ATVs to 100%.
Plug in battery.
Arm the ESC - you don't mention what model you have so you have to figure it out yourself.
With throttle stick all the way down, reduce ATV until motor starts. Then add 5%.
Go to max throttle. Adjust ATV until rotor rpm reduces then add 5%.
The ATVs are now adjusted to your ESC.
The Castle controllers automatically adjust to your radio, the GP needs manual adjustment.
Fritz
fritzthecat is offline Find More Posts by fritzthecat
Old Jan 29, 2006, 07:40 PM
chase4556 is offline
Find More Posts by chase4556
newbie
Spring, Texas
Joined Dec 2005
mess with the throttle trim....click the button up and down...cant remember which does what. And see if that helps.
chase4556 is offline Find More Posts by chase4556
Old Jan 30, 2006, 07:59 AM
fly4fun is offline
Joined Jun 2001
Fritz I will try what you have suggested.
Chase I have messed with the Throttle trims and it get to a point where I have good throttle control but after I have to re arm the system again its messed up.
Thanks for the Help Guys.
Old Jan 31, 2006, 12:40 AM
Futurase is offline
Find More Posts by Futurase
Futurase's Avatar
Fayetteville Municipal, Arkansas, United States
Joined Sep 2004
I have a Jeti controller and it does the same thing. I just click up the trim a few times before every flight as I have been too lazy to tweak the end point. It is a SC issue as I have some high end SC's and they do not do it. My Jeti is a $200 77A controller and excellent, but does require manual adjustment.
Norman Ross Jr.
Futurase is offline Find More Posts by Futurase
Old Jan 31, 2006, 12:04 PM
fly4fun is offline
Joined Jun 2001
Fururase yes I could keep adjusting the Trim for Every flight if the End Point Adjustments doesn't work.
Let me add my E-Flite BL controllers work fine also. So no problems with Castle and Eflite controllers with the Spektrum TX.
David
Help! Problem with my Futaba Radio Throttle stick kuzko Radios 8 Jan 16, 2007 11:07 PM
pixie 20 throttle problem echoplanar Parkflyers 11 Dec 12, 2002 04:50 PM
radio glitch problem rycomm Radios 2 Aug 11, 2002 10:39 AM
Huge hitec radio range problem Thomas Manson Electric Plane Talk 10 Jun 20, 2002 08:19 PM
Sky Scooter throttle problem GooberVA Foamies (Kits) 4 Jun 02, 2002 02:49 PM
