Old Feb 02, 2006, 06:22 PM
Gary Warner is offline
Find More Posts by Gary Warner
York Electronics
Gary Warner's Avatar
Dallas Tx USA
Joined Apr 1999
Originally Posted by R/C Flier268
Gary,
I have a question though, do those numbers hold true for a ducted fan (electric) model?
Uuuuhhh... yes and no. They are correct for the true amount of 'wattage' applied in the form of thrust. Problems come into the equation because of how that wattage is used. With a much (usually) smaller 'disk' of moving air, the same wattage outputted will be at a higher efflux (higher speed of accelerated air) which will provide less static thrust, but much higher residual thrust at higher airplane speeds.
So, before your head starts to spin (mine is) these are the numbers 'I' find useful in fans.
40 watts - able to hold altitude, no climbing
80 watts - able to ROG from paved runway, mild aerobatics, speed scale like but too slow for true 'jet-jocks'
120 watts - ROG and acceleration good, aerobatics with energy management look very strong, but still not unlimited vertical, level passed look fast
160 watts - excellent climb rate (over scale in most cases), climbs at least 'look' vertical with a climb rate slash eye sight range limited to just a few seconds.
180+ watts - quickly moving up to unlimited vertical performance, vertical climbs are awesome and level passes look like you have your hair on fire!!!
Again, these are just guides. I fans, high speed drag and wing loading can skew these performance numbers significantly. And, remember these are motor output watts, not motor input watts.
Ask the same question in the e-fan forum for some other opinions about this stuff. I've hung out there enough to know (for most jet-jocks), flying anything under 100 watts per pound isn't worth the effort to build.
Gary
Gary Warner is offline Find More Posts by Gary Warner
Old Feb 10, 2006, 01:06 PM
SQUARE ROOT is offline
Find More Posts by SQUARE ROOT
SQUARE ROOT's Avatar
San Diego, CA
Joined Jun 2003
I just ordered mine and I have to say that I am skeptical as to wheater the price includes the Motor/Speed Control/Battery. It just seems to good to be true and we all know how that saying ends...It probably is.
Regardless it is a good deal for the airframe and I will probably drop one of the extra brushless motors I have lying around.
SQUARE ROOT is offline Find More Posts by SQUARE ROOT
Old Feb 10, 2006, 01:21 PM
IWC is offline
IWC
Find More Posts by IWC
IWC
Joined Feb 2003
Get it in writing and hold them to it.
IWC is offline Find More Posts by IWC
Old Feb 10, 2006, 02:08 PM
San Diego, CA
Joined Jun 2003
Well it is in the manual. Guess it comes with it after all.
Old Feb 17, 2006, 01:17 PM
Iflyrc_vic is offline
Find More Posts by Iflyrc_vic
Iflyrc_vic's Avatar
USA
Joined Dec 2004
Optional Equipment
Just got my Tower Hobbies monthly magazine - Tower Talk. The issue features ELECTRIC FLIGHT. The Lancair is on the inside cover with radio, charger, battery pack as a COMBO for $299.97.
The plane with the Speed 400 motor, 30A ESC, on-board battery, gear box and propeller for $99.99.
Hopefully they will be available soon....
Iflyrc_vic is offline Find More Posts by Iflyrc_vic
Old Feb 17, 2006, 01:46 PM
Mark Winstanley is offline
Find More Posts by Mark Winstanley
Mark Winstanley's Avatar
Canada, ON, Ottawa
Joined Jan 2002
I think the combo is with a radio, battery and charger as well as the motor / esc. The $99 kit is airframe, motor and esc and battery. I got fed up waiting and cancelled my order. I note that the same kit is advertised bt OmniModels at the same price b ut they also indicate late feb for delivery.
Mark Winstanley is offline Find More Posts by Mark Winstanley
Old Feb 17, 2006, 01:58 PM
papasmurf is offline
Find More Posts by papasmurf
"I passed on the kool-aid"
Waco, TX
Joined Jan 2004
I was looking at the tower site the other day and all the replacement parts were listed as available at the time but the complete package was not...go figure.
papasmurf is offline Find More Posts by papasmurf
Old Feb 17, 2006, 03:01 PM
York Electronics
Dallas Tx USA
Joined Apr 1999
I guess if I want one bad enough, I could get all the major parts (minus motor, gear box, controller, prop and battery - don't want them anyway). I add them up to $123.58. Hummmm....
Gary
Old Feb 17, 2006, 07:01 PM
Waco, TX
Joined Jan 2004
That is why I did not order one....is that a jenday by chance?
Old Feb 17, 2006, 11:02 PM
York Electronics
Dallas Tx USA
Joined Apr 1999
Sun. Mean as . Took the toe off a Blue Headed this week . I guess I trained him right... he ain't going to take off anyone!!!
Gary
Old Feb 18, 2006, 12:39 AM
Waco, TX
Joined Jan 2004
Sorry...figured it had to be one or the other. I miss mine....not the noise though.
Old Feb 18, 2006, 01:16 AM
York Electronics
Dallas Tx USA
Joined Apr 1999
Eahhhh?.... What ya' say sonny???? I'm deefe from the Sun!!!!
Seriously... Sounds like you lost a good friend. I dread the day I find Sonny tits up. He's such a good friend. Even if he costs me hundreds of dollars 'correcting' his bad behavior. (not that two days of cage punishment isn't enough . )
Gary
Old Feb 18, 2006, 09:32 PM
kipp geisler is offline
Find More Posts by kipp geisler
Kipp G
Dixon, Ca.
Joined Mar 2004
I've had mine on order now since late October. Not sure when it first hit the catalog, but I hope I'm near the top of the waiting (back order) list. If anyone wants my landing gear they'll be free. I'm not putting gear on mine. Hoping to improve performance, and I fly at a glider field of grass landing area. What about using a 3 cell Lipo pack? 11.1 volts would certainly increase performance if it doesn't fry the motor...But then that would give me an excuse to put in the MP Jet outrunner and see if it flies even close to my Alfa Model p-51. All of us glider guys are buying up the Alfa warbirds and going crazy while we wait for thermal weather in northern Ca.
kipp geisler is offline Find More Posts by kipp geisler
Old Feb 18, 2006, 11:29 PM
Waco, TX
Joined Jan 2004
I would be happy to take the gear off your hands if/when the plane arrives and could take care of shipping. I am always on the look out for spare wheel pants. After looking at how nice the fiberglass parts look on the tower site, it is going to be hard to resist this one when it finally does get here.
Old Feb 19, 2006, 01:45 AM
gotime242 is offline
Find More Posts by gotime242
Boynton Beach, FL
Joined Jul 2005
And if he doesnt want them i do.
gotime242 is offline Find More Posts by gotime242
Discussion GP Lancair EP Motor Not Straight?? kenmalecki Electric Plane Talk 8 Jun 27, 2008 11:35 PM
Sold Badly damaged GP Lancair EP,$30 plus shipping MustangAce17 Aircraft - Electric - Airplanes (FS/W) 10 Feb 06, 2007 09:27 PM
Question GP Lancair EP Horizontal Stab Attachment Thermalin Scale Kit/Scratch Built 1 Jul 31, 2006 07:29 PM
Sold GP Lancair EP RTF bruff Aircraft - Electric - Airplanes (FS/W) 0 Jul 06, 2006 12:21 AM
GP Lancair EP ARF - thoughts (Scratch this.. just saw the thread) Thermalin Sport Planes 0 Nov 09, 2005 10:27 PM
