Old Jan 28, 2006, 01:17 PM
gotime242 is offline
Find More Posts by gotime242
Boynton Beach, FL
Joined Jul 2005
...still not in stock. Blasted.
I think we can all agree its "Late Jan" as well.
Then again, like i said, they told me over the phone it would be feb.
At least i have that Corsair comming that will keep me distracted.
gotime242 is offline Find More Posts by gotime242
Old Jan 28, 2006, 02:53 PM
Iflyrc_vic is offline
Find More Posts by Iflyrc_vic
Iflyrc_vic's Avatar
USA
Joined Dec 2004
Originally Posted by Gary Warner
Did you see that the kit includes a 1800ma battery and a 30 amp controller? At first I thought this was part of the 'combo' price, but after looking, it's not (according to the web site docs). Like so many ARF's, I wish they would keep the motor, gear box, battery and controller out of the kit to keep the price low. Still, $99 for an ARF with a glass fuselage isn't bad.
Gary
I don't own any electric planes but I will as soon as this one hits the street. Since I am new to the electric world, is the speed 400 motor, controller and battery included in this kit any good. I don't plan to fly this bird all the time but I don't want a "dog" when I do fly it.
Iflyrc_vic is offline Find More Posts by Iflyrc_vic
Old Jan 28, 2006, 05:04 PM
Boynton Beach, FL
Joined Jul 2005
It will fly smoothly around the air. Dont expect unlimited vertical, or a crazy amount of power...but for just a sunday sport flyer it will be fine.
Old Jan 28, 2006, 06:11 PM
Iflyrc_vic's Avatar
USA
Joined Dec 2004
Flight time
What is the expected flight itme with the stock equipment listed. I normally set my receiver timer for 10 minutes and fly between 7 to 10 minutes with the glow enegine planes although I have a lot more time available.
Old Jan 28, 2006, 08:47 PM
Gary Warner is offline
Find More Posts by Gary Warner
York Electronics
Gary Warner's Avatar
Dallas Tx USA
Joined Apr 1999
Hi Iflyrc-vic,
Welcome to the electric world of RC. Funny thing... when you stop and think about it... it's easier to configure an electric airplane than a gas plane, when it comes to "will it will fly or not, and to what degree". That's because we talk in terms of watts per pound.
What's watts per pound (you say, not)? It's the best universal unit used to describe the performance of ANY plane. That's right, any plane. You can universally apply watts per pound to a model or a full scale plane, or anywhere in-between and it works to characterize the flight performance.
When I was talking about 32 oz. and a Speed 400 motor, I made some assumptions that we e-guys all know, but maybe you don't. A speed 400 is good for about 100 watts input with an output at or around 50 watts at this level of power. It's not very efficient (loss of around 50% of the energy used). With a plane getting 50 watts (give or take a bit) to the propeller, and a weight of 32 ounces, it's easy see (for us E-geeks) that the flight performance will be lackluster.
Here's the basic rules to watts per pound: (watts is current x voltage)
20 watts per pound: able to sustain flight
40 watts per pound: able to climb and perform mild aerobatics.
60 watts per pound: able to ROG and fly with reserve in performance compared to the scale plane.
80 watts per pound: able to perform aggressive acrobatics.
100 watts per pound: able to perform extreme aerobatics.
120+watts per pound: able to hover (just) and to fly at any attitude in capable hands.
140 watts per pound - the sky's the limit.
With the stock configuration allowing for (probably) 110 watts input and about 60 watts output, you can see that the flight wattage is 30 watts per pound at 32 ounces (the upper quoted and most likely the real weight of the airplane).
At 30 watts per pound, it's 'just' going to fly. That's ok, if it's a calm day, winds right down the runway, wide open spaces (no other planes to dodge in the sky), skilled pilot, etc. There are little if any reserves if needed.
Now, to keep things in perspective... 120+ watts per pound (like I want to do) can also have its short comings. Most notably, Airframe stress. To fly at these higher potential power ratings, one must be aware that there is a throttle and know how to use it. Power is cool, but not if you bust up a plane every time you go fly.
That's what I meant by saying "it wonít do for me". That comment won't apply to everyone, just others who know what I'm talking about.
Now, all of that (the formalities) aside, I think the plane will fly with the stock power setup. But keep in mind that it will probably need a skilled pilot that understands what it's like to fly an underpowered airplane. Honestly, I think you (assuming you are an accomplished gas pilot) will not be happy with the stock plane. And, I can say that without even seeing the plane at hand. Numbers don't lie. 30 watts per pound ='s a disappointing flight for one who's used to power in reserve. Add 19oz per sq. ft with 30 watts per pound and it's not getting any better.
The structure looks ok and the basic loading numbers look acceptable if you are used to hitting the numbers on most landings. All that's needed is more power.
My suggestion is that you follow this tread to see how different motor/prop/battery combinations pan out. When all the data is in, you will see that basic performance levels will all hinge around the Watts per Pound.
(Darn..., do I sound like a Know-It-ALL? Sorry, I'm really not (as my peers will soon demonstrate)...
Gary
Gary Warner is offline Find More Posts by Gary Warner
Old Jan 28, 2006, 09:37 PM
Boynton Beach, FL
Joined Jul 2005
^ Good read.
Old Jan 29, 2006, 08:09 AM
Iflyrc_vic's Avatar
USA
Joined Dec 2004
HP vs Watts
Gary, thanks for the lesson on "watts per pound". If the plane does perform as you predict at 30 watts per pound, I would be highly disappointed. My nitro powered Lancair models have plenty of power as I use an OS 91 four stroke in each. The full scale planes are designed to "go fast" and the models should at least be capable of moderate speeds. One of the full scale Lancairs was flown at over 300 mph. An under powered Lancair just won't cut it (IMO). Also, because I fly off grass fields, I need a little extra power for those days when the grass is a little high.
I will definately take your advise and wait to see the responses from those who fly this bird with the stock equipment.
BTW
After reading your message, I converted the BHP output from my nitro engine (1.6 BHP) to watts (1 HP = 746 watts). Since my plane weights about 9 ponuds, this gives me about 132 watts per pound. This puts me at the upper range of your scale. Is this correct or do I need to make some other adjustments.
Old Jan 30, 2006, 05:11 PM
York Electronics
Dallas Tx USA
Joined Apr 1999
BTW
After reading your message, I converted the BHP output from my nitro engine (1.6 BHP) to watts (1 HP = 746 watts). Since my plane weights about 9 pounds, this gives me about 132 watts per pound. This puts me at the upper range of your scale. Is this correct or do I need to make some other adjustments.
The actual shaft BHP is must likely less than advertised. I don't know what engine you are using, but a typical example would be a BHP rating that's above the normal RPM's we prop them at. If it's 16,000 RPM and you have propped for 12,000 RPM, you are probably only getting 70% of that BHP. You are probably getting something in the 90's watts per pound range.
Re-run the numbers and see if the watts match the listed flight characteristics.
For fun, full-scale Cessna 172 with 180 BHP engine.
2500 pounds, 134,280 watts. That's 53.712 watts per pound.
I did this formula for a B747 and it worked out to about 60 watts per pound if I recall correctly. I don't have the numbers in front of me at this time.
The watts per pound even works out well for indoor airplanes that only weigh an ounce or two.
I wonder what an F14 or F16 would work out to?
Gary
Old Jan 30, 2006, 05:29 PM
shschon is offline
Find More Posts by shschon
shschon's Avatar
United States, CA, SF
Joined Aug 2004
BTW
No I don't think Watt/lb can tell you the whole picture. Remember that sailplanes has ABSOLUTELY NO POWER so they are always 0 watt/lb. Still I have seen sailplanes perform incredible aerobatics and flys faster than many powered plane. The other end of the extreme are the helicopters. In order to hover and take off vertically all helicopters have more than 1:1 thrust to weight ratio and their power to weight ratio are generally much better compared to plane in the similar size. However almost all helicopters flys slower than comparable size airplanes.
How an airplane performs involves much more factors than simply Watt/lb. For example, you mentioned that you want speed. However even if you get over 140 Watt/lb but you are using a large low pitch prop on a high gear ratio, you may hover or go straight up but still you are not getting the speed you want. In fact you can be flying MUCH SLOWER than a plane with only 30 Watt/lb but properly propped to fly at high speed.
Power and speed are related to some extent, but their relation is much more complicated than a simple "equality sign".
shschon is offline Find More Posts by shschon
Old Jan 30, 2006, 05:37 PM
York Electronics
Dallas Tx USA
Joined Apr 1999
What is the expected flight time with the stock equipment listed. I normally set my receiver timer for 10 minutes and fly between 7 to 10 minutes with the glow engine planes although I have a lot more time available.
Oh, I never answered this. Assuming you mean with the stock equipment...
It all depends on throttle management. Some assumptions can be made.
A Speed 400's max current should not be over 15 amps. On 8x1800 nickel cells, these batteries are going to choke down to about a volt per cell. 8 volts at 15 amps is 120 watts input. (VxA=W)
1.600 amp hour (1600ma) (most likely usable capacity of 1800ma pack) divided by the current (15 amps) gives a full throttle discharge in .106 hours. .106 x 60 = 6.36 minutes (call it 6 minutes).
Using the watts per pound, we can approximate the flight times based on flying style performance. So, if all you want to do is putt-putt around the pattern (say, 20 watts per pound) the battery voltage at the lower current will come up to about 1.1 volts per cell, or 8.8 volts.
At 32 ounces we would need 40 watts (at the prop) to fly around in a slow fashion. The motors efficiency will probably come back up to the 60% range.
So, motor input watts would be about 65 watts (65 x 60% = 39 watts).
Now we know we need 65 watts on 8.8 volts. That's 65 divided by 8.8, or 7.4 amps. Again, 1.6 amp hours divided by 7.4 amps ='s .216 hours to discharge the battery. .216 x 60 minutes = 12.96 minutes (call it 13 minutes)
So, the flight times should range from 6 minutes to 13 minutes. These are the theory numbers, but the real flight times might be 10-15% more or less.
Gary
Old Jan 30, 2006, 06:40 PM
Iflyrc_vic's Avatar
USA
Joined Dec 2004
Thanks for all the replies.
Shschon, I am well aware that these are theoretical assumptions and performance may vary depending on a bunch of factors including airplane aerodynamics, airfoil shape, fuse shape, prop pitch and size, and host of other factors. I am only looking for "round" numbers as we are not planning a trip to Mars. The figures that Gary presented will put you in the ball park and that is all I need.
Gary, my four stroke engines are the OS 91 Surpass II which bost a whoping 1.6 BHP at 11,000 rpm. I prop the engine and mixture to run around 9000-10,000 rpm on the ground so I am probably turning somewhere near 11,000 rpm in the air. As such, your charted watts-per-pound performance is close to what I am seeing. Again, thanks for the "yardstick" to use as a general gauge for estimating airplane performance.
Old Jan 30, 2006, 08:17 PM
ArnoldC is offline
Find More Posts by ArnoldC
ArnoldC's Avatar
Dallas, Tx
Joined Jan 2003
come airplane come here, here boy come on... hmm not working now is it
ArnoldC is offline Find More Posts by ArnoldC
Old Jan 30, 2006, 08:33 PM
York Electronics
Dallas Tx USA
Joined Apr 1999
^ LOL
I think he's making a good point. If no energy is added to the airframe, it can't fly level, let alone climb. A sailplane in flight gets its energy from the rising air. It's wattage, if you will.
Old Jan 30, 2006, 08:57 PM
York Electronics
Dallas Tx USA
Joined Apr 1999
shschon,
OK, here's an experiment in the WPP (watts per pound) modeling:
Sailplane: 5 pound, sink rate 100ft per minute
Question: What's the WPP added to the airframe to maintain level flight (enough 'lift' to sustain constant level flight)?
Fact: Horsepower is expressed as 33000 foot pounds per minute
The WPP needed is:
100 ft x 5 pound = 500 foot pounds per minute
500 / 33000 = .01515 horsepower
746 (1 HP in watts) * .01515 = 11.3019 WPP, and that's the exact MINIMUM WPP needed.
Now, for a sailplane with a good aspect ratio and an excellent sink rate this number is right on. Now add extra sink rates for maneuvering in the same level of lift and more watts per pound will be need. Say, 15 WPP or so. 20 WPP is a good number for sport planes.
I think the WPP IS an excellent way to characterize aircraft performance. The comment that a sailplane flies with '0' watts per pound is some what false. Now airplanes can fly at '0' watts per pound, but they all are falling in flight. Be it a Cessna, B747, E-plane or sailplane. If it's not falling, it's getting energy from something. Rising air for the sailplane and motor thrust for a power plane.
Do you know why solor flight is so marginal, at best? Do the math.
Gary
Old Jan 30, 2006, 11:08 PM
York Electronics
Dallas Tx USA
Joined Apr 1999
I can't resist. I know this is getting a fair bit off-topic..., but I've always wondered... what the watts per pound's are needede for 'excellent' lift (yes, I compete in sailplane contests ).
Ok, I talked to a friend tonight that carries a RAM altitude recorder on his sailplane. We both agree that the average 'good' lift situation hovers around 500 feet per minute. So, lets see how many watts per pound (WPP) is needed to climb at this rate. The basic model I described before will suffice for this example.
Sailplane: 5 pounds, Sink rate 100 feet per minute, climb at 500 feet per minute.
WPP needed for 500 ft per minute is:
600 ft per minute (500 climb + 100 feet per minute sink), x 5 pounds ='s 3,000 foot pounds per minute.
3000 / 33000 ='s .0909 HP
746 (1 HP in watts) * .0909 ='s 67.8114 WPP
Wow! There is a lot of energy in lifting air!
67.8114 WPP's is a lot of energy! Donít' believe me? Put your hand in the way of a prop running 339 watts (67.8 WPP x 5 pounds).
Gary
Discussion GP Lancair EP Motor Not Straight?? kenmalecki Electric Plane Talk 8 Jun 28, 2008 12:35 AM
Sold Badly damaged GP Lancair EP,$30 plus shipping MustangAce17 Aircraft - Electric - Airplanes (FS/W) 10 Feb 06, 2007 10:27 PM
Question GP Lancair EP Horizontal Stab Attachment Thermalin Scale Kit/Scratch Built 1 Jul 31, 2006 08:29 PM
Sold GP Lancair EP RTF bruff Aircraft - Electric - Airplanes (FS/W) 0 Jul 06, 2006 01:21 AM
GP Lancair EP ARF - thoughts (Scratch this.. just saw the thread) Thermalin Sport Planes 0 Nov 09, 2005 11:27 PM
