Old Jan 22, 2006, 07:25 PM
ave is offline
ave
Find More Posts by ave
ave
Wind Junkie
ave's Avatar
North Coast, Calif.
Joined Jun 2004
Anyone done Kevlar thin goop'd to EPP?
Trying to find a way to strengthen my LEG while it's in pieces, seems like it would work good for tensional forces... maybe just for the most common breakage area... somewhere between the LE and nose of EPP planes... or the whole bottom of the fuse for that matter. Then use CF rods more near the top of the fuse to hold the compressive forces.
I'm doing a little test right now(drying) to see how tough it is. The kevlar I'm using is somewhere around 1.5-3oz/sq-yrd. It wetted out great with the thinned goop!
Anyone experimented with this?
ave-
ave is offline Find More Posts by ave
Old Jan 22, 2006, 07:31 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
As long as it sticks after it's cured (Goop cures by evaporation so hopefully
the Kevlar doesn't just soak up all the Goop leaving nothing to adhere
it tothe EPP), and doesn't fuzz up at the edges, it should
work ok. I haven't tried it, since my supply of Kevlar cloth is pretty
limited. Reminds me, I should order some more from ACP.
ian
Daemon is online now Find More Posts by Daemon
Old Jan 22, 2006, 07:32 PM
slopemeno is offline
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
Its been done. it tends to wrinkle, like on the nose, and you cant shrink the wrinkles out with heat.
slopemeno is offline Find More Posts by slopemeno
Old Jan 22, 2006, 07:41 PM
ave is offline
ave
ave
Wind Junkie
ave's Avatar
North Coast, Calif.
Joined Jun 2004
Yea, that makes sense that you couldn't shrink it back down. Perhaps if you used it between the two fuse halves near the bottom edge. I may try that on my next ones.
ave-
Old Jan 22, 2006, 07:51 PM
ave is offline
ave
ave
Wind Junkie
ave's Avatar
North Coast, Calif.
Joined Jun 2004
Ian, you're right about the evaporation, I had to go back and squeegee in a non-thinned coat into the kevlar... the thinned stuff was too thin to fill the weave of the kevlar after evaporation.
ave-
Anyone done a 90" Jack Stafford B-24 Liberator? G.F. Beurling Scale Kit/Scratch Built 21 Mar 26, 2010 11:18 PM
Question How thin Goop for covering EPP wing? 4444 Slope 4 Oct 08, 2006 10:32 PM
Anyone Done this Bipe??? Steve H. Sport Planes 10 Feb 05, 2003 10:14 AM
Has anyone done a battery comparison in the Viper Twin? GBR2 Foamies (Kits) 10 Nov 20, 2001 06:14 PM
Anyone done this? pkyee Electric Heli Talk 4 Nov 04, 2001 06:25 AM
