Old Jan 22, 2006, 06:26 PM
DSK is offline
DSK
Find More Posts by DSK
DSK
Micro Nut
DSK's Avatar
Mountlake Terrace,WA
Joined Jul 2004
Question
What plane will work with this?
Hi all I have one of theseMotors
And was wondering waht plane could I use it in if at all. Would i be able to use it with an E-Flight Ultimate 3-D or something close? Any info would help?
DSK is offline Find More Posts by DSK
Old Jan 22, 2006, 06:45 PM
Larry3215 is offline
Find More Posts by Larry3215
Permanently Banned
Larry3215's Avatar
Gig Harbor, Washington, United States
Joined Sep 2003
Thats a pretty hi Kv motor, but on 2S lipos it would probably fly it. Its not ideal tho. Especially for hovering as you will need to stick with fairly small props.
Larry
Larry3215 is offline Find More Posts by Larry3215
Old Jan 22, 2006, 07:15 PM
DSK is offline
DSK
DSK
Micro Nut
DSK's Avatar
Joined Jul 2004
What about a Stryker or a Yak with TP 1320 3's ? is that a possibility?
Old Jan 22, 2006, 07:25 PM
Permanently Banned
Larry3215's Avatar
Joined Sep 2003
Stryker type plane would be much better than the Yak.
3D planes (like the Yak or Ultimate) are designed to fly relatively slow. They need more thrust than air speed for 3D manuvers. That means you need to spin a larger prop.
The Stryker types are just the oposite. They want to go fast. That means a smaller prop turning higher rpm. Thats what that motor you listed is designed for - hi rpms.
Larry
Old Jan 22, 2006, 08:03 PM
DSK is offline
DSK
DSK
Micro Nut
DSK's Avatar
Joined Jul 2004
Thanks I willl do somemore searching, Butyou have given me a place to start.
Discussion What planes will work with this setup ? Campy Glow to Electric Conversions 1 Dec 01, 2006 11:27 PM
Sold What motor will work with Uav plane 4 channel Speed Stick 3D Aircraft - Electric - Batteries & Chargers (FS/W) 3 Nov 14, 2006 01:23 PM
What receiver will work with my Radio? haddorh Micro Helis 13 Jan 15, 2005 12:28 PM
Question What plane will 3D with this stuff? Mickymouser731 3D Flying 1 Apr 18, 2004 02:14 AM
Q on what engines will work with Lithium cells ramw5p Parkflyers 8 Dec 14, 2001 12:33 AM
