Old Jan 22, 2006, 04:32 PM
ram3500-rcu is offline
Find More Posts by ram3500-rcu
ram3500-rcu's Avatar
Northern Ohio
Joined Jan 2006
Plug in removable wings for depron park jets
In building these jets for pilots around the world, I have gotten some challenging requests. One such request came from a gentileman who travels the world and wants to take his F-18 with him.
Problem; how to shrink it down to fit in a checkable case (I'm shooting for a small insrument case modified to fit our park jets). BTW, I hope to be able to get the transmitter in the case as well.
Solution; removable wings and verticals. The system for the wings is now complete and I am posting this for some feedback. I am now going to do this to all the ones I build as it makes shipping easier anyway. This will also make it easy to replace a damaged wing section. This is how I worked it out on an F-15. I did have build to taller turbine housings but they are not solid and the weight gain is minimal. I think they look better anyway. On the F-18, the turtle deck in the center will be the location for the two pins.
Not shown in the pictures yet are the aierons. I plan to split them as well and leave the inboard 1" with the center section of the wing. This way the horn and servo lincage will remain connected at all times.
ram3500-rcu is offline Find More Posts by ram3500-rcu
Old Jan 22, 2006, 05:48 PM
alpapilot is offline
Find More Posts by alpapilot
Newnan, GA
Joined Jun 2005
That really is a fantastic idea! Quick question though... How do you supose removable wings would work on the BD-5?
alpapilot is offline Find More Posts by alpapilot
Old Jan 22, 2006, 06:05 PM
Northern Ohio
Joined Jan 2006
can do
With todays carbon fiber rod, I think it is a possibility. The pin system would be easily accessable through the large hatch, and there is enough of a belly pan under the wing so the pins wouldn't protrude out the bottom. Maybe I will play around with this. Shipping would be much easier anyway. Think of how small the box could be.
Old Jan 22, 2006, 09:39 PM
cdebaca is offline
Find More Posts by cdebaca
cdebaca's Avatar
USA
Joined Oct 2005
Clever,I like the tiny cotterpins.
cdebaca is offline Find More Posts by cdebaca
Old Jan 22, 2006, 10:49 PM
Northern Ohio
Joined Jan 2006
Thanks. I plan to glue them to a length of fish line and fasten it inside the hatch so you can't loose them.
Old Jan 22, 2006, 11:30 PM
cdebaca is offline
cdebaca's Avatar
USA
Joined Oct 2005
Pins
Uhh,how would you get them back on?
Old Jan 23, 2006, 12:15 AM
Northern Ohio
Joined Jan 2006
Not sure what you mean. I'm just cabeling them to the fuse. so you can't drop them. They would be hard to find in grass.
Old Jan 23, 2006, 12:18 AM
cdebaca is offline
cdebaca's Avatar
USA
Joined Oct 2005
Oh I get it stupid me.
Old Jan 23, 2006, 01:05 AM
Northern Ohio
Joined Jan 2006
Don't be too hard on yourself. Pictures will help when I can post them. I have to pull off the project for 4 days because of my full time job. Be back on it Friday.
Old Jan 23, 2006, 01:40 AM
patrickverlinden is offline
Find More Posts by patrickverlinden
Belgium, Flemish Region, Beringen
Joined Sep 2005
Very interesting concept, take care however with the combination aluminium tube/carbon rod. friction between these materials could induce radio interference during flight.
Anyway, Ilike the idea!
greets,
Patrick
patrickverlinden is offline Find More Posts by patrickverlinden
Old Jan 23, 2006, 02:05 AM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
GREAT idea! Although this will add a little weight, I think these jets can easily handle it. Rather than split the flaperons, I'd suggest just putting them on the outboard wing only. You'd have to disconnect the flaperon control linkage every time you take the wing off, but that's easy to do. Other than that, I don't foresee any problems.
Steve
jetset44 is offline Find More Posts by jetset44
Old Jan 23, 2006, 02:52 AM
pacro is offline
Find More Posts by pacro
TOPDOG
Taiwan
Joined Oct 2003
looks better than the way i used on my EDF version of my F-18. ( i mashedone wing into the ground but the carbon didnt snap so i glued a 3mm di. core rod to the new wing cutout and slid it back on)
pacro is offline Find More Posts by pacro
Old Jan 23, 2006, 06:30 AM
Micronics is offline
Find More Posts by Micronics
Micronics's Avatar
Italy, Lazio, Rome
Well,Ive done this to my F-14.
Wings,elevons and stabilator are detachables.
Ill take some pictures and post it here how i done it.
Allen
Micronics is offline Find More Posts by Micronics
Old Jan 23, 2006, 07:50 PM
Northern Ohio
Joined Jan 2006
Steve
Thanks Steve, for your feed back. I very much enjoy your designs. On the lincage, my thinking on that was two fold. 1. not running the risk of getting something out of trim by messing with the lincage all the time and 2. minimizing the risk of loosing the link when it is disconnected. I could see myself getting to the field only to fine a pushrod missing. Murphys law and all. I figured a way to plug the aileron into it's root as well without disturbing the adjustments.
Old Jan 23, 2006, 08:12 PM
Northern Ohio
Joined Jan 2006
greets,
Patrick
Thanks Patric for the heads up. I am placing a small 'plug' of bees wax (the soft kind used to weather proof leather) in the tube, then I push the rod in. This lubes up the rod and helps prevent the epoxy from wicking in the tube when I lay it all up. Do you think I would be better off using dialectric grease for this, or am I ok with the wax?
Help! Removable wings for my pitts python. prodigy Foamies (Scratchbuilt) 0 May 03, 2007 08:37 AM
Discussion plug in programming switch for Fusion 9 SkyKing RC Hitec/Multiplex USA 10 Jul 27, 2006 11:59 AM
Discussion Best prop size for most park jets crazy pilot Pusher Prop Jet Models 5 Feb 23, 2006 05:44 PM
Discussion 1 gram Missles for your park jets?!!! delta400 Pusher Prop Jet Models 16 Jan 09, 2006 05:20 AM
A good plug in the wall charger for lipo batts kitbasher Batteries and Chargers 1 May 14, 2003 11:26 PM
