Old Jan 22, 2006, 01:49 PM
rand24 is offline
Find More Posts by rand24
Joined Jan 2004
full house e-sailplane and 8103 = no fun (9303 better?)
The 8103 has served me well in dlg and everything else I've done in the hobby...trying to set up a 2.5e Organic so that I can use flaps and vary the trailing edge and have motor on a switch is just about a real pain - Is this enough reason to swap to the 9303?
rand24 is offline Find More Posts by rand24
Old Jan 22, 2006, 02:29 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
It is fairly easy to do this with an 8103. There are some on-line instructions out there. Give me a bit and I will find the link...
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Jan 22, 2006, 02:41 PM
pmackenzie's Avatar
Joined Dec 2002
Found it! The author posts here as well, so he might pipe in at some point if you need more help.
http://www.smacaw.com/xp8103/
I just bought a 9303, but until now I have used a very similar method with both a 388 and 8103.
Pat MacKenzie
Old Jan 23, 2006, 04:40 PM
Goinav8n is offline
Find More Posts by Goinav8n
Jeff Carr
Ft. Mill SC / Charlotte NC
Joined Mar 2001
Unless you want the 9303 buy it but the 8103 is a good radio that will serve you well in this application
Jeff
Goinav8n is offline Find More Posts by Goinav8n
Old Jan 23, 2006, 06:10 PM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Awsome link! Thanks!
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old Jan 23, 2006, 10:42 PM
rand24 is offline
Joined Jan 2004
I have seen that - and thank you for posting - I'm uncomfortable with that workaround. I'd rather have a dedicated switch for the motor and run camber and flaps off the throttle lever. Jeff do you mean to say that the 8103 can run throttle on a switch and vary camber as well?
In this method does the throttle need to bet set to that exact location on the servo screen? For my motors they won't initialize unless that screen shows the throttle at zero.
Old Jan 24, 2006, 08:56 AM
rdwoebke is offline
Find More Posts by rdwoebke
The Self Confuser
rdwoebke's Avatar
United States, IN, Indianapolis
Joined Feb 2004
Rand,
I don't own a 8103. I do have a 783. I also don't (yet) have a 6 servo model.
That said, could you not use aux3 to run the throttle? Aux3 is a "pot" on the top right of the 8103. You could use a free mix to mix one of the switches to aux3 and run throttle that way.
It would be easiest to test this by plugging a spare servo into the output of aux 3 on your rx and watch it move as you test the mixing.
Ryan
rdwoebke is offline Find More Posts by rdwoebke
Old Jan 24, 2006, 06:49 PM
rand24 is offline
Joined Jan 2004
that's a good idea - I guess I have always just disabled the pots because thats what sherman knight et al seem to recommend - I'll look into that thanks...By the way Sherman Knight guides on the JR radios is really a great resource.
Old Jan 25, 2006, 07:28 AM
Goinav8n is offline
Jeff Carr
Joined Mar 2001
Let me look around a little as I may have something with a program in it. Im surprised no one has chimed in with one. You could go over to RCUniverse to the radio section Sub forum for JR and ask Danny. He will ansewer with in 1 day. Its a good resource. Do a search on there and see if someone has already asked
Jeff
Discussion Hitec Flash 5SX set-up for a full house TD sailplane aeajr Thermal 26 Jan 23, 2007 08:17 PM
Discussion E-sailplane and 8103 programming wingbeat High Performance 5 Jun 30, 2006 10:08 PM
FS: Sioux RTF "full-house" Sailplane johnsloper Aircraft - Sailplanes (FS/W) 6 Jun 03, 2005 06:59 PM
Full house electric sailplane with the JR-8103? Falconator Electric Sailplanes 5 Jun 10, 2004 05:55 PM
Rx battery pack for full house E-sailplane ? oded mazor Electric Sailplanes 6 Mar 20, 2002 05:51 PM
