Old Jan 22, 2006, 09:04 AM
agapornis is offline
Find More Posts by agapornis
agapornis
italy
Joined Jul 2004
Where Can I Buy An Electric Raptor ?
Any help ?
agapornis is offline Find More Posts by agapornis
Old Jan 22, 2006, 09:10 AM
heli_newbie is offline
Find More Posts by heli_newbie
crash. rebuild. repeat
Fairfield CA, USA
Joined Mar 2005
Nowhere.. yet... you'd still have to convert a glow powered machine.. there are kits available, however, such as at http://www.tppacks.com
heli_newbie is offline Find More Posts by heli_newbie
Old Jan 22, 2006, 10:13 AM
Veloc-E-raptor is offline
Find More Posts by Veloc-E-raptor
Veloc-E-raptor's Avatar
United Kingdom
Joined Jan 2004
Or www.realraptors.co.uk for the xerog 600ep, the carbon framed e-raptor
Veloc-E-raptor is offline Find More Posts by Veloc-E-raptor
Old Jan 22, 2006, 10:31 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Its also available from Xtreme RC Products http://store.xtremercproducts.com/
RC Man is online now Find More Posts by RC Man
Old Jan 22, 2006, 12:30 PM
gruntdog is offline
Find More Posts by gruntdog
Big Kid / Big Toys
gruntdog's Avatar
Ontario Canada
Joined Feb 2003
where can I buy
Unless you can find a used erappe for sale be it boxed or direct drive , you will need to build one , do some research first. then look into the parts required and quite a few choices to make, then you are ready to plunge into it.
not an inexpensive project to build, but not as expensive as some of the equally sized kits out
from my reading the e raptor is a good stable platform for entry into that size
of heli be it epowered or ntro that will also perform as your skills progress.
I would expect that even though I have some basic skills with my Ark x400 and my Corona the eRappe will be a learning curve as well due to its size. I have read that the larger helis do fly with a bit more presense in stability due to the weight you are working with, I will soon see.
MT
gruntdog is offline Find More Posts by gruntdog
Old Jan 24, 2006, 11:01 AM
Hoax is offline
Find More Posts by Hoax
Joined Mar 2005
Originally Posted by agapornis
Any help ?
Im getting out of the hobby so I could sell you my COMPLETE setup
Lemme know if you are interested
Hoax is offline Find More Posts by Hoax
Old Jan 24, 2006, 11:10 AM
remie is offline
Find More Posts by remie
remie's Avatar
Netherlands
Joined Dec 2004
you can buy a e-raptor at http://www.eheli.nl/winkel/index.php?cPath=1_129_132
they also have a e-gohbee/stinger
remie is offline Find More Posts by remie
Old Jan 24, 2006, 12:12 PM
United States
Joined Feb 2001
I just got my XeroG 600EP flying and it sure is a big improvement from all those plastic Raptor frames. It is extremely well engineered and very light weight. I also like the battery being fully enclosed in a very strong carbon fiber frame. The battery compartment is very large so it will be able to accommodate any future cells to hit the market. Those LiPo batteries should not be damaged in a crash.
This thing definitely has much better performance than my Raptor 50/OS50 helicopter.
RC
Old Jan 24, 2006, 12:54 PM
Albig is offline
Find More Posts by Albig
Das Universus Elektrikus
Albig's Avatar
NM, USA
Joined Mar 2002
RC
I wish I could say I agree with you but I've been flying LiPos in a Joker and a CF Raptor for a couple years and more often than not a crash does bad things to your pack regardless of being inside the frames. It's called Rapid Deceleration Trauma, and I've had on more than one occasion a pack that went bad shortly after a crash that appeared untouched.
We need the next generation cells ASAP
Al
Albig is offline Find More Posts by Albig
Old Jan 24, 2006, 01:32 PM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
Al
Have you had packs ignite after a crash?
Personally, I usually fly nicads, and I'm very very conservative when flying lipos...
Toshi
TMorita is offline Find More Posts by TMorita
Old Jan 24, 2006, 01:47 PM
Albig is offline
Albig's Avatar
NM, USA
Joined Mar 2002
No Toshi,
I have totally trashed them in crashes but never had one even get hot.
I have however had them vent & ignite twice in flight:
Old Jan 24, 2006, 01:50 PM
GGoodrum is offline
Find More Posts by GGoodrum
GGoodrum's Avatar
South Orange County, CA
Joined Mar 2003
Well, Ive seen two crashes now with the eMolis, and in both cases the packs were unprotected, up front, and both helis went nose in. In one, I just had electrical tape on it, and it was torn in a couple of spots, but no other damage. The other had the rubberized 3M shrink wrap and it had zero damage, even though it ended up 20 feet away. I recharged and balanced the pack at 2C, like I normally do, and again the cells were still within .020V of each other at the beginning of the charge.
I've never seen a LiPo pack explode on a crash. Usually, the pack is okay, even if bent, if the bags stay together with no punctures. Even when a pack gets a dead short it kills the cells pretty quick, but then it is an open circuit. The only "explosions" I've seen, or heard about, were charging-related, where for whatever reason, the cells were receiving too much voltage, causing thermal runaway and "venting".
-- Gary
GGoodrum is offline Find More Posts by GGoodrum
Old Jan 24, 2006, 02:18 PM
Albig is offline
Albig's Avatar
NM, USA
Joined Mar 2002
-- Gary
Oh No Not Again
Old Jan 24, 2006, 03:29 PM
GGoodrum is offline
GGoodrum's Avatar
Joined Mar 2003
Oh No Not Again
Yes, my Raptor had a lockout (using a G3 with a Revolution antenna...). But, it is all better now. The worst of it was it trashed my V-Blades. The frames are fine, except for a busted canopy mount. The canopy popped off, so it is fine, as are the CF skids. Looks like the blades took the brunt of the hit.
-- Gary
Old Jan 24, 2006, 06:09 PM
United Kingdom
Joined Jan 2004
Sorry to hear about the second battery impact testing. Are Hechingers still the cheapest online for v28s? (I may have someone who can bring some back to the UK for me......)
Question anyone know where I can find an electric Stearman pt17? fullscalepilot87 Electric Plane Talk 5 Jan 12, 2007 04:40 PM
Help! Where can I buy an RC Plane? leovelloz Beginner Training Area (Aircraft-Electric) 14 Dec 09, 2006 09:32 PM
Where Can I Find An Electric Outboard Motor Cover!!! telecom tech Racing Boats - Electric 1 Sep 24, 2004 04:49 AM
Does any one know where I can buy an inexpensive hot wire knife/saw? flyboy1987 Foamies (Kits) 3 Apr 26, 2004 09:14 AM
Where can I buy an FV-1000 ? Warren Jones Electric Ducted Fan Jet Talk 2 Jul 22, 2003 10:01 AM
