Old Jun 12, 2002, 05:50 PM
bigjohn is offline
Find More Posts by bigjohn
dare to be dull
bigjohn's Avatar
Deland, FL
Joined Jun 2002
Pleeeze! help needed with Neu speed control for Mega S7
Hi:
Just bought a 4.2m scale glider with an electric up'n'go system, my first electric. Check the pic at bottom.
Looks like the glider has been dormant for a while( previous owner says it's un-flown) so the propulsion is probably pretty dated. It's a Mega S7(BRUSHED motor) with a SWN FAI controller powered by 16 cells/ 1400Mah. This all swings a Graupner 11x7 prop thru the belt drive, 1:1.
I did see the S7 on the Mega web site . I have been looking for information on the ESC, but couldn't find anything.
Printed on the back of the speed controller is:
_________________________________
Center
FAI Controller
10-40 volts@100 amps
7-10 volts@85 amps
By SWN San Diego CA
HERE"S THE PROBLEM
The first time I got the system charged up, it seemed to run fine. Throttle was reversed, but once I fixed that and tuned the ATV on the radio, I had fine control of the speed.
Now, a week later, I went in the shop to set up the glider and the power system is wacky. The motor goes full on as soon as I plug the battery power in. It stops as soon as I either disconnect the pack (of course) or disconnect the ESC control from the Rx. I don't know what changed. Am I doing something wrong? Is there a particular order to switch ESC vs Rx on? I thought I tried it both ways..
Guidelines for running this particular ESC would be welcome. If I read my specs right, I could get away with a substantially smaller ( less power) ESC if need be.
If you think this one is broke, advice on getting it fixed - or getting a new one would be most welcome. Supplier's web site's would be of great value as well.
bigjohn is offline Find More Posts by bigjohn
Old Jun 13, 2002, 11:18 AM
bigjohn is offline
dare to be dull
bigjohn's Avatar
Deland, FL
Joined Jun 2002
Nevermind
Nevermind, got it.
Discussion help with Jeti Speed controller for Mega dman1 Foamy EDFs 2 May 03, 2006 12:42 AM
need help with choosing speed control ned49 Beginner Training Area (Aircraft-Electric) 7 Sep 18, 2005 05:29 AM
Help with Bluecore speed racer for local group contest. Aobid Foamies (Kits) 22 May 07, 2004 03:14 PM
HiTec Rep where are you/ help with Neon and speed control richphoto Radios 1 May 02, 2003 10:28 AM
Newbie Needs Help with Choosing Speed Control pwalter_99 Power Systems 0 Mar 21, 2003 09:26 PM
