Old Jan 21, 2006, 04:32 PM
Lboogie is offline
Find More Posts by Lboogie
Lboogie's Avatar
Sebastian Fla
Joined Nov 2005
Euro Fighter Typhoon scratch built for 90mm fan
Lboogie is offline Find More Posts by Lboogie
Last edited by Lboogie; Jul 22, 2009 at 12:59 PM. Reason: aint lernt how ta spellin yet :)
Old Jan 22, 2006, 01:52 PM
Lboogie is offline
Lboogie's Avatar
Sebastian Fla
Joined Nov 2005
Old Jan 23, 2006, 04:16 AM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
this for 2 or one 90mm fan? Just wondering cause thats close to the size im doing for 120mm and twin midi would definately fit in it.
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Jan 23, 2006, 02:52 PM
Lboogie is offline
Lboogie's Avatar
Sebastian Fla
Joined Nov 2005
Old Jan 26, 2006, 01:44 PM
Lboogie is offline
Lboogie's Avatar
Sebastian Fla
Joined Nov 2005
Old Jan 29, 2006, 12:57 PM
Lboogie is offline
Lboogie's Avatar
Sebastian Fla
Joined Nov 2005
Old Feb 05, 2006, 10:25 AM
Lboogie is offline
Lboogie's Avatar
Sebastian Fla
Joined Nov 2005
Old Feb 05, 2006, 04:11 PM
MattinAZ is offline
Find More Posts by MattinAZ
MattinAZ's Avatar
United States, AZ, Gilbert
Joined Jan 2005
Very, very nice.
Saw a turbine Euro fly and it had to have the best flight char for having a fun flying plane. I have a Grippen pusher with working conards and it too was fun to fly.
Go Steelers!!
MattinAZ is offline Find More Posts by MattinAZ
Old Feb 06, 2006, 08:14 AM
Lboogie is offline
Lboogie's Avatar
Sebastian Fla
Joined Nov 2005
Old Feb 06, 2006, 09:04 AM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Great work Leonard,
I hope to see this model fly sometime. maybe you and Bob G can make FJ's next month if so please bring you model for me to see.
Bob
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Feb 06, 2006, 09:38 AM
Ron Laden is offline
Find More Posts by Ron Laden
Ron Laden's Avatar
Landkey, Devon, England.
Joined Jul 2003
Hi Leonard,
Looking very nice indeed, lovely build.
Out of interest where have you positioned the c of g, I have it at 12% MCA on the little Minifan version which seems to be spot on and that will obviously be my start position on my 90mm version.
Also at my scale of 36" span the scale position of the main gear would be 5" behind the 12% c of g, which is too far back. I am going to position it 3" behind c of g (still a bit rearward) but hopefully rely on the positive "sit" on the ground plus the working canards to pick the nose up.
Reference your canard drives, how about some 1/8th carbon rod?
Cheers
Ron
Ron Laden is offline Find More Posts by Ron Laden
Old Feb 06, 2006, 12:46 PM
Joined Aug 2002
Even at my 38" span version I think I will be around 12 to 13 percent also. Going with fixed canards though. And I was going with scale location for gear, but you are thinking of bumping your back Ron? For rollout stability?
Barry
Old Feb 06, 2006, 01:16 PM
MattinAZ is offline
MattinAZ's Avatar
Joined Jan 2005
I went with the CF tubes. Tubes seem to be much stiffer than rods. I used a pc of alum as bushings for each side with liteply. If you find the right sizes of CF and Alum you will have a nice snug fit that you can add some Li greese to reduce the wear of the CF.
Roughed up the CF tubes and used epoxy to attach to canards. Has held up well.
Matt
Old Feb 06, 2006, 01:21 PM
Ron Laden's Avatar
Joined Jul 2003
Matt, you are quite right I meant to say carbon tube, it "is" stiffer than rod.
Old Feb 06, 2006, 01:43 PM
MattinAZ is offline
MattinAZ's Avatar
Joined Jan 2005
Ron,
Loved your minfan Euro build and watching the midi. Someday I need to build one.
The high alpha ability makes the delta/canard planes fun and easy to fly. Could barely get my grippen to stall and when it did it would just mush the nose over. Needed rudder for the high alpha flying which I added after a few flights.
Lboogie - Are you planning on rudder control? Could use a very small servo in the back. You really only needed it at high alpha. I found the ailerons useless at slow high alpha speeds.
Matt
Discussion euro fighter typhoon build ootay Pusher Prop Jet Models 12 Nov 17, 2006 02:59 PM
Small scratch built for sale mlehman Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2003 02:44 PM
F-104 for 90mm fan Jet builder Electric Ducted Fan Jet Talk 8 Jul 30, 2003 10:03 PM
F4D Skyray for 90mm fan Robert Belluomini Electric Ducted Fan Jet Talk 8 Sep 06, 2002 11:15 PM
Electro Zinger (Scratch Built) For Sale zebra Aircraft - Electric - Airplanes (FS/W) 0 Apr 26, 2002 09:08 PM
