Old Jan 20, 2006, 10:36 AM
EzEd is offline
Find More Posts by EzEd
NTSB most wanted
EzEd's Avatar
O-Town, FL
Joined Jun 2003
Black Horse Decathalon build
Good day fellow electric flyers. I have begun a build of the Black Horse Decathalon offered by Hobby Lobby.
The kit, upon inspection, looks to be a quick build. However, this is my first glow to electric conversion so I will be taking my sweet time. Besides I haven't got the power plant yet. I have ordered the Hyperion 4020 10 turn along with the front mount. I plan on using the Poly-Quest 4 cell 20C 3700Mah LiPo pack. Not sure yet on the ESC/BEC.
EzEd is offline Find More Posts by EzEd
Old Jan 20, 2006, 04:04 PM
David Hipperson is offline
Find More Posts by David Hipperson
Kilsyth, Victoria, Australia
Joined Oct 2003
This looks identical to my Decathlon sold here in Australia under the Seagull tag. I went a different route to you and used a locally produced 700 watt outrunner off 20 X GP 3300 and a Phoenix 60 esc with a 13 X 8 APC 'E' prop. Despite the cells shoving the weight up to 9lbs the plane is very comfortable to fly, stalls gently straight ahead and still manages ten minute flights. If yours is like mine then it pays to remove those very heavy pushrod tubes at the rear end (two for elevator and one for rudder). Good luck with it though as this is a very nice first time conversion.
David Hipperson is offline Find More Posts by David Hipperson
Old Jan 21, 2006, 07:27 AM
gouda is offline
Find More Posts by gouda
Is it summer yet?
gouda's Avatar
Flight Level 46 X 92
Joined Feb 2002
I just got a Thunder Tiger Decathlon this week for the same purpose (EP conversion). I'll be watching with interest. Very similar (64" ws, 694 sq in) but different airframe. At least I assume it's a different airframe, we should compare a few internal pics. Need to funish my current CG Cub project before starting on this one though. I'd be interested in your motor choice/options. I am planning on a AXI 2826/12.
gouda is offline Find More Posts by gouda
Old Jan 21, 2006, 10:04 AM
EzEd is offline
NTSB most wanted
EzEd's Avatar
O-Town, FL
Joined Jun 2003
Gouda,
Your choice for the motor should serve you well provided you will be in the 6 - 7 lbs range. The Hobby Lobby site actually recommends the 2826/10 for my decathalon. I decided on the Hyperion 4020/10 because I like the extra pop and I prefer to fly around half throttle with the extra reserve for aerobatic applications. I would think that using the 2826/10 would put me at the max for that particular motor.
I got the elevator/rudder tail feathers glued in place. I will now have a little bit of a pause in building as I await the motor/esc/bec to arrive. I should have the motor by next Weds(01/25).
This ARF is a very simple build even for me!
Old Jan 21, 2006, 11:07 AM
gouda is offline
Is it summer yet?
gouda's Avatar
Joined Feb 2002
I am shooting for no more than 6.5 lbs. I just unpacked the plane to make it sure it was undamaged. I'll weigh all the bits later today. I happened to have the 2826/12, that's why I am using it. If I have it all figured out, I think I can get about the same power out of the /12 by using a slightly smaller prop.
I am doing a CG Cub ARF right now and using a Axi 4120 in that. It's larger, heavier and I plan on adding floats to it so the larger motor will be needed I figure.
You may like to check this thread on RCU out. Same plane as yours:
http://www.rcuniverse.com/forum/m_3607971/tm.htm
Old Jan 21, 2006, 11:45 AM
dogon1013 is offline
Find More Posts by dogon1013
Watts Rule, Glows Drool
dogon1013's Avatar
orlando, FL
Joined Mar 2003
wow, Eddy,
looks like you got alot done allready. You still want to head to the hobby shop later today. I'm waiting on a table delivery but after that comes I'll be heading to graves. I'll give you a call later.
PS isn't this a build thread, instead of discussion
dogon1013 is offline Find More Posts by dogon1013
Old Jan 25, 2006, 04:22 PM
dogon1013's Avatar
orlando, FL
Joined Mar 2003
I know you got your motor in.....how about posting a picture or 2...
Please
Old Jan 25, 2006, 05:48 PM
EzEd is offline
NTSB most wanted
EzEd's Avatar
O-Town, FL
Joined Jun 2003
Please
Alrighty then Toby.
Old Jan 25, 2006, 05:54 PM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Hi All!
I converted the Seagull variant last year. An AXI 4120/18 and 16xGP3300 cells brought the weight up to 9lb, but the big Dec flew beautifully.
There's a build thread here;
http://www.rcgroups.com/forums/showthread.php?t=336965
Just watch out for all those metal to metal joints at the inner ends of the struts, OK?
tim
tim hooper is offline Find More Posts by tim hooper
Old Jan 31, 2006, 05:58 PM
EzEd is offline
NTSB most wanted
EzEd's Avatar
O-Town, FL
Joined Jun 2003
Well, bummer. The Hyperion front mount I bought for the 4020 will not work with the model. The thrust line is high on the firewall and the mount sort of flares at the mounting points and is outside the top of the firewall. I'm gonna have to go with the rear mount and flip the motor.
Old Feb 13, 2006, 07:29 PM
dogon1013's Avatar
orlando, FL
Joined Mar 2003
Eddy,
I finished those spacers for your motor mount. I made them 12mm so you shouldn't need those washers.
i don't think i will be able to fly tomorrow after work though, but Wednesday's winds look OK.
Old Feb 15, 2006, 06:16 PM
EzEd is offline
NTSB most wanted
EzEd's Avatar
O-Town, FL
Joined Jun 2003
Well, got the motor mounted with the Hyperion backmount set and dang, the small length of the motor would not get out far enough for the cowling. Thus, Toby had to fashion the spacers noted in his previous post. Thanks Toby!
Here are a couple of shots of the motor partially mounted.
Old Feb 28, 2006, 07:20 AM
EzEd is offline
NTSB most wanted
EzEd's Avatar
O-Town, FL
Joined Jun 2003
Got a few more items completed last night. Its about 97% done. Only one more thing to do and that is to mount the battery somewhere. The deck behind the motor may not work due to CG issues.
Old Feb 28, 2006, 08:54 AM
gouda is offline
Is it summer yet?
gouda's Avatar
Joined Feb 2002
FYI, I upgraded from the 2826 to a E-Flite Power 45. I think it will work out better than the smaller AXI, since likely the plane will come out heavier than what I expect. Isn't that always the case?
Old Feb 28, 2006, 01:03 PM
EzEd is offline
NTSB most wanted
EzEd's Avatar
O-Town, FL
Joined Jun 2003
I think you'll like that choice. I've always thought that the 2826 would work but it would be at its max performance envelope.
Black Horse Matrix nxda Fuel Plane Talk 4 Apr 22, 2008 04:50 PM
Black Horse "Twister" ARF Blueline Fuel Plane Talk 8 Jan 28, 2006 01:02 AM
Black Horse Sukhoi Su-31 thunder1 Glow to Electric Conversions 17 Dec 16, 2005 01:30 PM
Black Horse Super Air Albatross Fuel Plane Talk 0 Jul 28, 2005 12:09 PM
FS:Black Horse Model Spitfire .40-.46 ARTF snolord1 Aircraft - Fuel - Airplanes (FS/W) 13 Mar 09, 2005 06:20 PM
