Old Jan 19, 2006, 05:37 PM
Talus is offline
Find More Posts by Talus
Joined May 2005
Question
Propeller Attachment Procedure?
Is the proper procedure to secure the prop to the shaft for an EPS 350c geared motor as follows?:
1. Hex nut
2. Washer
3. Prop (imprinted letters facing forward)
4. Hex nut (embedded in hexagonal recess of prop hub)
5. Spinner (just pushed onto the shaft? Not threaded?)
Both sides of the prop hub have recessed hexagonal depressions to hold nuts, so I'm puzzled. You couldn't have both nuts against the prop (one front & one behind), could you? How would you tighten it?
All this is new to me, and I haven't been able to find the prop attachment sequence in the plane's documentation or numerous searches here (which makes me fear that it is so intuitively obvious as to escape misunderstanding by all but me ).
I would appreciate anyone's instruction.
Thanks.
Talus is offline Find More Posts by Talus
Old Jan 19, 2006, 06:26 PM
ltz400 is offline
Find More Posts by ltz400
R & R=Rape and Rampage
ltz400's Avatar
United States, IL, Sheridan
Joined Apr 2004
Prop!
Hey Talus-welcome to RCGroup.
1 Hex nut
2 Prop
3 Washer
4 Hex nut
5 Spinner!
Hope that helps you get your bird in the air.Goodluck!!!!
ltz400 is offline Find More Posts by ltz400
Old Jan 19, 2006, 06:54 PM
Talus is offline
Joined May 2005
Thanks, Itz400, for clearing that up for me.
Old Jan 20, 2006, 06:25 PM
ltz400 is offline
ltz400's Avatar
Joined Apr 2004
Not a problem-Btw what GWS plane are you building? Be sure to post some pics when your done!!!
