Go Back   RC Groups > Aircraft - Exotic and Special Interest > Waterplanes
Old Jan 19, 2006, 04:27 PM   #1
alexcmag's Avatar
Conwing L-16 (SeaDuck)
Since my old CL215 crashed after a broken wing in flight and the MartinMars is too big for small lakes, I will start a new seaplane, probably at 60in wingspan. I like twins and never make a twin-boom twin, so looking for twins on net I found the Talespin airplane, a Conwing L-16 named "The SeaDuck".
alexcmag is offline Find More Posts by alexcmag   Reply With Quote
Old Jan 19, 2006, 04:35 PM   #2
alexcmag's Avatar
3-views and color scheme
  • Name: seaducktechnical.gif
  • Name: seaduck.jpg
Old Jan 19, 2006, 06:32 PM   #3
alexcmag's Avatar
Just decided the size... It will have 161cm wingspan (63in)
  • Name: seaducktechnical_161cm.gif
Old Jan 20, 2006, 10:05 AM   #4
IWC
I will be watching with great interest. Thanks in advance for sharing your building skills.
IWC is offline Find More Posts by IWC   Reply With Quote
Old Jan 20, 2006, 10:13 AM   #5
G G Ghost Pirates !!!
Vyceroy's Avatar
Send a message via ICQ to Vyceroy Send a message via AIM to Vyceroy Send a message via MSN to Vyceroy
the 3 views are not all to the same scale .. i ran across this when i had them enlarged .. This is on my todo list from Bluecor
Vyceroy is online now Find More Posts by Vyceroy   Reply With Quote
Old Jan 20, 2006, 11:15 AM   #6
alexcmag's Avatar
Really not... The front and top view are on same scale, the side view is larger, so I took most measures from top and front.
I printed the front-view enlarged to check the visual effect and liked a lot.
I am cleaning my modelling room to start it (need to fix my E-starter and link my Beech18 first), but will start it tonight probably.
Old Jan 20, 2006, 11:42 AM   #7
Vyceroy's Avatar
I will follow your build .. What material will you use to build it??
Old Jan 20, 2006, 01:39 PM   #8
alexcmag's Avatar
EPS foam (white insulation foam), normally used on office air conditioning installations and electronics equipment packaging.
It is cheap, light, easy to cut with hot wire, easy to sando to any shape, and floats by itself, I use on most parts of my airplanes.
Old Jan 20, 2006, 01:49 PM   #9
Vyceroy's Avatar
used it many years ago .. everything i do now is 5-6 mm insulation foam
Good luck .. cant wait to see your finished plane..
Old Jan 20, 2006, 05:11 PM   #10
Perpetual Hobbiest
cant wait to see it. i was tempted to build the same plane. i used to watch that show.
carlosponti is offline Find More Posts by carlosponti   Reply With Quote
Old Jan 23, 2006, 05:39 PM   #11
alexcmag's Avatar
Here we go...
The hull is in advanced state, now I am sanding the corners to make a better fit and gluing all together with hot melt glue.
  • Name: DSC08218.jpg
Description: First I printed the front view to scale to have a general idea of how will it look like.
I decided to make the hull flat-bottom.  Me and my friends have a trauma with coanda effect on round hulls... First I printed the front view to scale to have a general idea of how will it look like. I decided to make the hull flat-bottom. Me and my friends have a trauma with coanda effect on round hulls... 23.6 KB · Views: 828
  • Name: DSC08219.jpg
Description: Draw a side view copying the measures from drawing.  I used a calculator to transform measures from paper to foam and draw it with a large soft felt tip pen. Draw a side view copying the measures from drawing. I used a calculator to transform measures from paper to foam and draw it with a large soft felt tip pen. 14.9 KB · Views: 679
  • Name: DSC08220.jpg
Description: The lines were cut with a vertical hot wire cutter The lines were cut with a vertical hot wire cutter 23.8 KB · Views: 696
  • Name: DSC08221.jpg
  • Name: DSC08222.jpg
Description: And here is the drawing... And here is the drawing... 11.3 KB · Views: 651
  • Name: DSC08223.jpg
Description: Used the foam side wall as template to cut other side Used the foam side wall as template to cut other side 12.4 KB · Views: 434
  • Name: DSC08224.jpg
Description: Measured bottom view from side view Measured bottom view from side view 15.6 KB · Views: 498
  • Name: DSC08225.jpg
  • Name: DSC08226.jpg
Description: Cutted one side of forward tip to make template to other Cutted one side of forward tip to make template to other 18.1 KB · Views: 479
  • Name: DSC08227.jpg
Description: And here is the bottom And here is the bottom 14.8 KB · Views: 528
  • Name: DSC08228.jpg
Description: Make 3 internal walls...  One on wing leading edge, one to the wing trailing edge, one right after the windshields Make 3 internal walls... One on wing leading edge, one to the wing trailing edge, one right after the windshields 20.6 KB · Views: 445
  • Name: DSC08229.jpg
Description: Fixed all in place with tape to test the shapes Fixed all in place with tape to test the shapes 24.6 KB · Views: 560
  • Name: DSC08230.jpg
Description: Used the front of hull to make the template Used the front of hull to make the template 19.9 KB · Views: 520
  • Name: DSC08231.jpg
Description: And here is the front And here is the front 20.8 KB · Views: 507
  • Name: DSC08232.jpg
  • Name: DSC08233.jpg
Description: Used the fuselage back to make template to aft door. Used the fuselage back to make template to aft door. 14.6 KB · Views: 416
  • Name: DSC08234.jpg
Description: This is aft door on foam This is aft door on foam 22.2 KB · Views: 398
  • Name: DSC08235.jpg
Description: After cutted, I needed to reduce the width, so it can make a curve After cutted, I needed to reduce the width, so it can make a curve 24.4 KB · Views: 478
  • Name: DSC08236.jpg
Old Jan 23, 2006, 08:07 PM   #12
Vyceroy's Avatar
Nice progress .. keep it coming ..
Old Jan 24, 2006, 05:27 AM   #13
Electric only
rkopka's Avatar
See this:
http://people.freenet.de/punikaoase/...6349961f3.html
RK
rkopka is offline Find More Posts by rkopka   Reply With Quote
Old Jan 24, 2006, 06:34 AM   #14
alexcmag's Avatar
Originally Posted by rkopka
Thanks, very nice airplane.
I forgot to make the "rooftop" style deck in front of windshilds, to look an existent model is much better to make it then from comics.
The flat hull will make mine look like having a smaller nose. In the other way, it will stay horizontally in water without tip floats :P
I usually make some adjusts to avoid this effect, like decreasing the height, but in this case it os not possible, since the prop may touch the water...
Old Jan 25, 2006, 04:49 PM   #15
alexcmag's Avatar
New pictures from today...
Corrected the nose shape, glued all together but leaved hatches for internal access on front and over cabin.
This will provide me space to fit battery where needed to set CG and make entry points to fix-ups.
The fuselage will hold only the battery pack. Due to the twin tail boons, all servos will be fixed on wing, motors too, so the better place to receiver and ESC is on wing too...
  • Name: DSC01251.JPG
  • Name: DSC01252.JPG
  • Name: DSC01267.JPG
  • Name: DSC01268.JPG
  • Name: DSC01269.JPG
Spirit L-16 blade grips problem? vellodoro Electric Heli Talk 3 Apr 10, 2005 11:31 AM
where are the robbe L-16's ozace Electric Heli Talk 8 Jan 12, 2005 12:14 AM
RObbe Spiriti L-16 info ? kellydavid Electric Heli Talk 1 Oct 17, 2004 11:12 PM
Congratulations SimpleM!
