Old Apr 25, 2001, 10:19 AM
Derrek Curtis is offline
Find More Posts by Derrek Curtis
nashua nh 03060
Joined Dec 2000
T-33 Spring-air minis HW609
Greeting,
I have a NIB T-33, a set of Spring-air minis and an HW 609. I am thinking about buying an 920-4 to power this plane. Does anyone think that this will all work together. I'm thinking 8or9 cells (2400). The plane must rise off of grass. Any comments, suggestion, or sanity checks are appreciated
Thanks in advance
Derrek
Derrek Curtis is offline Find More Posts by Derrek Curtis
Old Apr 25, 2001, 10:46 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Hope Herb sees this, as he (I think) has done an Ultra/609 T-33; though hand/bungee launched.
Think he used 10+ cells and pulled 50 amps; was his fastest combo, but not his prefered (I think again).
Nose gear mounting shoulf be OK, wing mounting ??? Off grass???? Power and strength the big questions.
I say bungee launch and land with retracts; a servo operated retract might be able to work with a smallish servo when only used for extending retracts(?).
jrb is offline Find More Posts by jrb
Old Apr 25, 2001, 02:07 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Yes indeed I have a T-33 powered by and HW 609/Ultra 920-4 combination, and I fly it now on 12x2400 cells. I had to strengthen the wing significantly by fiberglassing so they would not bend and twist or fly off,
http://aeneas.ps.uci.edu/edf/t-33_ultra.jpg
It's quite heavy at 62oz, but I think I over-did it. Power in is around 12Vx55A=660 Watts, so I needed an ESC rated at 70 Amps.
It hand-launches fine (although sometimes I use a bungee as well),
http://aeneas.ps.uci.edu/edf/t-33_mwe.mpg (1.3MB)
To get the power of the Ultra, you need to draw quite a few amps, which means larger batteries unless you are willing to put up with a 1 min flight .
On the Ultra 920-4 you can use fewer cells (say 8 or 10) but then you might have CG problems (since the Ultra is kind of heavy) and ultimately after all that expense not that great a performance - it's all a trade-off.
The retracts (3 gears) would add quite a few more oz of weight, plus steerable nose gear, plus carving out that space in the nose...
I have been thinking about retracts in the T-33 as well (3x Robart minis), but more along the lines of a lighter setup with still lots of static thrust. Maybe an 1114/4y or 1010/2y or fun-480 -even in the Kyosho fan- might be more suitable due to the above weight considerations.
But maybe if you build yours light, reinforce the wing slightly (carbon fiber tape on bottom), use 1250 or cp1700 cells and keep the tot weight under 55oz it will be ok - or even better than ok!
Do look at Robert Wagoner landing gear conversion (non-retract) for the T-33,
http://ezonemag.com/articles/1998/jun/edf/edf0698.htm
http://209.180.123.24/clips/t331.avi
Herb is offline Find More Posts by Herb
Old Apr 25, 2001, 03:42 PM
p471701
p471701
Guest
n/a Posts
i did roberts conversion on mine and it works well.fixed gear with servo only added 1 3/4oz.
it's not a heavy duty set up but on a paved runway it works well.........gregg
Video Pneumatic Air Launches of T-33, Good,bad and Ugly! 3Deranged Electric Plane Talk 8 Nov 13, 2006 08:39 AM
T-33, Mega 22/20/2 and HW609 Kyri Electric Ducted Fan Jet Talk 11 Sep 09, 2003 02:30 AM
setting up a T-33 avie Electric Ducted Fan Jet Talk 7 May 04, 2001 11:11 AM
Kyosho T-33 Soarla Electric Ducted Fan Jet Talk 1 May 03, 2001 11:06 PM
T-33 w/tip tanks; any one fly with them? jbrundt Electric Ducted Fan Jet Talk 10 Apr 22, 2001 10:25 AM
