Old Jan 16, 2006, 08:17 PM
PROACE is offline
Find More Posts by PROACE
Rocky Mountain High and Higher
PROACE's Avatar
Joined Jan 2002
Fuel tank info for OS marine engine
OK experts I need some suggestions. I bought a new OS .21 RG-M and would like to know what a resonable size fuel tank would be. Also are there any tricks to keep foaming fuel from leaning out the engine during a rough run? Prop selections too if anyone has experience with this setup.
The boat is a Dumas Deep-Vee 20.
The engine is an OS .21 RG-M with a Macs tuned pipe.
Thanks all for any help.
PROACE is offline Find More Posts by PROACE
Old Jan 18, 2006, 11:41 PM
ernest2 is offline
Find More Posts by ernest2
all my boats are broken
ernest2's Avatar
manila
Joined Aug 2004
hi! i'm no expert. but from what i have read and what was suggested to me, an 8 oz dubro or sulluvan tank is good enough, thou that will still depend on the hull if it fits or not
ernest2 is offline Find More Posts by ernest2
Old Jan 18, 2006, 11:42 PM
Ron Olson is offline
Find More Posts by Ron Olson
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
8 ounces. Octura X-437 to X-440 or a Prather 215.
Seeing how it's going into a mono I bent the pick-up tube to the right rear corner, don't use the clunk. If you're really that worried about not picking up fuel then use a 1 or 2 ounce hopper tank.
Ron Olson is offline Find More Posts by Ron Olson
Old Jan 19, 2006, 06:32 PM
PROACE is offline
PROACE's Avatar
Joined Jan 2002
Thanks for the info. When it is finished I hope to post pics so I can get some constructive input before I take it out and sink it
Another question has come to mind also. Are the trim plates useful and how are they used correctly? What about balancing the boat is it like balancing a model airplane so to speak?
Old Jan 19, 2006, 11:02 PM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
Good questions.
Yes, trim tabs are definitely useful. Mount them 1/16" above the bottom of the hull, easy to do if you have a piece if 1/16" ply to use as a guide.
Yes, you basically balance them kind of like a plane except for the wing part.
If you go with the hopper tank, place that over your CG on the right side if you can.
Old Jan 20, 2006, 05:51 PM
PROACE is offline
PROACE's Avatar
Joined Jan 2002
So would I balance the boat at the center of (front to back)? Also I have seen boats bounce up and down on the front like a porpoise. Is that a balance or trim problem or just the nature of that particular boat? I will be breaking in engine when I run the boat for the first time so maybe I can trim the boat during the same time.
Old Jan 20, 2006, 10:54 PM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
Porpoising can be from several things, one is the balance being off, the strut being a little off vertically or at an angle. Start with everything with the driveline level with the bottom of the boat including the trim tabs. Your first runs might keep you busy getting everything dialed in from the carb to the prop. Take one step at a time.
Old Jan 21, 2006, 10:09 AM
PROACE is offline
PROACE's Avatar
Joined Jan 2002
Great info. Thanks, I really appreciate the help.
Discussion what size fuel tank to use on a 90 sized engine? spitfire123 Engines 3 May 09, 2006 09:36 AM
Question Fuel tank size for Saito 1.80 Mike_Then Engines 1 Jan 08, 2006 07:52 AM
Question Fuel Tank Setup For Inverted Flight efish 1/2A Planes 6 Nov 29, 2005 10:32 AM
Fuel tank location for 1/5th scale? SailplaneDave Fuel Warbirds 1 Jul 08, 2005 05:17 PM
Fuel Tank size for a Zenoah G.45 Pro Flyer Giant Scale Airplanes 3 Jun 06, 2005 03:23 PM
