Old Jan 16, 2006, 01:39 PM
segelflyg_anders is offline
Find More Posts by segelflyg_anders
Joined Dec 2005
Vacuum switch, where/how ?
Hi,
I've gotten my hands on a very nice vacuum pump with a 3-phase motor. It's a *bit* overkill but I got it for free, so...
It's one of those heavy duty rotary vane pumps, which is nice. Problem 1) is that it doesn't come with a vacuum tank and 2) that it doesn't have a presure regulated on/off switch. A solution to 1) is dead-simple, but problem 2) is a bit more intricate.
I've scanned the web for a few hours but cannot find anything suitable and obvious that would work at a moderate price. The closest I've gotten so far is a 1-phase (240V) switch directly actuated by the vacuum pressure at a semi-high US$70 (roughly). It is a bit on the high side though since it is not enough as a complete solution.
Does anyone have experience with solving this problem ? All input is appreciated.
Anders
segelflyg_anders is offline Find More Posts by segelflyg_anders
Old Jan 16, 2006, 04:37 PM
jcyr1 is offline
Find More Posts by jcyr1
United States, AZ, Surprise
Joined Jul 2002
Anders,
CST sells vaccuum switches, they are not rated for that pump. Solution is to use the switch to drive a relay or solid state switch tha can handle the current used by the pump. That way the switch would only handle the current of the relay.
John
jcyr1 is offline Find More Posts by jcyr1
Old Jan 16, 2006, 05:21 PM
rcjunkie is offline
Find More Posts by rcjunkie
SEFF Contest Director
rcjunkie's Avatar
USA, GA, Stone Mountain
Joined Oct 2000
The CST switch will work like jcyr1 said with the relay and will cost about $35-40.
Also to take care of the vacuum tank issue, I used an empty Helium tank on my setup and drilled a hole thru the case and screwed in a fitting with RTV around it to make sure it was sealed. It works great and cheap. Some people use a section of 4-6" PVC pipe with endcaps on it and make a vacuum tank out of it.
Ernie Schlumberger
rcjunkie is offline Find More Posts by rcjunkie
Old Jan 17, 2006, 04:41 AM
chetosmachine is offline
Find More Posts by chetosmachine
chetosmachine's Avatar
Madrid, Spain
Joined Sep 2004
Hi,
i'm working on my pump and have a pair of questions:
-i bought a vacuum switch which i want to operate through a relay. Does anyone have a scheme of the connection?
-i have an empty gas can. It's from a torch, and is around 15" tall * 4" diameter. Does it have the right size or is it small?
thank you,
Chets
chetosmachine is offline Find More Posts by chetosmachine
Old Jan 20, 2006, 11:42 PM
fishinrflyin is online now
Find More Posts by fishinrflyin
RussMc
Olympia WA
Joined Nov 2004
I looked all over when I was trying to find a vacuum switch. Check out the vacuum switches sold by Digi-Key. The one I use (part # 384-1009-ND) is rated at 25A and can be set from 6" Hg to 24" Hg (81" to 330" H2O). You shouldn't have to use a relay with the switch and the Best thing about it - it cost $16.24 + $5.00 S&H.
Look at the bottom of the page for the World Magnetics Pressure (& vacuum) switches.
http://dkc3.digikey.com/PDF/T061/1703.pdf
Digi-Key home page is http://www.digikey.com/
When you choose a vacuum tank, remember that you will want the most capacity that you can reasonably get away with. The reason is you are only working from 0.0 to 1.0 atmosphere (or 0.0 to 14.7 psi), unlike the normal range of compressors which operate over several times atmospheric pressure (100 psi is almost 7 atmospheres). I set up my system with a 6' length of 4" PVC pipe, which works OK but if you get a leaker vacuum bag, the cycle time on the vacuum pump is still noticeably short.
Good Luck
Russ
fishinrflyin is online now Find More Posts by fishinrflyin
Old Jan 27, 2006, 04:21 PM
qv_ is offline
qv_
Find More Posts by qv_
qv_
Sweden
Joined Nov 2005
I have not build my yet. But I like to use the vacuum part from a car engine.
The vacuum bell that adjust the timing of the spark.
Just add a spring and a switch.
/jan
qv_ is offline Find More Posts by qv_
Old Jan 31, 2006, 12:13 AM
jkswong is offline
Find More Posts by jkswong
Melbourne, Australia
Joined Dec 2004
G'day, have you guys sussed out the diagram on the ACP website. I was able to follow this for connection of the relay switch and associated wiring.
http://www.acp-composites.com/vacuum-switch.html
Also they have Vac switches for $39US. Works pretty well in my set up.
Jason
jkswong is offline Find More Posts by jkswong
Old Jan 31, 2006, 09:45 AM
AgoMago is offline
Find More Posts by AgoMago
Tarzanstyle English Sorry
AgoMago's Avatar
Cittadella(PD)(Italy)(Europe)(World)
Joined Nov 2004
Home made vac switch
I solve the problem in that way!
And only 2 $ !!!!!!
Ago
AgoMago is offline Find More Posts by AgoMago
Old Jan 31, 2006, 11:42 AM
pinolefm1 is offline
Find More Posts by pinolefm1
Permanently Banned
pinolefm1's Avatar
Joined Aug 2005
And only 2 $ !!!!!!
Ago
Very ingenious...Rube Goldberg would've been proud
Steve
pinolefm1 is offline Find More Posts by pinolefm1
Old Feb 03, 2006, 12:52 AM
ThermalSeeker is online now
Find More Posts by ThermalSeeker
United States, CO, Denver
Joined Sep 2005
lid Flex ?
The vacuum causes the lid to flex enough to trigger the microswitch ?
MikeN
And only 2 $ !!!!!!
Ago
ThermalSeeker is online now Find More Posts by ThermalSeeker
Old Feb 04, 2006, 04:35 AM
HELModels is offline
Find More Posts by HELModels
HELModels's Avatar
Joined Aug 2003
That is too efficient to be Rube Goldberg. Rube was forced to study engineering and chose to be an artist.
It must switch off when the vacuum is highest, so the switch would lose contact. That would require the jar to be glued to the base, for the flexing of the lid to control the contact. Evacuating the jar causes the lid to want to cave in, i.e., flex down switch off. The spring provides tension to delay the flexing down and encourage the flexing up? The tension is adjustable, if you look closely. ??????? Choose the wrong spring and it wont work?
Looking at the arrangement of the tubing, is critical to understanding this rig.
I imagine a venturi effect putting pressure on the jar, causing the jar to lose contact with the switch, but when? When the vacuum is building or after?
Maybe Tarzanenglish can explain.
Unlike Rube, I studied Art first and can only admire engineering.
HELModels is offline Find More Posts by HELModels
Old Feb 04, 2006, 09:32 PM
A6INTRUDER is offline
Find More Posts by A6INTRUDER
Portland Intl, Oregon, United States
Joined Jul 2003
I posted this quite a while ago but here is where I found a place to get vac switches
not sure if they have any 3 phase or not but you might check them out.
this is a repost of my response to another question about vac set ups....
I found a place to get the same vac switch sold at one of the composites stores for less than half price.
air-logic.com
look in their subminature vac switch section, the one I like is
V-5100 28 FM B85 25a
it is variable from 3-28 inches of vac and can be bought at 15 amps or 25 amps
(thats the 25a number at the end).
Air logic only sells wholesale, but if you call them they will tell you where the nearest
dealer is.
good luck
TIM
A6INTRUDER is offline Find More Posts by A6INTRUDER
Old Feb 05, 2006, 12:56 AM
HELModels's Avatar
Joined Aug 2003
And only 2 $ !!!!!!
Ago
Ago,
Is the glass jar firmly attached to the wooden base? I can see that you sealed the connection to the lid, so eVacuating the jar must be the goal.
Is it the flexing of the lid that controls contact?
where can I get a vacuum switch ? yclui The Builders Workshop 0 Oct 16, 2002 12:14 PM
Where and how is CA glue made? LJH Electric Plane Talk 13 Jan 24, 2002 08:24 AM
Need a vacuum switch GoodTill Electric Plane Talk 4 Nov 01, 2001 01:49 PM
Optical Stabilizer, where and how? Haro Electric Heli Talk 4 Oct 26, 2001 12:15 PM
2000 NiMH Where & how much? billchas Power Systems 9 May 13, 2001 12:41 AM
