Old Jan 16, 2006, 06:31 AM
zmonte is offline
Find More Posts by zmonte
I just can't wait !
zmonte's Avatar
Joined May 2004
Found the elusive 12T 2.3 mm pinion
After extensive searching for a 12T 2.3 mm pinion for my Steve neu motors I finally have found it with the proper pitch mesh also.
Even though it states a 2mm shaft mount that is a misprint it is actually a 2.3 which I presumed I have received them and they fit perfectly
http://www2.towerhobbies.com/cgi-bin...?&I=LXLBN1&P=6
zmonte is offline Find More Posts by zmonte
Old Jan 16, 2006, 06:56 AM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
That makes sense.
The MX400 uses a Speed 400 motor with a 2.3mm shaft, so all the motor pinions would be 2.3mm bore.
Cool. I will add that to the next version of the EHBG! Thanks for posting the info!
Toshi
TMorita is offline Find More Posts by TMorita
Found 2.3 mm 9 tooth pinion for T-Rex RobDog Aircraft - Electric - Helis (FS/W) 2 Apr 11, 2006 01:51 PM
WTB: GY240, Berg 5 DSP, etec 1200 3s, 2.3 mm pinion 11T microflite Aircraft - Electric - Airplanes (FS/W) 0 Oct 18, 2004 12:51 PM
Outlet for a 9 tooth 48 pitch 2.3 mm pinion for a Shogun rickc Mini Helis 6 Jun 10, 2004 09:23 AM
Putting a GWS 300C - D pinion on a 2.3 MM Shaft boomerace Power Systems 3 Feb 06, 2004 02:14 PM
wemotec speed 300 on 2.3 mm dave morris Electric Ducted Fan Jet Talk 1 Jun 16, 2001 06:39 PM
