Old Jan 15, 2006, 10:20 PM
THUREN is offline
Find More Posts by THUREN
blah...
THUREN's Avatar
United States, OR, Bend
Joined Jun 2005
Servo gear strength. Micro metal vs. standard nylon
I searched around a bit with no concrete answers... So here's some questions..
Would a sull size NYLON GEAR servo, with similar torque specs to to a micro METAL GEAR servo, have a similar gear strength? It wouldn't seem that the nylon could hold up as well as the metal but I remember reading it somewhere that full size regular servos nylon gear sets are of comparable strength. Here's an example as I have a radio coming with 5 of these JR digitals...
NES537,
Specs
Torque: 40.3 oz/in
Speed: .25 sec/60
Dimensions: 0.73 x 1.52 x 1.32in
Weight: 1.58 oz
Bearing: single
Motor Type: 3-Pole Ferrite
compare that to say........
HS85MG's....
Torque 42oz
Speed .16 second
Size : 1.1"x 0.5"x 1.1"
Weight - 0.77 oz
I have the JR digitals coming for "basically" free with the radio but I don't know if the gears are worth much... I don't want to bury these servo's in a EPP plank if I'm just going to be digging em' out after 2 flights...
THANK YOU!!!
Don
THUREN is offline Find More Posts by THUREN
Old Jan 16, 2006, 10:02 AM
mlee8249 is online now
Find More Posts by mlee8249
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Hi Don,
One of the things you have to consider in this formula is that metal geared servos do not have the same size gears and gear ratios as the same or similar servo with nylon gears. So, the relative "strength" of the material is somewhat lost in this question you have. In general a metal gear servo has superior strength. Most manufacturers will place at least one of the gears in there as a nylon gear to protect the electronics and motor from damage in the event of a severe shock to the servo, (like hitting the ground). They would rather you break the gears than to destroy the rest of the servo and have intact gears.
Normally, the rule of thumb is that for harsh service environments, use a metal gear servo. They are more robust and can handle more abuse. When they do strip a gear, the gears may cost you more. You should also consider that if you do strip the gears, can you buy new ones very easily? If not, not only will you be digging out the striped servos, but you'll be down longer than you might want to be.
Mike Lee
mlee8249 is online now Find More Posts by mlee8249
Old Jan 16, 2006, 10:30 AM
ouluckydogu is offline
Find More Posts by ouluckydogu
Joined Feb 2004
I would tend to use the digital servoes because in a plank type plane the servoes need to center very well. I have had trouble with my bluto and my halfpipe with centering issues with Hitec 85 metal gear servos. Planks are very touchy with elevator changes so I think the centering power of digis might be in order. I am waiting for someone to come out with inexpensive digital servoes with metal gears with the size of minis or mids
ouluckydogu is offline Find More Posts by ouluckydogu
Old Jan 16, 2006, 11:18 AM
Rodney is online now
Find More Posts by Rodney
Florida
Joined Aug 2004
In general, metal gears are stronger but metal gears also develope slop and wear much faster than nylon gears do. Unless you are pushing gear strength, nylon gears will give you longer and more slop free service.
Rodney is online now Find More Posts by Rodney
Old Jan 16, 2006, 08:22 PM
THUREN is offline
blah...
THUREN's Avatar
Joined Jun 2005
Thanks everyone!!!
I know that micro size nylon gear servos can strip almost by themselves... Are standard size servos as touchy? Some of these servos could be going in a combat-type wing if they could stand a few knocks...
I guess I'd just have to try it...
Discussion Waypoint W-092MB High Torque Metal Gear Sub-Micro 9.2G Servo? Sonex128 Mini Helis 1 Jan 30, 2007 04:05 PM
FS: Futaba S9206 Servo Heli Hi Torque Metal Gear Jason WAI Aircraft - General - Radio Equipment (FS/W) 5 Sep 12, 2004 09:37 PM
GWS Micro Metal Gear Servos--Anyone using? DavidJ GWS (Grand Wing Servo) 6 Aug 21, 2004 08:27 PM
Hitech servo gear question will the hs81 metal gears fit into the hs81 Sloop Radios 3 Feb 02, 2004 03:58 PM
GWS micro metal servo ??? Dugman Radios 0 May 20, 2003 12:44 AM
