Old Jan 14, 2006, 12:59 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
eddy current effect demo videos
Some nice videos demonstrating the huge effect of eddy currents (a.k.a. Foucault currents) and the benefits of statorlamination (insulated thin sheets of iron, not a massive iron stator/transformer) or even rotor/magnet 'lamination'.
Eddy current losses explained
en.wikipedia.org/wiki/Eddy_current
Magnet falling through metal pipe
www.wimp.com/copperpipe/
Effects of laminations:
demoroom.physics.ncsu.edu/html/demos/163.html
Eddy current brake:
demoroom.physics.ncsu.edu/html/demos/192.html
More eddy current demos under '5K20'
demoroom.physics.ncsu.edu/html/electricity_and_magnetism.html
groups.yahoo.com/group/lrk-torquemax/message/14
groups.yahoo.com/group/lrk-torquemax/message/166
www.vuw.ac.nz/scps-demos/Demos/Pira5K/EddyCurrentTubes/Aluminium.mp4
www.supermagnete.de/eng/project66?switch_lang=1
www.engconcepts.net/
-> SuperMagnetMan Magnet University.
-> Magnet Brakes its Own Fall
and
-> Magnet Braking System
DIY eddy brake dynamometer design for testing e-motors
www.aerodesign.de/peter/2001/LRK350/index_eng.html
-> bottom of that page
-> EM 4/2001 Performance Measurements on Electric Motors
Something you can do yourself. Just let a Neodymium magnet slide down a metal (non-ferrous) tube or a length of angled metal and then let it slide down a plastic tube and see the difference. First an aluminium ring than a magnetic ring
video.google.com/videoplay?docid=1660843971041561797&q=neodymium&hl =en
Demo in MRI scanner
MRI MAGIC (0 min 15 sec)
Vriendelijke groeten Ron
diy motor building tips & tricks
diy outrunner discussion group
int. E fly-in & diy outrunner meet, June 25 2006, Nijmegen, the Netherlands
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jan 14, 2006, 11:30 PM
ScubaSteve is offline
Find More Posts by ScubaSteve
Maryland
Joined Nov 2003
Great info. Thanks Ron.
ScubaSteve is offline Find More Posts by ScubaSteve
Old Jan 15, 2006, 10:34 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
Where is Inewton to talk about magnet gear ratios???
fly_boy99 is offline Find More Posts by fly_boy99
Old Jan 16, 2006, 07:56 AM
INewton is offline
Find More Posts by INewton
Massachusetts
Joined Jan 2006
Hey fly_boy99,
After seeing Ron's great demo, are you now going to keep all your aluminum parts out of the magnetic path?
To keep things a bit simpler for you the best way to identify magnetic loss is by spinning the motor with a high speed grinder motor (I read that somewhere) and finding out what parts get hot.
To fix the 283, you need to modify the bearing tube, laminate the flux ring and use two half magnets,14x3 mm, instead of a full 14x6.
Then to keep the peak magnetic (and current) pulses down to the lowest level, switch from a wye to a delta.
Or, do you prefer flying with a motor/toaster?
INewton is offline Find More Posts by INewton
Old Jan 16, 2006, 11:44 AM
fly_boy99's Avatar
Don't have a 283 and mount my stators with CF...
How you like those apples???
I have not found one person on RCG that believes in your magnetic gear ratios either!!!
Old Jan 16, 2006, 01:33 PM
Joined Feb 2001
Originally Posted by INewton
... After seeing Ron's great demo, are you now going to keep all your aluminum parts out of the magnetic path?...
Or any other conductor/metal. But there's no problem if the metal does not move in the magnetic field.
Old Jan 16, 2006, 02:04 PM
INewton is offline
Massachusetts
Joined Jan 2006
OR the magnetic field doesn't vary!
Old Jan 19, 2006, 02:37 PM
Joined Feb 2001
Something you can try yourself. Just let a Neodymium magnet slide down a metal tube or a length of angled metal and then let it slide down a plastic tube and see the difference.
Old Apr 19, 2008, 11:30 AM
Joined Feb 2001
Added a few videos of demos.
Old Apr 25, 2008, 09:29 PM
NX-687 is offline
Find More Posts by NX-687
Joined Aug 2007
Hi
Hey fly_boy99,
Were you serious when you said laminate the flux ring , because that was poo ,pooed in a discussion a few months back
NX-687 is offline Find More Posts by NX-687
Old May 29, 2008, 02:36 PM
Joined Feb 2001
Added:
http://www.supermagnete.de/eng/project66?switch_lang=1
Old Jul 14, 2009, 05:29 PM
Joined Feb 2001
Eddy currents explained:
http://en.wikipedia.org/wiki/Eddy_current
Old Jul 29, 2009, 10:39 AM
Joined Feb 2001
Added to first post
http://www.engconcepts.net/
and
Old Jul 29, 2009, 10:41 AM
Joined Feb 2001
Added
http://www.aerodesign.de/peter/2001/...index_eng.html
Old Jul 29, 2009, 11:10 AM
pullin-gs is offline
Find More Posts by pullin-gs
Arlington,VA USA
Joined Jan 2001
I won a $5 bet with my kids that my "magic" metal cylinder would take 10x longer to pass through an aluminum tube than a another "regular" metal cylinder!
Like taking candy from a baby!.
pullin-gs is offline Find More Posts by pullin-gs
Yippee! Reflex (XTR) Demo Videos jerrysimon Simulators 5 Mar 07, 2004 10:16 PM
