Old Jun 10, 2002, 08:53 PM
Tim H. is offline
Find More Posts by Tim H.
FoamyFactory.com
Tim H.'s Avatar
USA, TX, Fort Worth
Joined Nov 2001
Kontronik Fun-400-36 in a ProJeti
I'm thinking about putting a Kontronik BL Fun-400-36 with an 8 cell CP1300 pack and a 5.5x4.5 CAM Speed prop in a Projetti.
The 400-36 has a kv of 3600 (rpm/v). The Mega 16/15/3 has a kv of 3000. What do you guys think?
The only reason for the 400-36 is because I have one sitting here on my bench for a MF480 that is not being used. Think this is overkill, or will it work. Dimentions on the Kontronik are identical to the Mega 16/15/3. I may put this combo in my Zagi 400x first to test the waters...
Tim H
Tim H. is offline Find More Posts by Tim H.
Old Jun 11, 2002, 01:32 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
The FUN400-36 is too hot for effcient direct drive, but if you want to try it, ensure your ESC and your batteries are up to the task providing the current. Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jun 11, 2002, 11:28 AM
Tim H. is offline
FoamyFactory.com
Tim H.'s Avatar
USA, TX, Fort Worth
Joined Nov 2001
That's kind of what I thought, kv a little too hot...
Tim H.
Old Jun 11, 2002, 01:25 PM
JasonJ is offline
Find More Posts by JasonJ
Dude, where's My Plane?
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
Well the KV is a factor of the cells, On 8 cells the 400-36 is only in the 200W range I think, so it sould be fairly tame, the 1300s should be up to it, and you will have an efficent light weight setup with good durration that should cook in the ProJeti.
JasonJ is offline Find More Posts by JasonJ
Old Jun 11, 2002, 02:18 PM
Joined Sep 2000
My FUN400-28 with Cam 5.5x4.3 prop already draws 25A on 8 cells! The 400-36 will (want to) draw a lot more! Jürgen
Old Jun 11, 2002, 04:15 PM
JasonJ is offline
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
Well, you can always add two more cells and drop the MF 480 in it!
Sold Kontronik Fun 400-36 with 3.7 Planetary Gear plasmaman Aircraft - Electric - Power Systems (FS/W) 4 Sep 19, 2006 10:51 AM
Sold Kontronik Fun 400-36 w/3.7:1 pgb Al P Aircraft - Electric - Power Systems (FS/W) 6 Jul 20, 2006 04:33 PM
Wanted Looking for a Kontronik Fun 400-36 w/4.2:1 Gear Drive finishman2000 Aircraft - Electric - Power Systems (FS/W) 1 Feb 05, 2006 07:16 AM
Kontronik fun 400/36 motor and ESC Steve H. Aircraft - Electric - Airplanes (FS/W) 12 Jun 08, 2004 10:15 AM
FS Kontronik Fun 400-36 termite Aircraft - Electric - Airplanes (FS/W) 1 Jun 01, 2004 06:40 PM
