Old Jan 11, 2006, 10:11 PM
Simon Robbins
Simon Robbins
Guest
n/a Posts
Reflex XTR gyro setup with Futaba T8UHFS (FF8) help?
Can anyone give me some pointers on how to set up the gyro gain properly
with Reflex XTR on my Futaba T8UHFS (FF8) controller?
I want to use switch F, which I've set in the radio, and set the ATV gains
to their fullest extents (which it only lets me set to 30% - 100%). Then
I've set Gyro Up to 100% and Down to 0% in the controller's advanced menu.
However, I can't get the Reflex gyro response to behave other than in
heading hold. Also, where should I set the channel 5 (gyro) to 50% so that
Reflex calibrates it properly?
This all seems a little more complicated than it should be.
(Plus I wish there was a way of disabling Reflex's auto-control setup
everytime I want to assign channels..)
Si
Nigel Heather
Nigel Heather
Guest
n/a Posts
Re: Reflex XTR gyro setup with Futaba T8UHFS (FF8) help?
This is how I have my FF8 set up with XTR.
Gyro set to channel 5 as you have done.
Leave the ATVs for channel 5 at 0% and 100%.
Assign Switch F to channel 5 as you have done.
On the radio advanced menu (i.e. press the bottom two buttons together)
Scroll to GYRO and check the following settings Up = 100%, Down = 100% and
SW-F
On XTR disply the select the channel display (F8) and check the operation of
Switch F
Operating it should toggle between -100% and +100% on the display. This
won't be exact depending on calibration, but should be somewhere near.
Now on the radio set the GYRO parameters as desired - I use Down = 20% (i.e
80% rate) and Up = 80% (i.e. 80% rate).
Check this has an effect on the channel display.
Calibration - you can't centre channel 5 so don't bother - you are only
interested in one position being +100% and the other being -100%.
Cheers,
Nigel
The OTHER Kevin in San Diego
Guest
n/a Posts
On Wed, 11 Jan 2006 16:34:03 -0000, "Simon Robbins"
(sorry Si, but I'm gonna hijack part of your thread..heheh)
Can't help ya, but was wondering if anyone's got a good starting point
for Reflex and the 9CHFS radio - I'm thinking Relfex is going to be my
next sim purchase...
Thx..
Simon Robbins
Simon Robbins
Guest
n/a Posts
"The OTHER Kevin in San Diego" <skiddz "AT" adelphia "DOT" net> wrote in
message news:liqas1h86g7rssal2svq65kb3hdqbg5qa0@4ax.com...
Get orf moi thread ya varmit! :-)
Si
Simon Robbins
Simon Robbins
Guest
n/a Posts
"Nigel Heather" <No-Spam@No-Spam.com> wrote in message
news:h-2dnc1QgOMt_ljenZ2dnUVZ8qadnZ2d@pipex.net...
<snip>
Fantastic. Thanks Nigel.
Si
Discussion Reflex xtr gyro EMAXXER101 Simulators 2 Nov 26, 2006 06:25 PM
Sold Reflex XTR flight simulator with Futaba and JR cables Steve H. Aircraft - General - Radio Equipment (FS/W) 6 Sep 28, 2005 08:31 PM
F/S Reflex XTR Flight Simulator (Square Futaba Ver) Lv2Fly Aircraft - Electric - Airplanes (FS/W) 2 Dec 20, 2004 07:26 AM
Question ECO 120 setup with Futaba 9CHP sjgusmc21 Electric Heli Talk 2 May 13, 2004 03:12 PM
