Old Jan 10, 2006, 10:36 PM
JKA is offline
JKA
Find More Posts by JKA
JKA
Iowa
Joined Jan 2006
Question
4 in 1 not arming until after several connects to the battery.
For some reason my 4 in 1 is not arming properly until the battery has been connected for several minutes. Multiple disconnects and reconnects later it finally arms. Anybody? ideas? replace it?
JKA is offline Find More Posts by JKA
Old Jan 10, 2006, 11:11 PM
ktmrider is offline
Find More Posts by ktmrider
Joined Sep 2005
I have the same problem! I have to resort to tapping the 4in1 so that it can arm.
Once in a while, the heli would just drop while flying because the 4in1 shutdown!
ktmrider is offline Find More Posts by ktmrider
Old Jan 11, 2006, 12:00 AM
GaryL is offline
Find More Posts by GaryL
Novice
USA OHIO
Joined Nov 2005
I would think that there must be a loose connection. Check your plugs and make sure they are pushed in all the way.
GaryL is offline Find More Posts by GaryL
Old Jan 11, 2006, 02:02 AM
Buda is offline
Find More Posts by Buda
Joined Jan 2005
same here, but for me it's because of the temp out side, i get frequency drift in the Illinois weather at present. (confermed with scope) inside it works great, take it out side last 1 maybe 2 min then drops.
Buda is offline Find More Posts by Buda
Old Jan 11, 2006, 07:10 AM
JKA is offline
JKA
JKA
Iowa
Joined Jan 2006
I will take it apart when I get home and see if there are any cold solderings on the board. Might even make an experiment to hit it with the hair dryer before connecting the battery to see if it is heat related.
Old Jan 11, 2006, 07:15 AM
Tintin is offline
Find More Posts by Tintin
Tintin's Avatar
Akershus, Norway
Joined Mar 2005
Sure it's not xtal related, common...
Tintin is offline Find More Posts by Tintin
Old Jan 11, 2006, 07:35 AM
JKA is offline
JKA
JKA
Iowa
Joined Jan 2006
Tintin,
Crystal related?
Old Jan 11, 2006, 08:54 AM
Tintin is offline
Tintin's Avatar
Akershus, Norway
Joined Mar 2005
How is it blinking when it does not arm?
Normal procedure is blinking red, blinking green, steady green.
Does it keep blinking red or green or does it start to alternate red/green.
It it starts to blink red/green this is either a sign of no radio contact or that your throttle or throttle trim is not lowered completely.
No radio contact might be loose xtals, damaged xtals or bad batteries in tx.
Old Jan 11, 2006, 09:29 AM
peter frostick is offline
Find More Posts by peter frostick
peter frostick's Avatar
south shields. England
Joined May 2004
As buda suggests it might be caused by a comfortably enclosed warm Tx crystal trying to control a very exposed thus quickly cooling Rx crystal??
Peter
peter frostick is offline Find More Posts by peter frostick
Old Jan 11, 2006, 12:20 PM
ktmrider is offline
Joined Sep 2005
My problem goes away when I remove the canopy. So this crystal is the problem?
Old Jan 11, 2006, 12:48 PM
JKA is offline
JKA
JKA
Iowa
Joined Jan 2006
I turn on the TX and then fire up the cx. The lights keep blinking red/green and some time the servos move just a tad but it never goes to solid green until after a bunch of reconnects of the battery, then suddenly I see the servos centering and the light goes solid green. It is weird. Once it is armed it will never loose it, I can even change battery and start it up again without any problems. Maybe it is my radio controller that is the problem.. Should maybe take it down to hobbytown and see if we can get it to arm with a different tx.
Old Jan 11, 2006, 12:51 PM
JKA is offline
JKA
JKA
Iowa
Joined Jan 2006
Hey, Tintin just noticed your location.. I'm originally from Göteborg, Sweden. Lived in the US for over 15 years by now though.
Thanks for all the input guys. I will dig in it a little more when I get home tonight.
Old Jan 12, 2006, 01:16 AM
benson100 is offline
Find More Posts by benson100
file sharing is illegal
benson100's Avatar
Peoria Illinois
Joined Dec 2005
Hey I know a buda,I live bout 30 miles south of Peoria.Where you from Buda???
benson100 is offline Find More Posts by benson100
Old Jan 12, 2006, 08:47 AM
JKA is offline
JKA
JKA
Iowa
Joined Jan 2006
I now have figured out that it is heat related.... I took the front body off and started flying and the tx lost connection with in the minute. Did the same thing again and the tx yet again lost the connection. I put the front body back on and it flew just fine. The down wash is cooling off the 4 in 1 and shuts down. Calling horizon.
Help! BCX 4 in 1 flashing Green and Red after Crash brocja01 Coaxial Helicopters 4 Oct 16, 2006 10:48 AM
Discussion SOLD Blade CP 4 in 1 , TX , motor , battery , charger copperclad Micro Helis 0 Jul 29, 2006 02:58 PM
Help! Lama 4 in 1 chip falls off after hard landing!--with pictures nuv22 Coaxial Helicopters 6 Jul 16, 2006 03:21 AM
4-in-1 question? Brand new and not working.. neuroblade Micro Helis 3 Aug 10, 2005 03:40 PM
4-in-1 Board nheather Micro Helis 4 Jul 16, 2004 05:45 PM
