Old Jan 09, 2006, 09:57 PM
TonyBAMF is offline
Find More Posts by TonyBAMF
Sureflite
TonyBAMF's Avatar
Joined Jan 2006
looking for a DIY tutorial.
I am trying to find info on toturial on how to make a plane from scratch (the body not the electronics) prefeably a trainer type plane.
thanks a bunch
TonyBAMF is offline Find More Posts by TonyBAMF
Old Jan 09, 2006, 10:22 PM
BIGDANO is offline
Find More Posts by BIGDANO
AMA #851612
BIGDANO's Avatar
Alameda, CA
Joined Dec 2005
There are a ton of scratch build plans available online. You should be able to find some links by searching these forums.
Have you built from schematics/CAD drawings before? I was interested (and still am) in doing a scratch build, but was highly encouraged to build a kit first. Kits come with everything pre-cut, usually by laser, so it's pretty precise.
I'm going to do a kit first, then think about a scratch build.
BIGDANO is offline Find More Posts by BIGDANO
Old Jan 09, 2006, 10:28 PM
TonyBAMF is offline
Sureflite
TonyBAMF's Avatar
Joined Jan 2006
I actually want to find info on how to make/design/build my own.
Old Jan 09, 2006, 11:55 PM
TrappedinNM is offline
Find More Posts by TrappedinNM
All posts Copyright '07
Joined Sep 2004
Pick a basic design. For a basic parkflyer, follow these "rules":
Distance between motor and leading edge of wing: .75 mean chord length. For example, if your wing is 6" wide, the wing would sit back ~4.5"
Wing aspect ratio of ~4:1 to 5:1.
Ailerons ~15% of wing area.
Stabilizer ~20% of wing area.
Elelvator ~35% of Stabilizer.
Fuselage length from trailing edge of wing ~1.5 to 2 times chord to middle of elevator.
Factor in construction type, weight, wing loading, etc.
Start by trying to build from scratch a proven design - say a SS, but with a built-up wing. Then move up the food chain.
TrappedinNM is offline Find More Posts by TrappedinNM
Old Jan 10, 2006, 02:04 AM
TonyBAMF is offline
Sureflite
TonyBAMF's Avatar
Joined Jan 2006
Hey thanks I will try that out.
Is there some place with the raw math to making model planes?
Old Jan 10, 2006, 02:43 PM
will_newton is offline
Find More Posts by will_newton
wishes this caption was longe
will_newton's Avatar
wilson, nc, usa
Joined Dec 2005
hi,
scroll down on the rcgroups home page!
http://www.rcgroups.com/forums/forumdisplay.php?f=136
there's the aircraft modeling science forum.
will_newton is offline Find More Posts by will_newton
Old Jan 10, 2006, 03:34 PM
David Hipperson is offline
Find More Posts by David Hipperson
Kilsyth, Victoria, Australia
Joined Oct 2003
Tony, If you can find a copy through one of the S/H bookstores buy a copy of Gordon Whitehead's "Scale Aircraft - Models for everyday flying". Though you are asking about trainers this book covers everything including basic design, airfoils, CG location and construction techniques. Thing to bear in mind is that it was written 26 years ago and for IC power. Nevetheless, it is a first rate overall guide and I still refer to my copy even though I've been building for 50+ years. Good Luck
David Hipperson is offline Find More Posts by David Hipperson
Old Jan 10, 2006, 04:53 PM
Electric_D is offline
Find More Posts by Electric_D
Herriman, Utah
Joined Aug 2005
Another book is "Aircraft Workshop: Learn to Make Models that Fly", by Kelvin Shacklock. There are plans for a good high-wing trainer and gives you a list of the materials you will need. He takes you step-by-step through building the plane. This book does goes through some of the basics of model design (not real in-depth), but gets you building plans from scratch.
Electric_D is offline Find More Posts by Electric_D
Old Jan 10, 2006, 04:56 PM
rutat is offline
Find More Posts by rutat
Joined Mar 2004
Design Guidelines for Electric Powered Model Aircraft (from Maxcim.com)
Select model and scale (or size).
Determine wing area in square feet (span in inches x avg. chord in inches / 144).
Work out total weight for desired wing loading:
For typical 05 to 40 sized models:
Less than 15 oz/sq.ft for a floater
15-20 oz/sq.ft for a cabin sport model/trainer
20-28 oz/sq.ft for a sport low wing, 30's, warbird, etc.
Over 30 oz/sq.ft - You're on your own!
Determine power input required:
Level Flight: 25 to 30 Watts per pound.
ROG off smooth surfaces, reasonable climb: 40 to 50 Watts per pound. (ROG = Rise Off Ground)
ROG off grass, Sport Aerobatics: 50 to 60 Watts per pound.
Pattern: 70 to 100 Watts per pound.
(Note that the actual calculation of these values depend upon the lift and drag coefficients, and so the higher values should be used for draggy airframes.)
For a typical current of 25 Amps and a cell voltage of 1 volt per cell, determine the number of cells required (Total Watts divided by 25).
Select the MaxNEO motor for the power and number of cells defined. Geared motors will generally give better performance for all but racing applications by allowing the use of a larger diameter, higher pitch, more efficient prop.
The maximum airframe weight (including the radio and servos) will be the total weight less the motor/battery/controller (the "motor power system") combined weight. Can you build it that light and still achieve the required strength? Generally, the "motor power system" weight should represent about one-half of the total flight weight.
Determine the approximate stall speed: Stall speed (mph) = 3.7 x sq. root of wing loading (oz/sq.ft)
The propeller pitch should give a theoretical "propeller speed" of at least twice the stall speed, and preferably 3 to 4 times the stall speed.
The propeller diameter should then be chosen to give the required current draw of about 25 Amps. (The diameter should always exceed the pitch).
As a final check, when it is all put together, the measured static thrust should be at least one third of the total model weight. Note that static thrust measurements are only meaningful if the propeller diameter is at least 150% of the pitch (e.g. 12x8).
Using the 1700 mAh cells will give a full power duration of around 4 minutes at 25 Amps (1.7 x 60/25). Going back to the power loading required for level flight (section 4 above) then allows estimation of the maximum "cruising" time. Actual flight time will of course be less than this due to the full power used at takeoff.
Finally, always use thick multistrand wire (no less than 14 gauge or 2.5 sq. mm), good connectors (e.g. Sermos or Powerpoles) and a high efficiency, high rate speed controller that can handle the required number of cells and current.
If you find that you cannot satisfy all of the above rules with some particular model, BEWARE! That first flight could be quite interesting.
http://www.charlesriverrc.org/articles_modeldesign.htm
rutat is offline Find More Posts by rutat
Discussion Looking for a DIY Powerbox Harpia DIY Electronics 18 Jan 17, 2016 03:40 PM
Discussion looking for DIY receiver designs village_idiot DIY Electronics 11 Jun 08, 2007 09:03 AM
Discussion im looking for a good tutorial jaas75 Beginner Training Area (Aircraft-Electric) 7 Oct 19, 2006 10:33 PM
Discussion Looking for a particular tutorial CAFB 04-12 Electric Heli Talk 3 Sep 10, 2006 07:16 AM
looking for DIY 12 volt power supply instructions super_nova DIY Electronics 4 May 09, 2005 11:06 AM
