Old Jan 09, 2006, 01:49 PM
tow is offline
tow
Find More Posts by tow
tow
tow's Avatar
Norway, Nord-Trondelag, Namsos
Joined Dec 2003
Idea
Mr. Boogies JSF F-35 with thrust vectoring
Finally adding this modification to my F-35.
Have yet to test it fully in flight, but maybe I can outclass the Suhkois and do the "Cobra"?
tow is offline Find More Posts by tow
Old Jan 09, 2006, 02:53 PM
airmcn_3 is offline
Find More Posts by airmcn_3
Moore, Oklahoma
We need better pics!!! Please let us know how you built that. Later Chris
airmcn_3 is offline Find More Posts by airmcn_3
Old Jan 09, 2006, 02:56 PM
Mr. Boogie is offline
Find More Posts by Mr. Boogie
Mr. Boogie's Avatar
Morristown, New Jersey (excl EWR), United States
Joined Oct 2003
Yeah Tow,
We need better and bigger pictures!
You say you have yet to fully test it in flight, implying that you have tested somewhat.....
Details man, details!
Mr. B
Mr. Boogie is offline Find More Posts by Mr. Boogie
Old Jan 09, 2006, 03:08 PM
tow is offline
tow
tow
tow's Avatar
Joined Dec 2003
Will submit better pics when my camera co-operates with me againI `ll try to post some more tonight (Norwegian time.)
Old Jan 09, 2006, 06:05 PM
Paul DF jet man is offline
Find More Posts by Paul DF jet man
MORE POWER IS THE KEY
Paul DF jet man's Avatar
South Australia
Joined Jun 2004
Tow
You are going to need a bigger servo i think you will find. the thrust from the engine will overpower the servo and you wont get full thrust vectoring capability. you will at lower power but when at full power i think you will find it wont be able to push it around to well. + if the servo is OVER loaded constantly you might cook (short circuit) it and this could cause receiver problems its happened before.
That said i LOVE your jet and the idea looks Grate cant wait to see her fly.
Good luck.
Paul DF jet man is offline Find More Posts by Paul DF jet man
Old Jan 09, 2006, 07:04 PM
Mr. Boogie's Avatar
Joined Oct 2003
I like the setup tow.
What's the weight penalty? and have you tested movement of the tailcone on the bench at WOT? This would be one way to preview functionality.
B
Old Jan 10, 2006, 01:46 AM
Sluf7 is offline
Find More Posts by Sluf7
Sluf7's Avatar
New Zealand, Taranaki, Midhirst
Joined Feb 1999
Well Mr Boogie looks like the lil thing will get Jiggy with it.
Concur on the Servo issue.
Sluf7 is offline Find More Posts by Sluf7
Old Jan 10, 2006, 02:35 AM
RCParkflyer is offline
Find More Posts by RCParkflyer
RCParkflyer's Avatar
Racine, WI AMA# 809291
Joined Nov 2003
signing on
RCParkflyer is offline Find More Posts by RCParkflyer
Old Jan 10, 2006, 05:07 AM
tow is offline
tow
tow
tow's Avatar
Joined Dec 2003
B
Weight increase is I think insignificant, a few grammes over the weight of the added servo shouldn`nt mean much. I tested tailcone movement at WOT and that works fine. I may need more movement maybe, but that remains to be seen. I tried a system earlier using vanes in the duct coupled to the tailerons,wich turned out to be a WILD ride to say the least! Barely saved the bird down in one piece! Working in the vertical pitch only seem like a much better idea.
Old Jan 10, 2006, 05:13 AM
tow is offline
tow
tow
tow's Avatar
Joined Dec 2003
Originally Posted by Paul DF jet man
Tow
Good luck.
This is an issue I agree - if it turns out the servo isn`t up to the job or a more rigid setup is called for I go for that. To prevent current overdrain I will use an Ubec sircuit.
Old Jan 10, 2006, 06:17 PM
South Australia
Joined Jun 2004
that is a very good idea.
im sure it will benifit from a say??? a JR 331 or a hitch 56 BB
good luck
Old Jan 10, 2006, 06:40 PM
Twizter68 is offline
Find More Posts by Twizter68
Owns an Evil Black Rifle
Twizter68's Avatar
Kuwait
Joined Dec 2005
Just curious...
How did you do that, and is the vector nozzle sealed to the exhaust tube, or is it just around it?
Twizter68 is offline Find More Posts by Twizter68
Old Jan 11, 2006, 01:13 AM
allintheair is offline
Find More Posts by allintheair
The Netherlands
Joined Sep 2004
Great stuff!
I also like to have more details on the nozzle. Material, shaping, mounting...
If it turns out to work well I might put them on the flanker...
Marc.
allintheair is offline Find More Posts by allintheair
Old Jan 11, 2006, 04:21 AM
tow is offline
tow
tow
tow's Avatar
Joined Dec 2003
The vector-nozzle rotates freely around the outlet-tube since it has a slightly wider inner diameter .The outlet protudes ca.4mm into the exhaust-cone and allowes for some movement.
Build Log X-31 EDF Park Jet with Thrust Vectoring System jetset44 Foamy EDFs 427 Jun 29, 2014 10:00 AM
JSF F-35 Ready for Launch Ken Lapointe Electric Ducted Fan Jet Talk 50 Sep 04, 2009 10:39 PM
Video X-31 EDF Park Jet with Thrust Vectoring System jetset44 Electric Plane Talk 4 Apr 25, 2006 02:24 PM
OT: Fullscale MiG-29 with thrust vectoring Kevin Cox Electric Ducted Fan Jet Talk 4 Aug 17, 2005 07:17 AM
Mini Vertex with thrust vectoring! RCAV8R13 Foamies (Kits) 9 Nov 04, 2003 07:55 PM
